GreenMachine allMod aftCycloneVz DaveRc Tangent astro 3220
aCeMadMod   1 kW
Re: GreenMachine allMod aftCycloneVz DaveRc Tangent astro 3220
Post by aCeMadMod » May 21 2019 6:26am
Hi all . More work geting done this week.
I fitting delta 3220 . That fan mod done to it.
The shalf is get cut down from 1/2 to 3/8 to fit dave gearbox .
I just hope my gearing is right . Other wise to slow or wheelie. Not fun.
Looks like can't use big vesc chageing delta mode yet ๐Ÿ˜ญ
So no choise but to use a real deta motor
I hopeing in time they will frimware or software update to play with fleid waeking .๐Ÿ˜Ž๐Ÿ˜‚
Thank you all
aCeMadMod   1 kW
Post by aCeMadMod » May 24 2019 2:02am
Hi All
All parts are made and fit ok .for test run
Need pick 40/1 or 20/1 gearset
I have a costom 28t freewheel i dont know if i use it
With 40/1
I think it to big for deta motor and 20/1 i have both gearsets
It will use some zip ties and tape job. First run
Not petty but working๐Ÿ™
Dont want rian will not test it
This bike had one harder i ever done the tools you need mind blowing . And odd
I sill make wire covers to hild wires .and water proofing
Thsnk you all
aCeMadMod   1 kW
Post by aCeMadMod » May 28 2019 1:58am
Hi all looks like i get very close to call it done
Motor mount all done . Useing deta motor with fan
I just need to work out what is best coating for less heat it help to repiar gears ..
Cirramic coating is close me shop . Or Ti firecoat half away around au. Melbour both costly
Dave looks like run away and dose not care about Es users any more . ๐Ÿ˜ข
You can"t get parts or help now atfer this long i got use try custom made parts 3 time before it works. By hand by my self
You never happy cnc is king
Ano ti to 23 volts
I just hope the cable tie can hold my ti pot . From moveing from chian
Next part to make heatsink water bottle for big vesc
Thank you all
aCeMadMod   1 kW
Post by aCeMadMod » May 29 2019 12:10am
Hi all
Looks like good news can use reuse water bottel and most likely my old heatsink . Will fit inside
I may sill need to mill new heat sink.
For maxien heat . Tranfer
And water cooling i have space.
Thank you all
aCeMadMod   1 kW
Post by aCeMadMod » Jun 06 2019 2:28am
Hi all
I got a bit done this . Week
I had make new parts . My lucky i was able to reuse old motor mount my one 1 side that not cracked
Has a heat sink and place holder
It sill needs to be clean up and ano last step .
More waiting i need to mod this part more
It one most unez bike i have ever made.
I need to write a book how take it apart.
I need lower my gearing i know the tox will be crazy
I have right now 16t 1/8 surly cog
I have track cog from the 1950 its 15t very fat more 4.4mm i need to retherd it .
So close but to tight it will kill my ti cog holder if i try get it off
I have 12 t 1/8 track cog come be bit may low for chian could hit my cogs holder๐Ÿ˜
My big vesc
https://m.youtube.com/watch?v=0IIB_-XtuH4
Thank you all
aCeMadMod   1 kW
Post by aCeMadMod » Jun 11 2019 1:42am
Hi all i got alot done you cant tell
I made costom bolts and retherded track cogs made dropouts fit 27.5# wheel or 3.0tire
I fear break chian now
Kmc chian better make super strong chian
Other wise walk of shame i take all my chian breakers with me now
It need ano or nick plated or copper it all about heat
I ask prices in moring
updated Ano has to bee
Green/ black / red
I found trinite coating $ 87 for 11kg of steel
Thank you all
aCeMadMod   1 kW
Post by aCeMadMod » Jun 19 2019 5:14am
Hi all i cant seem to up date my last post and try in pics
I add some new ones
I made this for casting in sand
Last year work good for mixing
I very close to call tthis done waiting for ano parts back and trinite gears.
Thank you all
aCeMadMod   1 kW
Post by aCeMadMod » Jun 30 2019 2:12am
Update
aCeMadMod   1 kW
Post by aCeMadMod » Nov 13 2019 4:22pm
Hi all this been made for 3 time .
And 5 culors this made like a tank now
New rims and tires . And for Es dude who wants
Make mid 4500 watt copy me
Off set no need for chiain pullie
I am sill save up for new parts . All will have my bikes with di2 or wireless in the end
Battery is big key for up grades . I whiss us lucky i hope next few years we have some thing
Thank you
aCeMadMod   1 kW
Post by aCeMadMod » Nov 21 2019 11:49pm
Hi all done 2 mods this week
One this ebike now drill out alloy the ring holds lights to show my battery change in big ring
I use tri led lights. Blue / red/ green
I may use 1 colour for now
Red ez see in day light
Has my batterys are postcost very hight cost now it feel like more a ban In au soon
I feel they try to kill evs all over the world
Thank you all
