GreenMachine allMod aftCycloneVz DaveRc Tangent astro 3220
aCeMadMod   1 kW
Re: GreenMachine allMod aftCycloneVz DaveRc Tangent astro 3220
Post by aCeMadMod » Sep 02 2018 5:57pm
more to come
aCeMadMod   1 kW
Post by aCeMadMod » Sep 07 2018 3:10am
hi I got big vesc. . first thing I do make a copper water heatsink for it ,
I feel sorry for a 3220 motor now . and more sorry for cyclone
only thing I can:t work can"t out if can take 18s lipo ?
I was thinking it could
Mary thank to a Es user who been most Cool , selling and trade with me
I now from him can make dual 3220 ebike
more to come when I real make the water block
take care all 8)
aCeMadMod   1 kW
Post by aCeMadMod » Sep 09 2018 11:38pm
hi all I got new bearing for cyclone. 1680 watt gearbox now use all hybrid ceramic
it help to save wight . 8)
in a week I be able to use my mill I kill it this week lol need new brushes
I will install Ti shalf and all new ceramic bearings I wight stock vs mod
cyclone
take take
aCeMadMod   1 kW
Post by aCeMadMod » Oct 25 2018 11:53pm
hi all I hope you are all well. Yes I have not stop try to get this ebike Done all year. :roll: I step . forward. and 3 back
I end up need make Tool after tool to solve things. I own a full work shop . from this ebike not cheap
I Made a Full titanium jack shalf tube it only one the world for this frame
I use a isis titanium. BB. from trial bike my guess I cut from stock. 500 gm to 700gm. in wight useing titanium
plus add 2 more bearing and repair gase oil from the ussr to hope repair the old 2 bearing I used it to costly 4 bearings cost me $200 for 4 of them
I need redone my big alloy rings for holding motor I try to weld it just crack on 6s
to shops
I look for get do very soon
I waiting for old isis cranks soon I cut them jackshaft
in end I will have make my own isis Ti end for chainwheels. not looking forward at this :cry:
take care all :bigthumb:
aCeMadMod   1 kW
Post by aCeMadMod » Oct 28 2018 5:31am
ti ez to ano
just water and barking soda
I HOPE to cast this week
take care
aCeMadMod   1 kW
Post by aCeMadMod » Nov 21 2018 5:47am
Hi I Done A great deal work . wow all year not stop try get this dam bike work . I had make more tools for just a 1 off job , I know So Mary trade from this ebike . a lot of Fails
I can't UPLOAD PIC ANY MORE MY OS stop working
I Got my full 1 day work on aLL my bikes in 2 years dam they a alot brake to bleed :shock:
plus I crack a seat post when riding home lucky it did not go up my ass
I cut off this ebike about 2 Kgs in wight by use Ti ,. and bolts it all look Very nice now
I mill the water block for vesc this week
I hope show what have done Take care all :D
aCeMadMod   1 kW
Post by aCeMadMod » Jan 11 2019 1:48am
hi al I had not stop on bikes . 12hours day 6 a week
I was test Vesc 4. with new gearing
has I have Dave 40.1 gearbox with it ..less 10 km Vesc 4 now Dead on 12s with new gearing to make move faster
old was 42 teeth
38 teeth motor
13 to 32 t
new 37t
motor 34t
13to 32 t
:roll:
lipo" s were change only to 4.10 volt
hope a other Es member can help me fix it has not stock. rev look the vesc 4 do not like pull more then 50 amp .
the bike is beast. whiss I could post it,.
thank you all
tangentdave   1 kW
Post by tangentdave » Jan 11 2019 12:25pm
Isn't the VESC4 only good for about 50A? I had a VESC6 running with a 20:1 gearbox on 12s, it lasted a whole battery pack before getting smoked on a hill climb and it's rated for 90A burst. You really want a lot of FETs on the controller.
GGMT/Tangent 8kW
tangentmotors.com
aCeMadMod   1 kW
Post by aCeMadMod » Jan 30 2019 8:08am
My old vesc4 which not a stock layout is dead. It had great way for cool fets in 1Side plus heat sink
I luck to get a vesc 4 focbox Plus 1.5kg alloy plate has a heat sink
Wow is last 2 rides so far up 2km hill. 1500 watt min whole way I had to low my gearing at backwHeel from 32/12
To
28/11 and sill try low gearing
And hope to get
To 30teeth Motor chanring
35teeth Bike Chianring both are rare and costly chianrings in slianless steel
I add wight bY forks to bike not be able to pull forks off the ground.... Wow I sill did 13 pounds forks
Only with vesc4
I hate to see the new big vesc I getting what it will do.
Will noT need a c. a 3.0 with big vesc it can 1000amp spike
Dave gearbox sorry say leaks Oil like Like it water
Let hope it only breaking time
Hope work out how best way to up load pic to es
Thank you all
aCeMadMod   1 kW
Post by aCeMadMod » Feb 03 2019 4:06am
Hi all I try some thing crazy. That this time 24@ Deghill for 750 matters with focbox and 6t 3220 with Dave Gearbox 40.1 with in some crazy gear can Not could pedal. Or Think about try padeling
Shock I need smaller gear use 25teeth I think I can use like 20 more speed..
Or use deta when get big vesc soon
I have try to find new chian rings 30t hard find in Au
And Stainless Steel. I may try Ti rings cost is crazy.
Any way I do it in Au
If any know cheap steel 30t rings plz tell me thank you all
aCeMadMod   1 kW
Post by aCeMadMod » Feb 10 2019 4:53am
Hi all I try new setting
It now crazy ebike
Focbox. Work well. Not dead in 2 week try up crazy hills
Today max when up Alot
55amp.
After changing motor and to 115 amp
Battery 50amp
Gearing motor chianring
20/34
Bike
36. Rear 11/25
I waiting fOr new rear Cass. 11/23
Just hope I can hold on next upgrade
20/30. I have thank sram make steel chanring.. Nowrow wide. 28/30/32 Cheap than Stainless Steel
.i can up grade all my bikes now
Bike 34 rear 11/23
I think I broke toe. And figer
Not at the same time
Thank you alll
aCeMadMod   1 kW
Post by aCeMadMod » Feb 13 2019 5:48am
Hi all got new rear Cass 11/23 its8speed only use 11/19and made new spider for 30/ 32 steel chianrings
It sould be good Norrow wide rings
Look like in 2 week I killed 2 chains. 1 rear Cass 11to 25
And 1 stainless steel roller..
Had made new one in Ti. Could get costly to run
Next would crmo steel roller
If no fast. Big vesc with fix that sets in detA mode
Thank you all
aCeMadMod   1 kW
Post by aCeMadMod » Feb 15 2019 9:00pm
hi all this from last year when i could upload pic from my pc
waiting for big Vesc to use this ebike :bigthumb: :thumb:
i useing wireless remote cleaner for bike , but plz keep Spart set battery's on at all times
thank you all
aCeMadMod   1 kW
Post by aCeMadMod » Feb 20 2019 4:28am
Makeing new motor mounts this week
They grow in dark too. Once add leds inside rings
I sould cut 500 gm off last rings
It not cast this time
Plus I try water cool my pot. Not ez
Thank you all
Who makes the strongers chain for ebike?
aCeMadMod   1 kW
Post by aCeMadMod » Feb 21 2019 7:07pm
Hi all I found way sending pics without a PC 🙏😎
I show my chianring pics I made for this ebike
From a isis cranks
aCeMadMod   1 kW
Post by aCeMadMod » Feb 26 2019 5:52am
Hi i was need help it part I cannot make my self
I need A place water jet or 3d print TI
In Au .
I price out the jackshaft wheel for isis it pian the ass using Ti
Hard to cut. Without work hard it . Costly
I will cut the therd my self.
Thank you all
aCeMadMod   1 kW
Post by aCeMadMod » Mar 04 2019 4:16am
Hi all look I am waiting to get more Ti bar
Isis axle will too hard find a 5d water jet in au. I need wait 3 week to get ti bar
I starting agian whole axle and holder the way I want And need to be made right for gearing I want.. Use track cogs is cheapest in long run
I willfix fork I waiting for 3 years to in Ti end caps . No one is this crazy. To fix carbon down hill forks
I try made a alloy end cap one it was a fail. Fear glue will not hold it in long run.
Ti ez, to ano. I can't pick what colour. Any help
I start my Gti with cyclone and big vesc
Soon
Thank you all
aCeMadMod   1 kW
Post by aCeMadMod » Mar 13 2019 1:20am
Hi all I got motor mount at last.... Only taken 2.years
Next part need made custom Ti freewheel and axle
Sill waiting ti and bearings
It crazy small for size balls bearing of my axle will 21 mm Wide.
I try find a standed bearing size and cheap
They 16$ each
Hope they give bearings give me 2000km for before I needing to Chage them
I will use 3 of them to replace Isis bearings which are bearing 20mm wide axle
Thank you more waiting. I will use a big vesc. It help save wight C. A 3.0 can go. Clean look
Next part it upgrade shock. If I can
Thank you all 8)
aCeMadMod   1 kW
Post by aCeMadMod » Mar 26 2019 4:30am
Hi all look like I have my ti bar for axle I guess take 2weeks to get axle and freewheel track holders done.
Looks Like 3220 like pull 50 to 60amp with vesc 4 ,
With stand gearing
Can't wait try big vesc what a safe amps for a 3220 in deta
First time fear killing my motor.
300amp from a big vesc
Thank you all
aCeMadMod   1 kW
Post by aCeMadMod » May 07 2019 6:39am
Hi will start on Ti axle and freewheel holder.
Then I need to take my 3220 motor deta shalf size down to fit Dave Gear box.
I will have 2 big vesc to play with. 60v and 75v
My small focbox was fixed by a great Is member.
So it will reuse for the road.
Don't ride In the rain
To costly.
More update this weekend
Thank you all
aCeMadMod   1 kW
Post by aCeMadMod » May 09 2019 2:39am
Update
aCeMadMod   1 kW
Post by aCeMadMod » May 12 2019 9:12am
Hi all you can add dead big vesc 75volt to killed esc I had
Looks like a 3220 deta motor no joke.
Next try is with 60volt big vesc I hope it save the day
Vesc big only last 2 sic then big magic smoke
Thank you all
aCeMadMod   1 kW
Post by aCeMadMod » May 13 2019 12:12am
Update
aCeMadMod   1 kW
Post by aCeMadMod » May 14 2019 12:34am
Hi all started 2 Rev in Ti this time I guess it take a week when I have time
This the old one it only good for test fit.
Useless otherwise
Thank you all
aCeMadMod   1 kW
Post by aCeMadMod » May 16 2019 3:27am
Hi all got Ti axle and track cog holders done .
I test this week
