Bafang bbs02-750 48v on a 16'' folder bike, good idea?
nukezero   10 kW
Post by nukezero » Sep 12 2015 7:13pm
Do you guys think it is a good idea to throw a Bafang bbs02 750w 480v on a citizen Tokyo 16'' folding bike?
Speed and compactness is the main priority :)
Goal is to reach 20-25mph minimum.
Nobuo   10 kW
Re: Bafang bbs02-750 48v on a 16'' folder bike, good idea?
Post by Nobuo » Sep 13 2015 6:08pm
That depends if you want it to still being a folder bike :lol:
For frame strength there is not any problem.
I convert a very similar foldable bike into an 1000W EV (no chain) with a 48V 43Ah battery (10kg of battery).
it is just not reliable anymore to be easily transported if you doesn't go riding it :o
The frame look good for it, check if a bbs2 fits right
* Lithium + Air = Fire * <-----> ** Lithium + Chemical-Additives + Air = ZERO Fire **
<Battery and EV works>
https://facebook.com/evmadrid1
<Battery building resources>
http://www.endless-sphere.com/forums/vi ... 14&t=68005
nukezero   10 kW
Post by nukezero » Sep 13 2015 6:47pm
Nobuo wrote:That depends if you want it to still being a folder bike :lol:
It has a sturdy steel frame and 6spd freewheel. if I pair it with a 52T BBS-02 750w, and 14T in the rear, I wonder if I could get at least 22-24mph. The biggest complaint on this tokyo is that people were saying its geared too low.
try_all   100 W
Post by try_all » Sep 14 2015 9:38am
wow 43Ah :O what kind of range do you get with that massive battery
jkbrigman   10 kW
Post by jkbrigman » Sep 14 2015 9:53am
Why not use the Seoul?
http://www.citizenbike.com/catalog.asp? ... duct_id=48
The 20" wheels will give you an edge over the 16" wheels to reach 20mph.
Plus, it's 4 lbs lighter, same frame.
Beware: those bikes have six speed 14-28T freewheels.
You will want to swap out that freewheel for something that's 11t on the smallest gear.
http://www.ebikes.ca/fw7spd1132.html
I could not find a six speed 11-32 or 11-28.
eRecumbent. 9C 2810, 6-FET,CA,18S3P LiPo, Kenda Kwest. 33mph max 12.8Wh/mi (22mph avg) Phat Bike Commuter HS3540, 6-FET, 18S3P LiPo, Schwalbe Marathon 47mph max 25 Wh/mi (28mph avg) Basic LiPo Charging Thread , Add Throttle to Multispeed Bike
dogman: "I bet if you just don't ride like a jerk, you can do whatever you want up to the speed where everybody looks at you like this. :shock: "
tomjasz: "Romans go full dork. They could give a hoot what 'Merkins do."
Nobuo   10 kW
Post by Nobuo » Sep 14 2015 11:35am
300km (186 miles) at 25mph. With a similar rigid frame, the battery contruction is complete made in order to minimize the energy losses. Also the motor into the 16" wheels
Y need 7Wh per kilometer
try_all   100 W
Post by try_all » Sep 14 2015 12:49pm
thats F..kin awesome mate props to you.i was looking at this battery on ebay:
http://www.ebay.co.uk/itm/321862210818? ... e075e&cp=1
Do you think i can get atleast 200km with just throttle at 30mph? Im using a 1000w 48v ebay kit.
Nobuo   10 kW
Post by Nobuo » Sep 14 2015 12:59pm
If the battery is made with high quality li-ion cells and the conductors has the enough quantity in every place, so it deliver close the power it has, so then you should ger that range.
I use also relatively high pressure on both tires, and I have no chain. All the train losses are from bearings basically
Ekibevoli   1 µW
Post by Ekibevoli » May 19 2017 11:09pm
Does anyone know if the bbs02 fits the bottom bracket of the citizen folders? I have a system, but am hesitant to buy the folder in fear it may not fit.
tomjasz   10 GW
Post by tomjasz » May 19 2017 11:25pm
Ekibevoli wrote:Does anyone know if the bbs02 fits the bottom bracket of the citizen folders? I have a system, but am hesitant to buy the folder in fear it may not fit.
What does the BB widthe measure at? Link?
Ekibevoli   1 µW
Post by Ekibevoli » May 20 2017 6:26am
The Bafang BBS02 fits into 68mm wide and 32mm diameter.
