Bafang BBS-HD cabling ??
mbackc@gmail.com   10 mW
Post by mbackc@gmail.com » Nov 27 2015 1:25pm
Hello.
Just received my new BBS HD, but there is no instruction manual.
It should be kind of obvious to install, but i´m in doubt of some of the cables from the motor.
I´ve connected the following:
Display
2 x brakes
speed sensor
thumb trhottle
Power supply
There are three more cables that I don´t know how to connect. One with two cores (Blue & black) and another one with two cores (red & black.) These two have a small black connector/plug on them. The last cable have one of the round black plugs (yellow in the middle) with three.
Does anyone have a wiring drawing or installation manual for this ?
Thanks in advance.
Michael Back, DK :D
Dogboy1200   100 W
Re: Bafang BBS-HD cabling ??
Post by Dogboy1200 » Nov 27 2015 1:56pm
Can you take some pictures? The cables you have connected are all the one's my BBSHD has.
2007 Transition Preston FR BBS02 https://endless-sphere.com/forums/viewt ... 28&t=73635 Now HD https://endless-sphere.com/forums/viewt ... &start=225
2006 KTM 250 XC-W
2005 crf50 stunt bike
Oset 12.5 (son's bike)
PW50 (son's bike)
Mongoose Kids Fat Bike BBS02 https://endless-sphere.com/forums/viewt ... =6&t=84133 https://endless-sphere.com/forums/viewt ... e#p1232034
Post by mbackc@gmail.com » Nov 27 2015 3:38pm
Photos
Dogboy1200   100 W
Post by Dogboy1200 » Nov 27 2015 5:59pm
Crazy! mine does not have those additional wires.
2006 KTM 250 XC-W
PW50 (son's bike)
Tor   1 mW
Post by Tor » Nov 27 2015 6:55pm
I got the same 3 extra cables - no idea what to do with them - help!
Thanks any advice
Tor, Norway
:D
bbshd plugs.JPG (67.58 KiB) Viewed 5705 times
WoodlandHills   10 kW
Post by WoodlandHills » Nov 27 2015 11:10pm
Strange, mine came like DogBoy1200s with no extra connectors. I have read of some BBSxx drives coming with a plug for a headlight (there is a provision to turn it on and off in the display), but I have never seen connectors like the two squarish black ones. Since you are in Norway, I guess you got it directly from China, any luck contacting your seller?
If it was me I would hook up what you have and plug it in and try it. Mine worked without the other plugs, yours probably will too. Perhaps the other plugs are for some sort of EU mandated pedal cadence sensor that was not included in the kit and you can just ignore them.
Tor   1 mW
Post by Tor » Nov 28 2015 5:08am
Kevin at http://www.btn-ebike.com who sold me the kit says the extra cables are for gear sensor and light :idea:
He told me to watch their site - they will soon sell light and gear sensor to connect to these cables.
I guess the rest of the cabling goes like this: https://www.youtube.com/watch?v=akA1vg5fcwY
Cheers
Tor, Norway
Post by mbackc@gmail.com » Nov 30 2015 3:21pm
Hi all - thanks for your replies...
It is correct Tor - the cables are for gear sensor and rear / front light...
IMG 2570 副本.jpg (135.07 KiB) Viewed 5565 times
tommie   10 W
Post by tommie » Nov 30 2015 7:10pm
Hmmm.... the obvious question now is when will the gear-sensor be on sale?
And will it fit the older BBS02?
MrMagu   1 µW
Post by MrMagu » Dec 15 2015 6:25am
Thanks! I had the exact same "3-cable-left-over-problem", and ended up here :-)
Regards
MrMagu
twist   10 mW
Post by twist » Feb 11 2016 8:50am
I tested the two light connecter.
If I turn on my light of the C965 display I have on:
BLUE/BLACK 5.8V
RED/BLACK 6.2V
If I turn the light off there is 0V ... so it has really somethink todo with the light.
Wish it would have been 12V!
Maybe we can use it to charge our phone :)
Does anybody know how all the plugs are called?
Would like to build my own cables!
So the yellow plug, the green EB-BUS plug, light connect plug, and so on!
Would be great to know!
Thanks
dirkdiggler   10 kW
Post by dirkdiggler » Feb 11 2016 3:54pm
I don't know what the connections are called, but you see them on smaller lipo batteries, specifically for the JJRC H8C quadcopter. I believe those are the same connectors.
From aliexpress:
Lurkin   100 kW
Post by Lurkin » Feb 11 2016 4:29pm
JST-SM. Can be purchased on ebay, and you need a crimper to go with it. If you go the ebay route, make sure you buy the right side of the connection for the cable you are making.
Alternatively, make up the cable you want and ring round RC shops. Someone might be willing to crimp it for you for a fee?
deepfraught   100 W
Post by deepfraught » Feb 21 2016 11:25am
I have those extra cables also, have installed a BBS02 without them so didn't know their purpose, and like others ended up here here wondering what they were.
I've just been routing the cables and deciding on protective conduit and grouping, handy to know thanks for the info.
The switchable light option is a nice touch. I''ve got it on a Bosch bike, and on a pedal only bike with dynamo I've just changed from Edelux to a B&M Luxos U that is nice modest lighting and legal/courteous.
Reminds me the greatest let down of 2015 was finding out about this high/low beam ebike light and that it's for OEM only, so on the $5k+ bikes. The brake light triggered tail light looks neat also.
http://supernova-lights.com/en/m99-pro
PS: I wouldn't go to great lengths to keep those lighting connectors and move to whatever you have already if you use a soldering iron. could find a stick pop up to do damage.
History: Front hub SS 200W, China E-mtb 200W, 3x A2B Metros, Commuter Booster beta, 2.4kW d/s w/DD kit, MAC 1.5kW road/flatbar 1250Wh EM3EV frame batt, BBS02 750W d/s MTB 1250Wh frame batt. All sold (except A2B Metros pending TLC from storage).
