Fumesucker
So.. I got my brushless motor the other day and wanted to confirm the rather vague motor constants provided by the seller.
The way I go about motor testing is to use two different propellers on the motor, measure the voltage, current and rpm with each propeller at full throttle as well as a no load current reading and then plug the numbers into a motor calculation program (I'm using http://www.peakeff.com/ and like it).
I've had an optical tachometer for a long time and was going to use that to measure the rpms, but lo and behold when I pulled out my tach the batteries were dead because apparently one of my grandkids had been playing with it and left it turned on. Of course the stupid tach uses four watch batteries that if bought locally cost more than I paid for the tach originally.
Since I'm basically an impatient cheapskate I tried to figure out a way to measure rpms without having to spend a chunk on four tiny batteries or waiting to order them from ebay.. After about five minutes of severe head scratching I realized I could possibly do the rpm readings acoustically by recording the sound of the propeller.
My digital camera will take quicktime movies with sound, so I ran my tests with the camera close to the end of the prop recording the sound of the blade tips going by. I then extracted the audio from the movie and put it in an audio editing program and was gratified to see that the blade tip passing by the microphone was conspicuously obvious.
Any method of recording audio will do, just so long as you can get the mic near the blade tip.
The freeware audio extraction program I used is here: http://www.aoamedia.com/audioextractor.htm .
The freeware audio editor I used is here: http://audacity.sourceforge.net/download/
And here is what the recording looked like in the audio editor..
So I then used the spectrum analyzer built into the audio editor to find the frequency of the tip passing..
Note in the spectrum plot window on the bottom there is a readout for cursor and peak, the peak is at 79 Hz, which means the blade tip was passing at 79 times per second.. (79/2)*60=2370 rpm..
There you have it, rpm measured acoustically and all with freeware..
