MitchJi
Hi,
I am planning to get one of Matt's drives and I think this deserves a separate topic. A 2kw to 5kw motor needs to be mounted very securely.
The possibilities are (if I'm missing something let me know):
Thanks!
Mitch
Welding - Is any welding at all acceptable on an aluminum frame or swingarm?
Bonding - is there any kind of bonding process that is strong enough?
Fabricating a mount that is complex enough and fits the frame well enough that bolts or bonding would be secure. The fabrication might be expensive but this should work. Is there an easier solution?
Thanks!
Mitch
