africanandy187
- Joined
- Nov 30, 2008
- Messages
- 22
This is my e-bike project for the winter!Having seen cyclone kits i wanted a chain drive system having been previously very disappointed with a 200w hub motor (legal limit here in sunny old england)
The bike is a piece of junk really, one of those made to look good mountain bikes where nothing works and you end up upgrading every component because when one fails you have to replace a whole lot!Light aluminium frame though, the shocks are a joke though!No breaks on the rear as there is no rim brake mounts (how rediculous!)
The 350watt scooter motor is mounted to the frame with u bolts i made from threaded rod, currently there is an 11 tooth sprocket on the motor and 68 on the BB, waiting for the 80 tooth to come.It has a cyclone crank and freewheel, greased as it wasn't from the factory!
Started the project with great optimism but now i'm beginning to think of all the problems!Ultimately with all the reduction it will be about 10:1 at most and i'm thinking this isn't going to be enough!Am i just being silly or will it be way to overgeared? I am not expecting it to go up any significant hills at all, infact its pretty flat where I live (maybe 1:100, 1:50).
The bike will have its first 24 tooth chainring functioning, but i'm only planning to pedal up steep hills without motor at all and on the flat, gentle hills i willl be using the motor only.
Planning to have 2 18AH AGM SLA batteries on a pannier rack at the back, also the bike is going to run a YK40 yiyun 28 Amp controller
Please somebody tell me if it's imminent failure before i waste anymore money on this project!
