Commencal Supreme Custom Mid-Drive Build
steven.b.watts   100 W
Re: Commencal Supreme Custom Mid-Drive Build
Post by steven.b.watts » Jul 20 2017 10:51am
Unfortunately the set screws on #1 are 90* apart not 180* apart. So I may have to buy the one that's drilled for pinning and either pin it (not sure how reliable that would be under such high rpm) or tap the pin holes for set screws since the flats on the Astro are 180* apart.
Time waits for no man
Mid-Drive Build
panurge   10 kW
Post by panurge » Jul 20 2017 4:56pm
Here for up to 22t track cogs http://www.velosolo.co.uk/shoptrack.html
JulesL.
Forsan et haec olim meminisse iuvabit
Onion MP6 - recumpence drives - CAV3 - CC HV160ESC - Astro 32204t
panurge   10 kW
Post by panurge » Jul 20 2017 5:00pm
I'm pretty sure you can ask Astro to have whatever kind of flat degrees or coupling option if you order directly from them.
JulesL.
panurge   10 kW
Post by panurge » Jul 20 2017 5:05pm
I think I have not a 180° flats on my astro. But I maybe wrong, It works just so fine and reliably that I haven't removed my primary pulley from the motor shaft I think in the last 3 years or more :wink:
JulesL.
Post by steven.b.watts » Jul 24 2017 6:26pm
Okay made my order to staton. Figured out I could change jackshaft OD to 15mm so I went with 0.9" 1.375x24tpi 15mm ID adapters on both ends ofjackshaft with 22t ACS rhd freewheel onleft side, 17t 3 prong cog on inside of right side and 12t Chinese freewheel on outside of right side. Ordered a 1.375x24tpi threaded 13t cog with lock rings in case it breaks. Right crank has 1.375x24tpi threads on the inside so put a rhd ACS 22t freewheel there to save my legs in case of freewheel seizure at high speed (thanks panurge). Also grabbed the 24t 3 prong cog for igh and found that igh gear ratio is 0.75:1:1.33. Also ordered 11t cog for motor shaft.
:mrgreen: :mrgreen: :mrgreen:
Mid-Drive Build
Post by steven.b.watts » Sep 04 2017 11:47am
Astro 3220 ordered!
Grin Tech 48v Satiator charger ordered!
Just waiting ages on Chinese 12t freewheel or threaded cog for pedal input :evil:
Mid-Drive Build
panurge   10 kW
Post by panurge » Sep 06 2017 5:09am
Sounds Good!
I would repeat it again and again, though: don't expect pedal ability from this config, at all.
How do you plan to fit a 15mm jackshaft where the previous was 12mm with supposedly 12mm ID bearings?
JulesL.
Post by steven.b.watts » Sep 06 2017 10:11am
Hey!
Yeah I'll have to deal with pedal issue later. Really wanted to get a ride in before the snow flies over!
The jackshaft rode on 4 bearings, 21mm OD 12mm ID 5mm deep. I was able to find 4 bearings 21mm OD 15mm ID 4mm deep
Mid-Drive Build
Post by steven.b.watts » Nov 03 2017 9:41am
Hey, just wanted to keep this alive. For whatever reason my machine shop has still not completed the final job -.-
Mid-Drive Build
aCeMadMod   1 kW
Post by aCeMadMod » May 20 2018 12:57am
hi is this ebike alive or dead ? :?:
Post by steven.b.watts » May 21 2018 4:49pm
Hey!
Bike is alive but there's snow on the ground here from November to April. Even after the snow melts in April there is still salt on the roads until sometime in May. Also I just got back from vacation. Also the company that does machining for me is a family owned business and one of the key members passed so they haven't finished the final job despite the fact that they've had the job since last October.
Will have updates in the next few weeks.
Cheers :D
Mid-Drive Build
aCeMadMod   1 kW
Post by aCeMadMod » May 23 2018 12:08am
hi send the job to me I get it done . if want it faster
any way to replace old pic.s in es. 8)
I hope all the best don't blow up the motor agian :pancake:
Post by steven.b.watts » May 23 2018 5:50am
Haha :D I wish it was that easy. But hey, if you want to help remotely then I could always use a hand. Any support is invaluable!
Ya, I really hope I don't blow it again :? Fairly expensive mistake...
Can't wait to have updated pics and info in a few weeks!
Mid-Drive Build
aCeMadMod   1 kW
Post by aCeMadMod » May 23 2018 6:49am
hi send pm
all the best 8)
Post by steven.b.watts » Oct 11 2018 9:20am
:twisted: :twisted: :twisted:
Mid-Drive Build
Post by steven.b.watts » Oct 11 2018 9:21am
aCeMadMod wrote:
May 23 2018 12:08am
Unfortunately I don't have the pics anymore! :x
Mid-Drive Build
macribs   1.21 GW
1.21 GW
Post by macribs » Oct 12 2018 1:29am
Is that a bafang motor?? There was no way to get the original motor + gearbox working?
What was the problem with the bike when you bought it? I remember there was some issues but the seller said it was minor work required to have it working. Must have been a little more then that if you ditched the motor+gearbox and went for bafang?
aCeMadMod   1 kW
Post by aCeMadMod » Dec 15 2020 6:00am
any more updates
its been some time
aCeMadMod   1 kW
Post by aCeMadMod » Dec 22 2020 8:32pm
i take ebike has i know it stoped
Post by steven.b.watts » Jan 08 2021 9:14pm
Hey everyone :)
The bike is sitting now with a Bafang motor mounted under the frame. The distance from swingarm pivot the bottom bracket is such that any chain drive is too loose or not big enough when a link is taken off. A belt drive could be an option but I'll have to completely redo the CAD model because the previous owner didn't send me the file and is now unresponsive.
I've been very busy these last few years working on a large automation project for a manufacturing machine. I look forward to getting back into this come spring, but also not looking forward to the amount of work trying to integrate belts! Haha. Ttyl :thumb:
Mid-Drive Build
