New build, BHT mid-drive "direct", custom frame
Overclocker   10 kW
Re: New build, BHT mid-drive "direct", custom frame
Post by Overclocker » Apr 17 2017 11:23am
did some weight optimizations and removed the gold color from the hub
now doing CAD (cardboard aided design / compass aided design) for the aluminum sprocket spider:
Overclocker   10 kW
Post by Overclocker » Apr 30 2017 12:38pm
i welded the original motor sprocket and a 13t 420 motorcycle sprocket together :roll:
rear hub is done, except for paint. that's a 53t 420 steel sprocket that's mounted to an aluminum carrier
ScooterMan101   1 MW
Post by ScooterMan101 » Apr 30 2017 2:37pm
Are you going to be charging the Battery Pack, through the Balancing Wires ( 18 wire/JST-XH Plug ) ?
or
Through the Main Discharge +/- wires ?
What size wire ( Awg ) did you use for your custom JST-XH Plug and Wires ?
Looks like you made your own JST-XH plug by cutting one and splicing it in between the others.
Overclocker wrote:finishing pack 1 of 2. 17s6p. no BMS, shown here w/ 18-pin balancing port. sand-filled 40A slow-blow fuse
My first conversion ... Sold
viewtopic.php?f=3&t=71378&p=1077497&hil ... 1#p1077497
It's 2018 already, ( now 2019 ) lets get some real , improved e-bike / e-velomobile / e-motorcycle designs .
Overclocker   10 kW
Post by Overclocker » May 01 2017 5:09am
ScooterMan101 wrote:Are you going to be charging the Battery Pack, through the Balancing Wires ( 18 wire/JST-XH Plug ) ?
or
glad you noticed the fatter balance wires, for faster balancing. i'll be charging through the main. not sure what AWG, just use the fattest that'll fit in the perf board
yes it's a DIY connector. i simply plug a typical 7-pin connector (w/ the locking lugs removed) into any point along the 18-pin array for monitoring/balancing
nutnspecial   1.21 GW
1.21 GW
Post by nutnspecial » May 01 2017 6:00am
Looks good man, I like the heavy drivetrain! What max speed are you shooting for? 17s and 17in moto @ 4:1 should be around 33mph (and ALOT of torque with 18fet)! I'd try up around 80amps if the controller is cool with it, but you'll probably keep the phase amps around 2:1 unless the ride is really heavy/big/stout. Even 200ph was ridiculous on mine lol.
skeetab5780   10 MW
Post by skeetab5780 » May 01 2017 9:04am
Nice progress on the hub assembly! That thing is going to be a torque monster
Overclocker   10 kW
Post by Overclocker » May 01 2017 11:09am
nutspecial wrote:Looks good man, I like the heavy drivetrain! What max speed are you shooting for? 17s and 17in moto @ 4:1 should be around 33mph (and ALOT of torque with 18fet)! I'd try up around 80amps if the controller is cool with it, but you'll probably keep the phase amps around 2:1 unless the ride is really heavy/big/stout. Even 200ph was ridiculous on mine lol.
yeah it's overkill. i could probably shave some more weight from the steel 53t sprocket but i'll probably do that later. i decided to use heavy #420 because i need this thing to ride through a wide riverbed of loose volcanic ash to get to my favorite trail. so with this setup i'll probably not have to worry about drivetrain wear for a while
id be happy with 45 to 50kph. i'm not too sure about that "percentage when loaded" term which defaults to 70% so your estimate is most likely more accurate
Overclocker   10 kW
Post by Overclocker » May 01 2017 11:11am
skeetab5780 wrote:Nice progress on the hub assembly! That thing is going to be a torque monster
next step is the swingarm
nutnspecial   1.21 GW
1.21 GW
Post by nutnspecial » May 01 2017 2:34pm
28mph
I was just guessing w/33mph. That 70% "loaded" is getting close to the highest efficiency and the torque fall off (~85% rpm imo), so if that's your target speed you'll be happy. The motor will get to 100% pretty quick though if you give it the power, and that looks like nearly 40mph based on the calc :twisted: !!
minde28383   1 kW
Post by minde28383 » Oct 02 2017 5:48pm
How is it going? Update us.
I'm on the verge to buy pit bike components for rear wheel from CN.
CNC alum rear hub 32 holes - 40usd
alum rim 17'' 1.6width 32 holes -35usd
spokes, and tyre will get locally for 25usd
but i see a lot folks to using bicycle components therefore it's hard to justify additional weight using pit bike components.
ebike build in progress
CN 5.5kw scooter (on sale)
E Mindless Maverick Talisman longboard, 2.2KW motor, 150Amps controller (on sale)
minde28383   1 kW
Post by minde28383 » Oct 02 2017 6:03pm
My 17'' tyre and 26 wheel sketch looks even less proportional.
rear: 572mm 70/100 Duro 17''
front: 700mm 3'' 26 Kenda Flame
I may switch front rim to 24'' or might increase rear wheel. Not sure which way it might turn.
17 26.JPG (28.35 KiB) Viewed 3285 times
Overclocker   10 kW
Post by Overclocker » Mar 09 2018 12:28am
i've decided to mount the motor on the swingarm but still coaxial w/ swingarm pivot
testing the drivetrain. it's quieter than i expected :roll:
minde28383   1 kW
Post by minde28383 » Mar 18 2018 8:00am
The noise is not too loud indeed; it is very silent on low RPM, alnost no sound, so you can crall in low speed like with hub but not generating as much heat in the motor. The sound is not too loud because it's is low kv motor. If it was twice kv it would be a lot noisier.
I have option to use 70kv motor and I tend to use it with 8M belt over 420 sprocket. The problem is that rear pulley has to be over 100teeth with 22'' diameter (17'' mc wheel) wheel taking into account that front pulley is 22teeth. And pulleys are scarce and expensive due to their unpopularity. I believe things might change if we are lucky but it's not up to us. Masses control a market. QS is manufacturing pulleys with 103 teeth but they are for 12'' scooter rims, with flanges.
In recent few years, I found the only one used Zero rear 130teeth pulley which cost over 100eu. That's how popular rear pulleys are in second-hand market.
Overclocker   10 kW
Post by Overclocker » Mar 18 2018 10:30am
should be welding soon. i modified the design yet again :lol:
motor's gonna bolt onto that plate. chain tension adjustment by moving motor forward/back. greatly simplifies the rear axle parts
swingarm-mounted motor also eliminates chain growth issues
minde28383   1 kW
Post by minde28383 » Mar 18 2018 10:43am
how much you pay (in usd or euros) for your rear hub? Can I see it for sale on some web shop?
Overclocker   10 kW
Post by Overclocker » Mar 18 2018 11:04am
minde28383 wrote:
Mar 18 2018 10:43am
it's an aftermarket hub for a certain 150cc motorcycle. i purchased it from a local shop, not online
minde28383   1 kW
Post by minde28383 » Mar 18 2018 4:23pm
I see, but how much you paid for it?
Overclocker   10 kW
Post by Overclocker » Mar 18 2018 8:49pm
minde28383 wrote:
Mar 18 2018 4:23pm
probably something like us$25
Overclocker   10 kW
Post by Overclocker » Mar 30 2018 10:08pm
skeetab5780 wrote:
Mar 30 2018 8:44am
Nice fab skills man, looking really nice
i'm getting concerned about the strength of my motor mounting plate. it's 2.8mm mild steel. you think it'll hold up?
i think you had you had issues w/ bending your motor mounts in one of your vids
skeetab5780   10 MW
Post by skeetab5780 » Mar 31 2018 7:10am
Ehh its a bit thin now that I notice there are slots cut in it, at first glance I figured it would hold up. Maybe double it up or add some bracing underneath if you see it flex
I bent the aluminum mounts on the motor itself because they weren't completely seated on a steel surface. The bike also weighed a ton
Swing is looking really nice, how do you adjust the rear wheel/chain slack?
Overclocker   10 kW
Post by Overclocker » Mar 31 2018 10:21am
i'll add some gussets to stiffen it up
the motor can slide forward/back to adjust chain tension. i probably have to torque those bolts really hard though to keep the motor from "creeping"
