New build, BHT mid-drive "direct", custom frame
trazor   100 W
Re: New build, BHT mid-drive "direct", custom frame
Post by trazor » Jan 15 2019 12:25am
Great progress! I'm curious about which method you use to bend tubes.
And the tube notching is perfect how you did it?
Overclocker   10 kW
Post by Overclocker » Jan 16 2019 9:36am
trazor wrote:
Jan 15 2019 12:25am
there's a machine shop very close to my house about 1 block away. i just print an actual size template of the bends and he does them on the steel pipe using a manual pipe bender w/ roller die. i'll try to get a pic
as for notching i have an earlier post about this. just print out the template on sticker paper
Overclocker wrote:
Dec 23 2018 3:23am
http://cq.cx/tubejoin.pl
finally the holidays, i think i'll have some time to work on this
trazor   100 W
Post by trazor » Jan 17 2019 12:38pm
Overclocker wrote:
Jan 16 2019 9:36am
trazor wrote:
Jan 15 2019 12:25am
Overclocker wrote:
Dec 23 2018 3:23am
I use the sticker method with an angle grinder but neved reached the level of precision you show in your pictures. I usually have a 1mm gap in some places.
Overclocker   10 kW
Post by Overclocker » Jan 18 2019 10:15am
this is actually my first time to notch so i'm surprised that it worked as well as it did :lol:
maybe you just have to compensate for the thickness of the pipe. the template generated is really for a theoretical zero-thickness pipe.
"footpegs". cheap VP Components pedals hoping they break off in a crash and not damage the frame :lol:
Grantmac   1 kW
Post by Grantmac » Jan 18 2019 2:36pm
trazor wrote:
Jan 17 2019 12:38pm
Overclocker wrote:
Jan 16 2019 9:36am
trazor wrote:
Jan 15 2019 12:25am
Overclocker wrote:
Dec 23 2018 3:23am
It's much easier with a die-grinder or rotary tool. Tough to get right with and angle grinder.
madin88   100 MW
Post by madin88 » Jan 28 2019 5:27am
nice work :thumb:
As a small hint in terms of form stability of the frame, i would weld something like the "X" as done on LMX frames near the head tube to make it stiffer.
And i also would weld another tube between motor and battery to have upper and lower tubes connected.
Overclocker   10 kW
Post by Overclocker » Jan 28 2019 11:35am
madin88 wrote:
Jan 28 2019 5:27am
nice work :thumb:
thanks. yes definitely going to add bracing and gussets
i actually have 2 separate battery packs in there w/ some space in between. so i'll slip some flat bars in between (GREEN LINES)
i'll also gusset the crossmembers off the upper shock mount
as for the RED LINE i'm still thinking about it... it's probably not needed? what do you think?
skeetab5780   10 MW
Post by skeetab5780 » Jan 28 2019 11:58am
Overclocker wrote:
Jan 28 2019 11:35am
madin88 wrote:
Jan 28 2019 5:27am
nice work :thumb:
Looking sweet! Sometimes quality takes time!
Chambers   10 mW
Post by Chambers » Feb 03 2019 2:58am
Awesome build!
Apologies if I missed it, Is the whole frame water pipe? Or just the head-tube?
If not what tubing have you used?
Thanks
Overclocker   10 kW
Post by Overclocker » Feb 03 2019 5:47am
Chambers wrote:
Feb 03 2019 2:58am
Awesome build!
Thanks
head tube is galvanized water pipe :lol: but dipped in hydrochloric acid to remove the zinc (not good to weld zinc)
the smaller tubes are 1/2" nominal ERW. actual OD about 20.8mm. wall thickness about 1.8mm
Chambers   10 mW
Post by Chambers » Feb 05 2019 3:15am
Should be plenty strong mate - I was just curious :thumb:
Overclocker   10 kW
Post by Overclocker » Feb 05 2019 3:49am
Chambers wrote:
Feb 05 2019 3:15am
you really think so? because i really don't have an idea :lol:
Chambers   10 mW
Post by Chambers » Feb 05 2019 4:39am
Definitely do the head tube bracing (I would probably do it out of plate instead of tube myself) and a couple of other cross braces for triangulation
- I would use tube for this not flat bar as flat bar is only strong in one direction.
1.8mm wall is heaps. 1.2 would probably be fine.
Keep it up it's a cool project.
madin88   100 MW
Post by madin88 » Feb 05 2019 7:57am
Overclocker wrote:
Jan 28 2019 11:35am
The red tube shows what i meant as second, but i also think if you weld the green tubes it should not be that important anymore.
minde28383   1 kW
Post by minde28383 » Feb 05 2019 9:08am
Chambers wrote:
Feb 05 2019 4:39am
1.2mm would be on too thin side. Especially at placed were next to weld. Pipes are structural steel.
I use 1.5mm ant it's on very thin side.
2mm or 1.8mm is better.
It's easier to work with 2mm, 2.5mm or 3mm compared with thinner.
Of course thickness has additional weight.
ebike build in progress
CN 5.5kw scooter (on sale)
E Mindless Maverick Talisman longboard, 2.2KW motor, 150Amps controller (on sale)
Overclocker   10 kW
Post by Overclocker » Feb 05 2019 10:54am
i picked 1.8mm wall thickness because thinner is very difficult to weld w/ my 0.9mm fluxcore wire, at least w/ the machine i have. anyway i just picked up a co2 tank. let's see if i could weld 1.3mm wall w/ MIG. i could probably get away w/ using thinner wall for the saddle bracket
in other news, my crappy DNM shock Decided Not to Move :lol: had to do a schrader valve mod to pump it up again
Sean9002   1 kW
Post by Sean9002 » Feb 05 2019 4:29pm
Was the DNM rear shock over pressurised? Ive had that on an RCP2. All the others seem to be spot on.
OSET 20+ - Custom frame and swingarm, Motorims - 66V
Ruff Cycles Porucho - MXUS 3000w - whitewalls - Gloss black/Pearl blue/copper leaf - custom tanks - bobber saddle
Giant Glory 00 - Clyte X5404 - Hubsinks - 18FET Sinewave
Fuji Nevada S - MXUS 35mm- Hubsinks - 12FET Sinewave
39inch longboard Dual 50mm, 12s lipo
trazor   100 W
Post by trazor » Feb 06 2019 12:28am
Overclocker wrote:
Feb 05 2019 10:54am
Oh please do a guide/video on that mod. There is one in russian that I don't understand anything and skips lot of steps. We need the definitive guide to mod the RCP2 with schrader valve. I know it is a PITA to disassemble it again but.... it is for the community :)
As a side note.. I use 2mm 5/8in structural steel pipe on my bikes. I beat them a lot and didn't have any damage on the frames. (I damaged forks, handlebars, sprockets, controllers, but not the frames :lol: )
Overclocker   10 kW
Post by Overclocker » Feb 06 2019 3:33am
Sean9002, i think it lost pressure, which kept the rebound needle from backing off the orifice, thus the super slow rebound. full diagnosis soon
trazor, sure. actually i haven't filled it w/ oil yet, that's the messy part. will make a video soon. btw what's your complete frame weight without shock and accessories?
trazor   100 W
Post by trazor » Feb 06 2019 3:59am
Overclocker wrote:
Feb 06 2019 3:33am
Great!
Unfortunately I've not weighted my frames (v1 and v2). I'm planning to paint them soon and that is a good opportunity to weight them. I will update OpenEmoto thread when I have the numbers and of course pictures of the paintjob.
The numbers I've now is v1 with 720Wh battery: 40KG, v2 with 100Wh battery 50KG. v2 is taller, longer and the headtube is machined and thick instead of 1 1/2 inch tubing (v1 uses standard headset and v2 uses semi integrated)
Keep going! you have made great progress in the last weeks.
