I've read the last 20 pages or so of this thread and I'm more and more interested in this drive for my next build. ATM, I only have a few questions, maybe I missed the answer, or maybe it's in the 165 pages I didn't read
I'm planning to buy a 48V version with VLCD6, because I'm looking for a small a display, and I don't need a throttle. I will use brake sensors which I believe I can add afterwards, even with the 6pin connector coming with the VLCD6 version of the drive (even if it requires splicing, no problemo). I will also install a temp sensor, because I want to make sure I won't cook the motor. But to make my choice, I need to understand a few things:
Can the VLCD6 (controller flashed with OS firmware from qmarco) display the temp info ?
How is the temperature information used ? Be it in the KT-LCD3 or in the VLCD6 if it can display it.
I mean, can I set a max temp (with reduced power once attained) or is it just a indicator (and I do have to manually manage the heat by reducing the use of the drive) ?
