Thanks for your help, that helped me diagnose the issue.Waynemarlow wrote: ↑Jan 09 2020 7:35pmSet your display up to show motor watts, it’s surprising how much the motor will input in without you really being aware.
I think the heat and cool was to extract the bearing for the one way clutch. Heating and cooling is normally used for freeing stuck items rather than inserting them togetherWaynemarlow wrote: ↑Jan 07 2020 2:44pmSome way back in the thread someone suggested the old trick of heating the case lightly and cooling the shaft, went looking for it but can’t seem to find it, or did I imagine this ? Anybody tried this ?maximusdm wrote: ↑Jan 07 2020 4:18amThanks for the info. Things are clearer now.casainho wrote: ↑Jan 06 2020 8:47amSee here: https://github.com/OpenSource-EBike-fir ... que_sensor
What I still do not know is how did the others press in the torque sensor while the inner ring is pressed by the small springs towards it. A lot of people worked on the sensor and I assume there are some ideas.
I have the exact same issue whilst enjoying this wonderful UK winter.Waynemarlow wrote: ↑Jan 10 2020 10:45amHi, we are having real problems with downed motors, well not really drowned but we are having probably the worst winter for mud and deep muddles that I can remember and the motors are having to put up with some real adverse conditions. Never the less we are two motors down with the same symptoms.
Symptoms are the motor starts to cut out after being through a deep puddle, the display still works and using the maintenance display, the torque sensor is still doing its stuff. The throttle also no longer works. The battery is not the problem as changing the battery doesn't solve it. You can turn the display off and then back on and it will reactivate the unit for a short period of time but within a few minutes the whole unit fails again. We've tried disconnecting the throttle and that's not the cause.
These units have been reliable in the dry but in the adverse conditions we're having there is a problem. Have any of you had similar problems ?
Speed sensor, will the unit operate if the speed sensor fails ( water and mud covered ) or does it perhaps time out if the sensor doesn't pick up a pulse ?
Any ideas would be appreciated.
Dielectric grease (silicone-based grease) can be used for this, it's commonly used on automotive connectors like spark plug boots. Much better than using silicone sealant or other permanent solutions as the connectors can be easily unplugged again.devboy-greg wrote: ↑Jan 10 2020 1:57pmIf I hadn’t had the motor apart I would probably have tried improving the 6 pin connector weatherproofing with silicon and waterproof tape after drying thoroughly.
Yes, I checked that cranks were ok. Then I could see on the square for that the axle is not aligned.Elinx wrote: ↑Jan 11 2020 5:54pmIf I read sucure the cranks were changed for new ones. If the axle is twisted, I asked myself how this could be possible with mass production. If that is true, than there must be {a lot} more faulty motors and a bad quality check.
Same for the cranks, but imho there is more chance they could be different because left/right are seperated parts. I hope it can be easy solved.
The inverted connectors (motor side female) are good because there are 8-pin to Bafang 5-pin adapter cables available in many configurations.
If I disconnect the brown cable, the display it's self works correctly._g_ wrote: ↑Jan 04 2020 11:03amNot sure if better here or own thread, but...
My VLCD5 just shows all elements on; ie 88.8, 888.8 all graphs and other elements full.
It does this as soon as I plug it in, without pressing any buttons
Does anyone why and how it can be fixed? Ideally I'd like to use it tomorrow.
I got this motor with a XH18.
I've put the XH18 on the bike the VLCD5 came from and leant it to a friend (my plan was always to have that display on that bike, keeping it compact).
I was hoping to flash the firmware and use the 850C display I got for the purpose. However going to do it today, I realised I hadn't clicked that the USBUART and STLinkV2 were different items - so I've only got the STLinkV2 and will need to order the other.
The cable from the VLCD5 had previously been broken, so I had used the plug end of that to attach to the 850C, which is now soldered up.
I've just wired up the spare plug end from the other cable I had to the VLCD5, keeping the colours consistent.
I could flash the motor firmrware today, but not the 850C display - I'm presuming that won't help me get it to work with either display.
Thanks - easing does not seem to be workingdevboy-greg wrote: ↑Jan 12 2020 7:32amIn the repair manual (available here) they use a gear puller.
From my own personal experience I have always been able to gently ease it out by hand, Jbalat shows it in his video to replace the sprag clutch:
Nite that there is the torque sensor under the main gear... You should not apply force to torque sensor but only to main gear, that always works for me and I only need two screendrivers to pull gently and apply the force on side only of main gear.Mike-P wrote: ↑Jan 12 2020 8:49amThanks - easing does not seem to be workingdevboy-greg wrote: ↑Jan 12 2020 7:32amIn the repair manual (available here) they use a gear puller.
From my own personal experience I have always been able to gently ease it out by hand, Jbalat shows it in his video to replace the sprag clutch:![]()
I am being happy with my motors on rainy days, riding like 4h under rain and a lot of mud -- but yes, I understand you have much more of this than meWaynemarlow wrote: ↑Jan 12 2020 11:21amOnce water is in that section then there is an open hole just beside the torque sensor wire + the opening of the torque sensor wire itself which are all unsealed, which can let water down into the controller and motor cavity.
