eyebyesickle   10 kW
Post by eyebyesickle » Apr 10 2018 7:19pm
John and Cecil wrote:
Apr 10 2018 7:11pm
Maybe it does support a throttle, a seller on aliexpress has an entire package including motor and throttle and vlcd6 (but no brake handles)...
Yes, even when 'hard wiring' a throttle with the xh18 display, the brake signal actually interferes with the motor/display functions... so thats a thing... beware also, the 'hard, or forced' wiring of a throttle from an 8 pin controller, to a 6 pin display can cause your controller to burn up... as I mentioned above
www.eco-ebike.com - USA Stock + Support
www.recycles-ebike.com - Manufacturer/Direct w/ USA Support
gggplaya   100 mW
Post by gggplaya » Apr 10 2018 8:04pm
Minivelorider wrote:
Apr 10 2018 4:27pm
asterduc wrote:
Mar 29 2018 1:19am
Mar 28 2018 1:54pm
Maybe there are different stock chainrings.
I didn't yet realize, but my bikes have 1/8" chain.
The TSDZ2 chainring is most probably designed for 3/32" chain.
I just checked and yes, the TSDZ2 front 42T is definitely for 3/32”. I tried it with a short length of 3/32” first:
Given that the TSDZ2 has a 50.2mm chainline, and my rear sprocket on my Sturmey Archer X-RF8(W) hub is about 43mm, I’m wondering if a 6-7-8 speed 3/32” chain is actually more “flexible” sideways than an 1/8” chain. (I read somewhere online that advances are being made on derailleur chains, and not on single-speed chains.)
So I switched my S-A rear sprocket from 1/8” to 3/32” (saved 10 grams!) and chain too (saved 46 grams!).
Summary: it seems to work fine, no perceptable difference.
Chain's aren't too expensive, but it sucks when you're out in the middle of nowhere and it breaks. I bought the strongest rated 3/32 chain I could find. These are for single speed BMW and Fixie track bikes, so they don't have the provisions for shifting on a derailleur, but that makes them stronger because the side plates are thicker. I use this since I also have an internally geared hub (Nuvinci N380) which has a max sprocket size of 3/32. http://kmcchain.us/chaintype/heavy-duty-series/
amberwolf   100 GW
Post by amberwolf » Apr 10 2018 11:16pm
IIRC, at least originally, these kits had to be ordered with a throttle, and one coudlnt' be added afterward. If that's true of the new LCD version as well, then the ones offered with a throttle may be the only ones that support one.
Something to think about and check on.
amberwolf   100 GW
Post by amberwolf » Apr 10 2018 11:20pm
gggplaya wrote:
Apr 10 2018 8:04pm
If you file, grind, or machine the inner circumference of a thicker sprocket so it's no thicker than that, you could use any thickness you like, and thus any chain type. ;)
You could even modify a belt sprocket to fit it, though that might take more effort.
Mantsos   10 mW
Post by Mantsos » Apr 11 2018 2:50am
My wife is going to buy that TSDZ2 motor (version 48v 500w) and I have currently one extra battery 48v 14.5ah so can she use that 48v 14.5ah battery with that TSDZ2 motor? Or does she have to buy some other battery?
gggplaya   100 mW
Post by gggplaya » Apr 11 2018 5:48am
Mantsos wrote:
Apr 11 2018 2:50am
Should work just fine.
tomjasz   1.21 GW
1.21 GW
Post by tomjasz » Apr 11 2018 10:28pm
casainho wrote:
Apr 09 2018 4:36pm
tomjasz wrote:
Apr 09 2018 4:22pm
casainho wrote:
Apr 09 2018 3:25pm
Sorry, don't know what you mean.
Are you saying they will sell the BB part and no need for the rest?
https://bmsbattery.com/ebike-kit/689-b- ... e-kit.html
See here one e-mail that I sent and the answer:
Safari won’t open...
tomjasz   1.21 GW
1.21 GW
Post by tomjasz » Apr 11 2018 10:34pm
amberwolf wrote:
Apr 10 2018 11:16pm
When i ordered mine it was sent without throttle or brake cut off features. I had to order another controller. That one came with only brake cut offs, the third came with brake cut offs and a throttle connection. A couple of dealers suggeste the first version i recieved was the most reliable. Growing pains I guess. Seems that eyebicycle (sp?) is the most reliable source, over factory direct.
John and Cecil   1 kW
Post by John and Cecil » Apr 12 2018 12:13pm
Does anyone know if the 48v motor can run on a 12s battery configuration? Someone mentioned lowes sells inexpensive 6s tool batteries that can be brought on a plane, I would like to wire two together to make a 12s battery. I am not sure if the low power cutoff for the motor will kick in too early though.
eyebyesickle   10 kW
Post by eyebyesickle » Apr 12 2018 12:43pm
tomjasz wrote:
Apr 11 2018 10:34pm
amberwolf wrote:
Apr 10 2018 11:16pm
Thanks, yeah I did considerable testing and experimenting with these, after experiencing the same types of issues when I first started playing with these...
Soon I'll have a little article drafted outlining some of the important info for the TSDZ2... Including wiring/pinout for the 8 pin.
eyebyesickle   10 kW
Post by eyebyesickle » Apr 12 2018 12:47pm
Apr 12 2018 12:13pm
LVC for the 48v systems is set at 39v, so this will work with a 12s, but you won't completely drain the 12s, which isn't the worst thing, especially if you have a bunch enough battery to achieve desired range before the LVC
John and Cecil   1 kW
Post by John and Cecil » Apr 12 2018 1:10pm
eyebyesickle wrote:
Apr 12 2018 12:47pm
I guess a 44v 12s battery normally drains to about 36v? I know my 52v gets down to about 44v before it loses most of it's power.
I cannot win! I can't use the top 3v of the 52v battery and I cant use the bottom 3v of the 44v battery. But at least the 2 6s batteries can go on the plane, it will be nice to be able to sit outside the airport and assemble the bike and actually have power to ride away :) Thank you.
I wonder if the programming software will be able to change the 39v to a lower number...
casainho   100 MW
Post by casainho » Apr 12 2018 1:16pm
Apr 12 2018 1:10pm
eyebyesickle wrote:
Apr 12 2018 12:47pm
We know the controller is the same for 36V up to 52V battery -- we just can't configure the original firmware for our custom voltages, only the factory can do it because they own amd have the original firmware. This will change soon, as I should receive my motor and I will develop from scratch our Flexible OpenSource firmware and then anyone will be able to select any custom voltage that the hardware supports. If I get help from community, I will develop it even faster, I will need users to test the different voltages, etc.
Developer of the Flexible OpenSource firmware for EBike motor controllers (TSDZ2 and KT) and LCDs (KT-LCD3 and Bafang 850C color LCD).
If you like my work, you can consider making a donation. I am being using the donations to buy needed resources for my developments. My paypal: casainho AT gmail.com.
John and Cecil   1 kW
Post by John and Cecil » Apr 12 2018 2:16pm
I am sure you will have many volunteers to try the firmware upgrades here! :)
jbalat   10 kW
Post by jbalat » Apr 12 2018 7:27pm
yep would love to run 11s on my 36v !!!
Please subscribe to my Youtube home page for Quadcopters, FPV and Bike Rides http://www.youtube.com/jbalatutube
My build log here http://endless-sphere.com/forums/viewto ... =6&t=55352
For some cool ebike talk join us on The Best ebike https://www.facebook.com/groups/193581737807033/
Tech talk TSDZ2 Opensource firmware viewtopic.php?f=30&t=93818&start=150
AWD   100 W
Post by AWD » Apr 12 2018 9:33pm
casainho wrote:
Apr 12 2018 1:16pm
Just let us know what you need. Thanks for your efforts btw!
We are working on the TS bugs here also. I feel it is well worth the effort to fine tune a torque sensing mid drive that is adaptable and relatively inexpensive. The ability to program the controller is all that is really missing. Other than an octalink type bb spindle and an offset chainring.
I feel as time goes on the industry push towards integrated batteries and motors requiring special frames will keep becoming more popular. But if one is keen on keeping up with technology advances as they occur an open source kit type system is the way to go. But I am not telling you guys anything you don't know.
casainho   100 MW
Post by casainho » Apr 12 2018 11:22pm
AWD wrote:
Apr 12 2018 9:33pm
casainho wrote:
Apr 12 2018 1:16pm
For now I need high resolution pictures of inside of the motor controler.
wheex   1 mW
Post by wheex » Apr 13 2018 3:47am
Tomorrow I can take photos from a 48V controller, I 'm struggling to open the unit because I ruined the four screws head that hold the case.
casainho   100 MW
Post by casainho » Apr 13 2018 3:55am
wheex wrote:
Apr 13 2018 3:47am
Thanks!!! Please try to take them in a way that we can see the reference of the 2 big ICs, one shoild be the microcontroller STM8S105xx and the other should be the driver for the power mosfets (no one knows yet which IC is this one).
mscoot   1 W
1 W
Post by mscoot » Apr 13 2018 5:51am
jbalat wrote:
Apr 12 2018 7:27pm
Do you need a firmware update for that? I can run 11s on my 36v. I've tried it and it works: slightly more power at a slightly higher cadence. Once my current 10s battery dies, I'll be replacing it with an 11s.
casainho   100 MW
Post by casainho » Apr 13 2018 5:59am
AWD wrote:
Apr 12 2018 9:33pm
Yeah!! We also need DIY options and also "cheap"/accessible. And we need to cooperate and help ourselves, since this "cheap"/accessible DIY kits business model is different -- we can't expect to pay cheap for the parts and have a good support from the seller, good documentation, a lot of marketing material like selling videos, etc.
John and Cecil   1 kW
Post by John and Cecil » Apr 13 2018 9:23am
Yeah I agree, we definitely need diy options. Most manufactured e-bikes are ridiculously overpriced (gouging) or they are made with crap components. Before I built my Raleigh kodiak bike I considered Raleigh's electric kodiak model. It is priced at 4k and it has a nice bosch mid drive but it is only a 250w motor. Mine was $1000 so far but with only a 2ah battery and a 750w motor. Their electric bike has better components and a larger battery, however I seriously doubt it costs them over $1500-2000 to manufacture one so it has a $2000-2500 markup fee.
There is too much junk in the world, and it all ends up going into landfills. We need to reuse what we already have, and we need to repair rather than replace. That is what I like about this motor (and the Bafang mid drives), the parts are replaceable and it is simple to work on so it will hopefully last a long time.
casainho   100 MW
Post by casainho » Apr 13 2018 10:10am
Apr 13 2018 9:23am
That is also my motivation!! And with our own firmware, we will need to go further, to reuse a battery pack we already have but have 1 or 2 more cells comparing to the standard 36v battery, etc. Add a throttle to a controller model that doesn't support it, etc.
John and Cecil   1 kW
Post by John and Cecil » Apr 13 2018 10:15am
casainho wrote:
Apr 13 2018 10:10am
I agree, I really wanted this motor but because of the firmware I almost went with the BBS02 because of the programming function. Being able to adjust firmware settings is almost a necessity. :)
eyebyesickle   10 kW
Post by eyebyesickle » Apr 13 2018 11:13am
Here, I dug up some older pics I had of the controllers... I can label the wires if you need, but I think more than that you will probably need better pics :oops: haha. Let me know I have some controllers sitting around I can snap some better pics if able... Maybe circle the areas you really need clearer, and I will focus on those specific components etc... Just let me know!
8 pin controller:
https://drive.google.com/open?id=1eXOho ... bf8k-T4cRS
6 pin controller:
https://drive.google.com/open?id=1LAtOL ... Gi4RCXARKJ
