BBS02 whistle noise
frotna   1 µW
BBS02 whistle noise
Post by frotna » Aug 14 2016 10:50am
Greetings.
I recently assembled bbs02 500w 36V motor on my bike.
At the end of first test ride which was around 10 km i noticed strange whistle like sound from motor.
Sound is there only when turning pedals. While using motor on throttle there is no strange sound.
Sound is present even when the motor is turned off. It is definitely coming from motor, i think from pedal axle part of it.
Motor works fine, there is no heat problem or other problems whatsoever just that strange noise.
I removed motor from bike and noise disapered and after i returned it to bike gradualy the whistle noise returned.
Can someone give some advice what can be the reason of this strange noise.
Here is the vid of the noise:
https://youtu.be/0VaZFoNv-RY
Regards...
tahustvedt   10 kW
Re: BBS02 whistle noise
Post by tahustvedt » Aug 14 2016 10:55am
Looks like the motor is pbeing pulled around when you spin the gear manually. My guess is the motor freewheel is stuck, and that the problem is not in the pedal axle or pedal freewheel. The pedal axle doesn't even move in your video.
frotna   1 µW
Post by frotna » Aug 14 2016 12:04pm
tahustvedt wrote:Looks like the motor is pbeing pulled around when you spin the gear manually. My guess is the motor freewheel is stuck, and that the problem is not in the pedal axle or pedal freewheel. The pedal axle doesn't even move in your video.
Hi.
Tenx for quick replay.
As you pointed, definitely the problem isn't pedal axle as it isn't moving.
Also i have to add that the strange noise is there only when i rotate slowly. When i rotate pedals faster there is no noise.
What part of the motor i have to disassemble to get to the freewheel part?
Do you think it's something serious or can i continue to drive like that?
Regards...
alfantastic   10 kW
Post by alfantastic » Aug 14 2016 5:33pm
I don't think you've got a big problem there. Remember, these units are not machined to the highest of standards, so some parts might be a little bit out of spec.
I think the large cog is rubbing slightly on the rear of the housing. Try applying some more grease to the final drive and see if the noise disappears.
FYI, I use a syringe to inject as much grease into the final drive and mine is very quiet and working very well.
frotna   1 µW
Post by frotna » Aug 15 2016 12:20am
alfantastic wrote:I don't think you've got a big problem there. Remember, these units are not machined to the highest of standards, so some parts might be a little bit out of spec.
Hi.
I have injected grease around large and small cogs before i mounted motor on bike and once more after noise appeared and unfortunately that didn't help.
Regards...
alfantastic   10 kW
Post by alfantastic » Aug 15 2016 4:34am
Personally, if everything is working as it should and you are ok with the noise, then I would just leave it.
I used to get a similar noise after riding for around 15 miles, but think it was the silicon seal, on the non drive side, slightly rubbing on the BB housing.
A squirt of silicon spray into the area marked in red on the picture, would cure that noise for a few hundred miles.
Bafang BB.jpg (83.35 KiB) Viewed 862 times
frotna   1 µW
Post by frotna » Aug 16 2016 1:01pm
alfantastic wrote:Personally, if everything is working as it should and you are ok with the noise, then I would just leave it.
I checked and lubricate silicone seal on non drive side but noise isn't coming from that side for sure. I drove bike last few days and noise is sometimes present and sometimes not.
Will continue to monitor it and report back after few more days...
