Mini Cyclone on carbon full suspension
StinkyGoalieGuy   100 W
Re: Mini Cyclone on carbon full suspension
Post by StinkyGoalieGuy » Oct 20 2016 11:00am
DingusMcGee wrote:For steep hill climbing while Mt biking[? does it even exist?] the standing rider tries for such a [standing] position where he still gets traction but he needs all the pedal force he can muster. A little bit of wheel spinning and you are out of momentum.
On the really steep stuff, as soon as I come out of the saddle, it's all over. You can't maintain as smooth of a cadence as when you are seated, so you break traction when you start pumping your legs. I find the best technique for MTB is butt on the saddle slide forward as necessary, lean over the front bars to keep the front end down and loaded so that your steering still has some effect.
jk1   1 kW
Post by jk1 » Jan 15 2017 7:53pm
Elementary how is that fatbike C3000w going awesome build
is it only single track or can you ride on more dirt bike type offroad terrain ? the C3000w would seem to have enough torque as a mid. but does it have enough grip.
elementary   10 W
Post by elementary » Jan 30 2017 5:32pm
I now have three Cyclone 3000w fatties and they offer such a significant performance improvement over BBS-HD machines that I mostly ride are Cyclones. There is plenty of snow here and the Cyclone 3000w linked to Vee Rubber STUDDED SNO TIRES tires have shown amazing capabilities plowing though knee deep snow.
*I can recommend the nickel plate 1/2 link primary chain as it runs quieter than full link chains and appears to be more rust resistant.
* In addition, the KMC chain with the rust resistant coating KMC is promoting is holding much much better than normal chain would in the wet and snowy conditions
* I has proven necessary to install a larger 203mm real disc brake to give the added stopping power and the ability to abruptly lock up the rear wheel for skidding thru corners
* The single best improvement was swapping the brake controllers so the left hand controlled the rear brake... this allows much better and quicker throttle controller
* I am using a Luna twist throttles from BBS-HD that are modified for zero free play... this lets the motor spin a little while moving and eliminates some of the drive line shock
XM full suspension carbon with Cyclone 300w
XM full suspension, 3000w, 203mm disc, 1/2 link primary, Vee SNO, studded, Fat Club Carbon Wheels
Alex07   100 W
Post by Alex07 » Jan 31 2017 3:28pm
Yeah i have heard many people say the same thing the BBSHD is wimpy compared to the C3000w, Are you considering running your C3000w with more power at 72v like others have done ?
elementary   10 W
Post by elementary » May 17 2017 6:02pm
Ecarbon now with CA3...
YouTube Video shows a short trail ride... Max speed 21mph, avg speed 12mph, 40amps with 20 hobbyking 10ahr lipo...
Bike now easier to ride in the woods when CA3 throttle is set to .25 volts per second https://youtu.be/ggfEeStGSRM
BeachRider2016   100 W
Post by BeachRider2016 » May 21 2017 8:48pm
Which carbon frame did you use ? That looks like a generic full suspension on Ebay going for $899.
Fat bike full suspension frame is crazily expensive for some weird reasons over mtn bike.
elementary   10 W
Post by elementary » May 26 2017 8:27am
My frames are XM Carbon... I have two with cyclone 3000w running 20 cells which is 84 volts fully charged. At that voltage they were hard to control on tight trails but the CA3 helps... But at 52v 14s they are easy to control
Hobbyking lipo's can easily provide 60 amps continuous..http://www.xmcarbonspeed.com/Productinfo.asp?f=1402 I
Post by BeachRider2016 » May 30 2017 8:02am
If you dont mind, how much did you get them for ?
zackclark70   100 W
Post by zackclark70 » Jul 01 2017 6:35am
why all the hate on cyclone motors i have done over 70,000 miles with cyclone motors over the last 10 years only killed 1 motor by cracking the case on a rock never burned one out very few over heat problems and no over heat problems since i rewound it and added better bearings cyclone motors are awesome if you use the right gear and dont push them over what they can take 25mph is not a problem for a 1680w kit go over that with a standard kit and you will start to have issues rewind and add better bearings and 2000w /30mph is not a problem what people need to realize is that these motors are only really a 1000w motor without mods
recumpence   100 GW
Location: On Earth right now. That can change at any time, though..........
Post by recumpence » Jul 01 2017 9:15am
zackclark70 wrote:why all the hate on cyclone motors i have done over 70,000 miles with cyclone motors over the last 10 years only killed 1 motor by cracking the case on a rock never burned one out very few over heat problems and no over heat problems since i rewound it and added better bearings cyclone motors are awesome if you use the right gear and dont push them over what they can take 25mph is not a problem for a 1680w kit go over that with a standard kit and you will start to have issues rewind and add better bearings and 2000w /30mph is not a problem what people need to realize is that these motors are only really a 1000w motor without mods
Noisey, overheating, poor bearings, the list goes on.......
1% of the world's population can think "Outside the box". The rest are firmly stuck within the box. Where are you?
zackclark70   100 W
Post by zackclark70 » Jul 01 2017 10:16am
overheating is mostly people running them in the wrong rpm range with high phase amps
ok bearings are fairly cheap
noise can be toned down alot ( new bearings stop the gears wearing out so fast and keep the noise down for longer )
the problems most people have are because they are running the motors in a way that is not optimal they are really good motors if you treat them right hub motors will always be quiet compared to any chain drive but they have so many downsides it makes them the worse choice really
recumpence   100 GW
Post by recumpence » Jul 01 2017 10:18am
I never promoted hub motors. I agree, hub motors are a poor choice.
zackclark70   100 W
Post by zackclark70 » Jul 01 2017 10:30am
if we all had the money we would probably be running some kind of belt driven rc setup but unfortunately money is a consideration for most people so we weigh up the pros and cons of all the options in our price range and pick what we think will be best for out needs
my long term goal is to build a mid drive motor from the ground up as nobody has made a motor just for ebikes
fcbrants   1 mW
Post by fcbrants » Jul 06 2017 12:12pm
:?: Elementary,
Having built 15 eBikes, I'm hoping you've encountered (and hopefully solved) a problem I'm having:
I'm trying to mount the Cyclone kit on this bike:
https://www.scott-sports.com/us/en/prod ... k-960-Bike
...which has this BB:
Shimano BB-MT500-PA / shell 41x89.5mm
This is my first build.
I believe I need to find a Threaded PF41 to BSA adapter to mount the LunaCycle Cyclone 3000 kit (https://lunacycle.com/cyclone-mid-drive ... etary-kit/), but I have been unable to find / recognize such an adapter.
Any suggestions?
Thanks!!
Franko
elementary wrote:
Having built 15 ebikes over 5 years...
Older pictures of the 3000 bracket and eCarbon
robocam   10 kW
Post by robocam » Jul 06 2017 1:53pm
Do you already have this bike? I would find a bike with a different bottom bracket if you don't already own it.
I ran into a similar issue when I was trying to mount a mid drive onto my Trek HiFi Pro 29 which has a similar bottom bracket. What I did was I bought an FSA BB30 to BSA adapter, removed 1mm from the outer diameter (rotary tool with a tungsten carbide tip, Dremel 9901 - I mounted the adapter to a bottom bracket spindle and spun it around until the rotary tool shaved the adapter to 41mm), shaved the bottom bracket shell until it was 68mm wide (with a rotary tool and a cutoff wheel), and then pressed in the adapter (with a hammer).
https://endless-sphere.com/forums/viewt ... 1#p1230611
Here's the adapter I used.
https://www.amazon.com/FSA-BB30-to-BSA- ... B004N99NG6
As you can see, BB30 is 42mm while BB92 is 41mm, so that's why 1mm has to be removed from the adapter.
fcbrants wrote:...I'm trying to mount the Cyclone kit on this bike:
Shimano BB-MT500-PA / shell 41x89.5mm...
fcbrants   1 mW
Post by fcbrants » Jul 06 2017 2:52pm
Thanks Robocam!!
Yes, I already purchased the bike - did a cursory search for PF41 to BSA adapters Before I bought the bike & Thought there were tons of choices, so Thought it was Ok to get the bike.
Still keeping the bike (bought it local & had the option to return it), as I have another Scott Spark 940 with a BSA BB, so I knew I had options, plus I Really like the (patented) Scott Twin Lock system (locks front & rear suspensions with a remote, so "on the fly"), as my goal for this build was to try to maintain the best "pedal power" features possible, while adding power.
Thank you SO much for your help, I have been puzzling over this question for Hours & Hours!!
Cheers!
Franko
robocam   10 kW
Post by robocam » Jul 06 2017 3:09pm
You're welcome! Keep in mind that if you modify the bottom bracket shell, it may weaken that area depending on your bike's bottom bracket shell design. It sounds like you still want to ride it like a bike. If that's the case, you really should consider the BBSHD, especially since it might fit your frame without modifications. The Cyclone is crazy powerful, so you may not not want to pedal. The BBSHD also has a nice PAS system. I have lockouts on my shocks too, but I don't see any point in using them with a motor.
fcbrants wrote:Thanks Robocam!!
Cheers!
Franko
fcbrants   1 mW
Post by fcbrants » Jul 06 2017 5:06pm
Thanks for the heads up about the BB shell, my plan is to leave it "as stock as possible."
I looked long & hard at the BBSHD, but didn't like some of the features (integrated controller) and was advised by Paxtana on the LunaCycle Electric Bike forum that keeping multiple front chain rings would be a battle and a kludge, with no front derailleur possible:
https://electricbike.com/forum/forum/bu ... -41x89-5mm
I also was hoping to tune the gearing and power to be able to keep up with city traffic if I start using the bike for alternate transportation.
I live in a hilly area, so while pedaling (mostly for health benefits) uphill, I always lock the suspension to keep if from absorbing pedaling energy, then lock it right away for the downhill bits to soften the ride, so I use the remote constantly.
Thanks again for your help!!
Franko
robocam wrote:You're welcome! Keep in mind that if you modify the bottom bracket shell, it may weaken that area depending on your bike's bottom bracket shell design. It sounds like you still want to ride it like a bike. If that's the case, you really should consider the BBSHD, especially since it might fit your frame without modifications. The Cyclone is crazy powerful, so you may not not want to pedal. The BBSHD also has a nice PAS system. I have lockouts on my shocks too, but I don't see any point in using them with a motor.
robocam   10 kW
Post by robocam » Jul 06 2017 5:28pm
What's wrong with an integrated controller? The advantage is that it doesn't take up space on your bike. It's replaceable.
There's really no need to run multiple chainrings. In fact, a 1x setup with a narrow-wide chainring will be much better for chain retention (for any mid drive). With a 42T chainring and the motor, you can climb anything you want to. You can even add a 50T cog to the rear if you need to. Top gear will take you to about 35mph.
But there is one benefit to the Cyclone. It will give you more ground clearance.
If you don't want to cut your frame, you can use one of these adapters with a fat bike bottom bracket. But you'll likely have chainline issues that you will need to correct by moving the chainrings around using spacers.
http://www.ebay.com/itm/J-L-BB92-BB86-B ... 1825746922
I've posted a question for you over here in the Cyclone thread to see if anyone can help.
https://endless-sphere.com/forums/viewt ... 5#p1302505
As you transition to ebiking, I doubt you'll use your suspension lock anymore =)
fcbrants wrote:Thanks for the heads up about the BB shell, my plan is to leave it "as stock as possible."
Franko
fcbrants   1 mW
Post by fcbrants » Jul 07 2017 12:38am
Thanks Robocam - I did not realize the controller is replaceable.
Great info about the chainline - I was reading that it could be an issue, so I was thinking about staying with a single front chain ring.
As for ground clearance, I believe that I can cut new motor mounts & get the Cyclone up into the triangle.
And thanks for the link on the adapter, I bought one earlier today.
Lastly, thanks for posting my questions over to the Cyclone thread. I considered posting it there, but at 86 pages, I was pretty sure my question would get lost. Started my own thread, but didn't get a response.
Thanks!!
Franko
robocam wrote:What's wrong with an integrated controller? The advantage is that it doesn't take up space on your bike. It's replaceable.
fcbrants   1 mW
Post by fcbrants » Jul 07 2017 5:28pm
I believe I have this problem solved.
I contacted my local bike (machine) shop:
https://www.velogold.org/
...and they're fabricating the PF41 / PF92 / PF89.5 to BSA adapter for me.
If that goes well, then we'll move on to the custom mounting brackets that will put the Cyclone inside the triangle.
Cheers!!
Franko
fcbrants wrote::?:
gman1971   10 kW
Post by gman1971 » Jul 10 2017 10:16am
Very nice!
I wonder the same, why so much hate on Cyclone?? They make eBikes affordable without breaking the bank with gimmicky stuff that you really, don't need.... 70k miles man! Kudos to you!
I am now at 12k miles combined (in about 1 1/2 years) on x3 Cyclone 3000W motors, two with shunt-modded controllers (90A max @ 72V), even have done a fair share of 0-60 mph runs and gone through a couple of Wisconsin winters...
I agree, it can all be improved, better mount, better bearings, better windings, etc... but for 350-400 dollars shipped to your door, a bolt and run package that just works its hard to beat... sure is not stealth, it might be noisy (although all of mine did quiet down after a few thousand miles)
G.
I am all about high-speed, low-drag, mid-drives and gears...
A-1B trike, 6+kW, 65+mph (Cyclone powered): https://www.youtube.com/watch?v=oFC8MRwvgUM
A-2A trike 3kW, 50mph (Cyclone powered): https://www.youtube.com/watch?v=bNoqp0wl6Vo
eB-1C bike 3kW, 42mph (Cyclone powered): https://www.youtube.com/watch?v=_weSmz_h3Ig
Alex07   100 W
Post by Alex07 » Nov 04 2017 8:26pm
any updates? more i read the more i read this seems ultimate mid drive build ! No surprise since you did 15 other builds before so i think you figured it out what is Ultimate more than anyone else on here :)
ebike11   10 kW
Post by ebike11 » Nov 05 2017 7:39am
elementary wrote:I now have three Cyclone 3000w fatties and they offer such a significant performance improvement over BBS-HD machines that I mostly ride are Cyclones. There is plenty of snow here and the Cyclone 3000w linked to Vee Rubber STUDDED SNO TIRES tires have shown amazing capabilities plowing though knee deep snow.
Hi do you have a link to that rust coated KMC chain? Thx
stuntmanmike   100 W
Post by stuntmanmike » Nov 19 2017 1:32pm
elementary wrote:
Sep 21 2016 5:58pm
The Cyclone 3000w is NOT silent and stealthy like the BBS-HD, but it has a lot more torque... More torque than needed in the woods using 14s 16000Mahr HobbyKing Lipo 52v nomial 58.v8 charged. The highest the stock Cyclone 3000w controller pulled was 58.4 volts at 39.2 Amps.... without any modification to the shunts.
Bottomline, the BBS-HD Sniper will be ridden more because it is easier in the tight trails, but if a challenge is need the Cyclone 3000 can deliver.
Example, the fastest ride a 4" hardtail BBS-HD fattie with Bluto fork was a 8 mph average over set woods course, if pushed the BBS-HD Sniper full suspension can average about 9 - 10mph. Pushing the eCarbon full suspension with a Cyclone 3000w averaged 13 mph over the same course... something too dangerous to do again. The ride is something like an old Honda 125cc Ensenada motocross bike and a 72v Cyclone 3000w maybe impossible to ride in the woods. Never tried the Cyclone 1680w because it overheats, nor the Tangent for other reasons
-Elsinore**
