GNG Ultralight RC Mid Drive with Bluetooth control
teslanv   100 MW
Post by teslanv » Mar 13 2017 10:03am
http://www.gngebike.com/ultralight-300w-kit
I just placed an order for this little RC MId Drive that GNG just came out with.
It will be going on a very lightweight XC Bike.
I think this little drive has some potential, and looks to be a perfect fit for a brick of 6S LiPo, as the ESC is rated for 22.2V Nominal.
It's a low-power drive (About 300W, per the manufacturer) but I do intend to see how far I can push it. :)
Other reported features include Bluetooth connectivity, and a built-in cadence PAS sensor. It actually does not have any throttle, which is OK by me. KISS.
The Manufacturer lists the weight as 1.55Kg. (3.41 lbs.) or about 40% the weight of a BBS02. Weight weenies rejoice!
Looking forward to reporting back with more info soon.
DD Hubs, Batteries, Controllers & Custom Ebikes.
http://westcoastelectrics.com
West Coast Electric Cycles
Bellevue, WA
USA
spinningmagnets   100 GW
Re: GNG Ultralight RC Mid Drive with Bluetooth control
Post by spinningmagnets » Mar 13 2017 10:14am
I am curious about the diameter of the motor-shaft, and also the configuration of the interface it mates with. It "should" be fairly easy to upgrade the motor size to an 80mm. These RC motors can easily have their shafts removed, and you can buy spare shafts to modify without "ruining" the motor for other jobs. I have modified hobby King motor shafts, and I found it to be pretty easy...
https://endless-sphere.com/forums/viewt ... 60#p322332
Looks like a 50mm diameter motor. Going to even just a 63mm would be an improvement...
Santa'sLittleHelper   100 W
Post by Santa'sLittleHelper » Mar 13 2017 10:54am
Very interested in how this claimed light weight motor works out. It appears the weight they state is for the motor itself only, not including mounting hardware, sprockets, chains, BB, etc... (correct me if I'm wrong). The BaFang BBS02 contains all those other things. Please weigh it in once received.
It also comes in a triangle mounting configuration:
Can you tell where the freewheel is? Does it have a simple push button 1-5 power level control or Blue Tooth (BT) only? Kind of hard to repeatedly adjust on the fly if it is BT only.
How about the RPM and actual gear reduction numbers? It says high reduction, but I didn't see any actual numbers stated or tooth count for the motor or left crank sprockets???
Look forward to your experience with this one!
Last edited by Santa'sLittleHelper on Mar 13 2017 11:00am, edited 1 time in total.
wineboyrider   100 MW
Post by wineboyrider » Mar 13 2017 10:59am
RC controller? Hall sensors?
teslanv   100 MW
Post by teslanv » Mar 13 2017 11:02am
wineboyrider wrote:RC controller? Hall sensors?
No Halls, that I can tell. Sensorless.
Bellevue, WA
USA
bionicon   1 kW
Post by bionicon » Mar 13 2017 12:18pm
Very tempting ,I have laying arround a 1200kv 3000watt motor with controller :roll: .....maybe just have to try it :D and see how long it will stand :wink:
Joe T.   100 W
Post by Joe T. » Mar 13 2017 10:44pm
Me not being a fan of PAS I wonder how quickly the PAS stops helping once you stop pedaling. Also if it has a brake cut off option.
The weight claim: 1.55KG MID DRIVE KIT UNIT (HIGH SPEED MOTOR, BOTTOM BRACKET, ESC CONTROLLER, PAS SENSOR, bluetooth connectivity)
Not sure if it is a good fit for us power hungry Americans.
neptronix   100 GW
Post by neptronix » Mar 16 2017 4:00am
I think it would be fun as hell for a light offroad bike. Replace or shunt mod the controller and fan cool the motor and you might be seeing 400 or 500w perhaps?
I'm anxious to see who will be the guinea pig for this motor.
teslanv   100 MW
Post by teslanv » Mar 16 2017 7:34am
neptronix wrote:I think it would be fun as hell for a light offroad bike. Replace or shunt mod the controller and fan cool the motor and you might be seeing 400 or 500w perhaps?
I've got one on the way.
Bellevue, WA
USA
Ecyclist   1 kW
Post by Ecyclist » Mar 16 2017 7:53am
Look ma it's a Chinese Vivax. :lol:
Don't expect from life to be easy and then it will be.
My builds:
Avian with hypocycloidal drive https://endless-sphere.com/forums/viewt ... 2#p1318056
2016 GNG extreme drive https://endless-sphere.com/forums/viewt ... 28&t=82252
notger   100 W
Post by notger » Mar 16 2017 8:35am
spinningmagnets wrote:I am curious about the diameter of the motor-shaft, and also the configuration of the interface it mates with. It "should" be fairly easy to upgrade the motor size to an 80mm. These RC motors can easily have their shafts removed, and you can buy spare shafts to modify without "ruining" the motor for other jobs. I have modified hobby King motor shafts, and I found it to be pretty easy...
installing a bigger motor might not be a big deal, but i guess the gears in te bearbox might not handle much more than the rated ?00 watts, if so it would be nice
teslanv   100 MW
Post by teslanv » Mar 16 2017 10:00am
Ecyclist wrote:Look ma it's a Chinese Vivax. :lol:
haha. Not nearly as refined or stealth as a Vivax.
Bellevue, WA
USA
Storapa   100 W
Post by Storapa » Mar 17 2017 2:38am
My mate ordered one a couple of weeks ago. It should arrive in the UK shortly.
It looks like an interesting alternative if you want a lightweight mid-drive. He has a fair bit of experience with lightweight hub motors, so it will be interesting to see what he thinks.
I'll update the group when it arrives.
Daily machine. - Giant Toughroad, Mac 8T, Thun torque sensor, Phase Runner, CA V3
Scratch built machine - Crystalyte HS 3540, 12 fet IRFB4110 Infineon controller, CA V3, 74v - 20Ah Lipo battery pack. https://endless-sphere.com/forums/viewt ... =3&t=75457
amigafan2003   1 kW
Post by amigafan2003 » Mar 17 2017 6:02pm
Hmm, wonder if 6s lipo bricks will be a good match for this?
teslanv   100 MW
Post by teslanv » Mar 17 2017 6:13pm
amigafan2003 wrote:Hmm, wonder if 6s lipo bricks will be a good match for this?
It seems like the ESC they are using is ideal for 6S Lipo. It's rated for 22.2V. :wink:
Bellevue, WA
USA
Storapa   100 W
Post by Storapa » Mar 20 2017 7:26am
The kit arrived today. Pics below. The weight as pictured (without battery etc) was 2050g.
GNG 1.jpg (124.26 KiB) Viewed 3468 times
GNG 2.jpg (153.79 KiB) Viewed 3468 times
GNG 3.jpg (144.14 KiB) Viewed 3468 times
Wheazel   10 kW
Post by Wheazel » Mar 20 2017 7:40am
So is this a worm gear or bevel gear gearbox?
The position of the shaft makes me think bevel gear.
Storapa   100 W
Post by Storapa » Mar 20 2017 7:45am
Good question. I assumed bevel gear as I didn't know there was a worm drive version.
I will ask my mate what it is.
Post by Santa'sLittleHelper » Mar 20 2017 8:22am
Storapa wrote:The kit arrived today. Pics below. The weight as pictured (without battery etc) was 2050g.
Thanks, so about 4.52lbs. I don't see a freewheel in the mix. What kind of resistance do you feel when turning the crank without power?
Storapa   100 W
Post by Storapa » Mar 20 2017 8:30am
Hi SLH,
Not sure about the resistance, as it's at my mates workshop. I'll go and have a good look later this week. I'll also take more photos.
Any more questions, let me know and I'll do my best to answer them when I'm over there.
notger   100 W
Post by notger » Mar 20 2017 10:49am
Storapa wrote:Hi SLH,
sure, it would be great if you could open the gearbox and show some photos from inside, in that way we could guess alittle how many watts the gears might take maximum.
if you opened the gearboc also give us some pic about the motorshaft.
measuremenrs of the motor, diameter and lenght.
if possible measure the KV of the motor.
and some dereil photos of all the separate parts would be great too.
greets
gernot
amigafan2003   1 kW
Post by amigafan2003 » Mar 21 2017 9:05am
From the GNG website
The freewheeling clutch system is integrated in the gear box.
Ecyclist   1 kW
Post by Ecyclist » Mar 22 2017 11:51pm
So, let's see inside of the transmission.
My builds:
Storapa   100 W
Post by Storapa » Mar 24 2017 2:54am
Morning All,
I went and had a look at the parts that my mate has just received. This mid drive is a thing of beauty.
I got a couple of photos of the motor. I'd forgotten to take my vernier, so didn't get any precise measurement. Anyway, motor dia in about 50mm. Motor shaft is 8mm. Lenth is as per the photo.
We didn't open up the motor as my mate wants to run it first. As and when he does open it, I will get some photos.
Motor Length.jpg (72.79 KiB) Viewed 3466 times
Motor Length 2.jpg (70.5 KiB) Viewed 3466 times
Ecyclist   1 kW
Post by Ecyclist » Mar 24 2017 10:43am
[quote="Storapa"]
[quote="Storapa"]
Are you sure that the shaft is 8mm? That is enormous for 50mm inrunner. I'm still dying to find out how the tranny looks like and what is kV of that motor. I bet it is at least 2000 kV.
My builds:
