ag273n
100 µW
- Joined
- Feb 4, 2014
- Messages
- 9
the motor i end up acquiring is an Emax BL5345 (Blue Series). Its an outrunner motor - 195kV (90A on 10S-12S battery). I already have the ESC for it, a battery, and a servo tester - already tested the connections, it works, i'm able to control its RPM.
how do i know if this motor is ok to be used as a friction drive? i hear there has to be some kind of bearing built in so it can sustain the abuse. i'd like to just put maybe some griptape on its outer shell so the mount isin't as complicated as chain drives. - more discreet and clean looking.
