Cyclone motor
mafire@email.c   1 mW
Cyclone motor
Post by mafire@email.c » Jun 14 2017 2:15am
Hello
DingusMcGee   10 kW
Re: Cyclone motor suddenly stopped working. Please help
Post by DingusMcGee » Jun 14 2017 7:42am
1st. Contact eclipse bikes and ask them for help.
mafire@email.c   1 mW
Post by mafire@email.c » Jun 14 2017 10:21am
i did it - no answer yet.
mafire@email.c   1 mW
Post by mafire@email.c » Jun 15 2017 4:20am
please ?
minimum   100 W
Post by minimum » Jun 15 2017 8:41am
If your hall sensors supply measures battery voltage instead of 5VDC then your problem is likely worse - damaged controller aside hall sensors.
Voltron   10 MW
Post by Voltron » Jun 15 2017 8:46am
I'm not sure with the Cyclone, does it have an internal clutch or an external freewheel? If it's internal, that would explain the sound but no output. If you put your hand on it when you turn the throttle does it vibrate like the motor is spinning inside?
mafire@email.c   1 mW
Post by mafire@email.c » Jun 15 2017 9:27am
It have external freewheel.
zackclark70   100 W
Post by zackclark70 » Jun 27 2017 6:40pm
i can help with this ( as far as i know i am the only person to have done a full rewind on one of these motors and one of a handfull that has fully striped one of these )
If your having coging issues like the video that does suggest hall sensor problems have you taken the gearbox and top plate of the motor yet ?
btw the pin out for the hall wires is as follows
purp / blue temp cutout ( just a loop of the power switch wire really )
orange is ground
yellow is +5v or +15v depending on controller
black is hw
white is hv
red is hu
( with the controller on the voltage of hw hv and hu will go between +0v and +5-6v as you rotate the motor slowly )
also unplug all motor connectors and measure the resistance between the motor case and each of the 3 phase wires if they have low resistance there is a short ( can still be fixed just harder )
i am more than happy to help you or anyone that has one of these motors just give me a message
no mater what the problem is it can be fixed i will pm my phone number feel free to whatsapp call me any time ( i am in the uk )
sather   100 W
Post by sather » Jun 28 2017 6:59am
Robocam posted instructions and photos on how to do it
https://endless-sphere.com/forums/viewt ... l#p1283830
Quote: "If you email Paco, he'll probably give them to you for free (plus shipping). He did for me.
viewtopic.php?f=28&t=69867&p=1224666#p1224666
viewtopic.php?f=28&t=69867&hilit=radiator&start=1275#p1209434
viewtopic.php?f=28&t=69867&hilit=radiator&start=1350#p1223294"
zackclark70   100 W
Post by zackclark70 » Aug 17 2019 8:10am
sather wrote:Robocam posted instructions and photos on how to do it
the 3 hall chips are only a few £ easy to swap out and wont take more than a few days to show up cyclone can take a month to get here
Last bumped by mafire@email.c on Aug 17 2019 8:10am.
