rajien2
- Joined
- Jun 20, 2017
- Messages
- 4
Guys,
I'm on my 43rd apple battery 'recycle', I current have ~240 1900-2010 mwah 18650's and 32 more packs to disassemble. As a result I think im ready to start looking at a power plant, taking inspiration from the following videos I think 3 motors would be amazing.
https://www.youtube.com/watch?v=UG8RsJsJ05I
https://www.youtube.com/watch?v=yfn_HKViwtM&t=194s
https://www.youtube.com/watch?v=SiiNORLzA18
I need a bit of a sanity check on this set up, ive gone with water cooling options for better thermal control.
Motor: Turnigy AquaStar T20 x3 (229A) : https://hobbyking.com/en_us/turnigy-aquastar-t20-3t-730kv-1280kv-water-cooled-brushless-motor.html
ESC: Turnigy AquaStar 200A Watercooled x3 : https://hobbyking.com/en_us/turnigy-aquastar-200a-watercooled-sensorless-esc.html
Battery: 18650 x348, 29 cells in a module x12 at 44V at 696,000 mah
Frame: 140 Moto FRAME KIT with Larger Shield https://qulbix.com/qulbix-products/diy/frame-kits/140-moto-frame-kit-with-larger-shield
Throttle/Thermal control/BMS and rate sensor: Arduino Edison with a surface pro display.
The motor set up would look like the picture bellow. I believe with a large enough pully I can get the RPM down for more torque... Let me know if anyone sees any glaring problems with this configuration or if you have a better recommendation
