MarkLester
- Joined
- Jul 7, 2017
- Messages
- 4
I am trying to work out what this bit is even called.
Symptoms: a few nasty clicky noises and then while the motor still runs it isnt driving the chain wheel. Even worse and odd, i cant even pedal. obviously there is some magic between my work and the bafang. I took it off and then it worked. SO I put it back on, got 50 yards, and oit happened again, not even pedals will move the chain wheel.
Possible cause: I followed a national cycle route through a sand dune. I subsequently did two other beach runs before being told off by my cycling mentor. There is still grit everywhere.
Suggested solution: I have taken the cover off the crank area so I can see the small wheel from the bafang meshing with the large crank. Getting any further looks harder. I am proposing to attack it with WD40, try and run it on the work bench and continually spray with penetrating fluid, like buckets of it, then whack a load of grease back on and pray.
