Sur-Ron - New Mid drive Bike
3DTOPO   1 kW
Post by 3DTOPO » Jan 07 2019 6:17pm
motomoto wrote:
Jan 07 2019 9:05am
I used to make billet swingarms and frames. The swingarm weighed 1 kg without hardware.GP frame 1.jpg
Wow, that's pretty darn light! Does anyone have an idea how much the stock swingarm weighs? Is there a bearing where the swing arm connects to the frame?
I guess for calculating the force, it seems like the biggest force is the impact from jumping it. How many feet vertical drop could that swingarm withstand?
For a 220-pound rider, plus the 110-pound bike, I calculate that if landed completely on the back wheel from a 9.8-foot drop (3 meters), the swing arm would be subjected to 3,246 foot-pounds. I am guessing the lateral forces for centrifugal force, handling, etc. should probably be, what a half or a quarter of that?
Now, I am considerably lighter than 220 pounds, and never jump more than a couple feet, but that seems like a pretty good design goal. What do others think? How many vertical foot drop should a swingarm be able to take, with how heavy of a rider? What do you think the Sur-Ron was designed for?
Jonathan1981   100 W
Post by Jonathan1981 » Jan 07 2019 7:59pm
3DTOPO wrote:
Jan 07 2019 6:17pm
motomoto wrote:
Jan 07 2019 9:05am
Swing arm = 5.1lbs
Bare frame = 11 lbs
subframe, with key latch = 3.3 lbs (which is crazy heavy)
3DTOPO   1 kW
Post by 3DTOPO » Jan 07 2019 8:24pm
Thanks Jonathan!
Wow - Harley unveiled 4 new concepts today (two of them are prototypes). One of the prototypes looks like a Sur Ron competitor:
https://electrek.co/2019/01/07/harley-d ... otorcycle/
Love the fat tire on the back!
3DTOPO   1 kW
Post by 3DTOPO » Jan 07 2019 8:29pm
It's interesting they went with a belt drive on a vehicle that is clearly designed for off-road use.
Grantmac   10 kW
Post by Grantmac » Jan 07 2019 9:28pm
Belt drives are a Harley signature design feature.
fechter   100 GW
Post by fechter » Jan 07 2019 9:44pm
The belt looks like it might be made to fit on a Sur-ron. It would sure reduce the noise.
Rix   100 GW
Post by Rix » Jan 07 2019 11:25pm
Lelandjt wrote:
Jan 07 2019 4:05pm
RE: Swingarm Flex
My cut Shinko 3.5" tire clears the kickstand spring by over 5mm but under hard cornering it hits. The spokes are tight and it has 20psi. That's swingarm flex. I decided to find a smaller, lighter, less grippy tire that doesn't overwork the chassis so hard.
Yah thats frame/swingarm flex causing that. Not surprised you are having a little issue. But thats normal.
Rix   100 GW
Post by Rix » Jan 07 2019 11:27pm
3DTOPO wrote:
Jan 07 2019 6:17pm
motomoto wrote:
Jan 07 2019 9:05am
Nothing wrong with a little over engineering.
3DTOPO   1 kW
Post by 3DTOPO » Jan 08 2019 1:43am
Rix wrote:
Jan 07 2019 11:27pm
3DTOPO wrote:
Jan 07 2019 6:17pm
motomoto wrote:
Jan 07 2019 9:05am
Agreed. So you think a 10-foot drop with a 220-pound rider is a good target for a swingarm?
Rix   100 GW
Post by Rix » Jan 08 2019 11:04am
Yes I do.
motomoto   1 kW
Post by motomoto » Jan 08 2019 1:17pm
I have gone by the "that looks like it would be strong enough" approach in the past, but these days you do finite analysis on the computer model.
Flykrisco   1 mW
Post by Flykrisco » Jan 09 2019 8:55pm
I've looked online everywhere and I can't find information on RST killah fork. I have read it that it is a coil Spring and non adjustable. Does anyone know where you can purchase aftermarket heavier Springs?
Finer   1 µW
Post by Finer » Jan 10 2019 11:44am
I weigh about 185 pounds. My rst Fork has about 20% of sag when I sit on it. Right in the ballpark. If I weighed less than 150 lbs I would probably want lighter springs. If I weighed over 200 I would probably want a heavier spring. The compression and rebound clickers offer lots of adjustment. Small clicks, maybe one or two, make a huge difference on how the bike rides.
Lelandjt   100 mW
Post by Lelandjt » Jan 10 2019 10:06pm
Flykrisco wrote:
Jan 09 2019 8:55pm
I emailed RST and bought a "firm" spring but when I swapped it both it and the stocker had red paint on them and felt the same. They don't make an extra firm. I preloaded the spring with 2 washers between it and the plunger and that made it a little firmer. I poured 50cc of oil in the left leg and 20cc in the right leg and that helped the late stroke spring rate a little and improved lubrication. The damper desperately needs more shims or thicker oil and more pressure but you'll need to find a chuck that fits its weird version of a schrader valve before you open it. I gave up on the stock fork and got an air fork.
Lelandjt   100 mW
Post by Lelandjt » Jan 10 2019 10:08pm
Finer wrote:
Jan 10 2019 11:44am
20% is a lot of fork sag. If you aren't bottoming out and don't mind the steep head angle I guess you're okay but at 170lbs I was diving and sagging all the time and clanking hard off the bottom whenever I jumped. The compression clicker only firms LSC which blows off under impacts. It only helps resist diving under braking.
Jammen   1 µW
Post by Jammen » Jan 11 2019 10:52am
First post! Lurking for awhile, figured I should give back. :wink:
Rockshox Coil Spring Boxxer... https://www.amazon.com/dp/B002SR3MB2?re ... b_ap_share
That'll fit in the RST Killah. You'll need to take apart the weird like 6+" preload spacer they have in there and cut a piece of PVC down to 2" or 3". I think it was 1" diameter PVC but double check me.
Huge difference to have the extra firm spring for my 215# self!
Paulflieg   1 µW
Post by Paulflieg » Jan 11 2019 11:04am
ImageImage[/img]
Jammen wrote:
Jan 11 2019 10:52am
All the springs of the Rock Shox Boxxer fit. The same stroke. The length with a modified stop, to adapt to the top cap. The preload is easy to adjust.Image
JuiceMeUp   100 mW
Post by JuiceMeUp » Jan 12 2019 6:49am
RST Fork guys:
I pulled apart the right hand fork leg containing the compression dampening mechanism.
I drained and refilled the internal piston with 10 weight oil that was on hand (not sure what stock is).
Made a huge difference to the responsiveness of the compression dampening dial.
It's not a replacement for a stiffer spring, but happy with the 'quick fix' if bottoming out is a problem...
Rix   100 GW
Post by Rix » Jan 12 2019 7:42pm
JuiceMeUp wrote:
Jan 12 2019 6:49am
RST Fork guys:
I like it!
Lelandjt   100 mW
Post by Lelandjt » Jan 13 2019 6:46am
JuiceMeUp wrote:
Jan 12 2019 6:49am
RST Fork guys:
How did you repressurize the damper cartridge. That weird version of a schrader valve kept me from opening it. RST told me it comes with 10wt oil so I was gonna fill it with 15 and up the pressure.
Flykrisco   1 mW
Post by Flykrisco » Jan 13 2019 7:09pm
Paulflieg wrote:
Jan 11 2019 11:04am
ImageImage[/img]
Jammen wrote:
Jan 11 2019 10:52am
That is great news. Thank you so much for the information. I've got a spring on order.
I've got ahold of Alan at electric race technologies and we are working out the details for an asi lipo based power system. I'll post details when we get them worked out
derb   10 mW
Post by derb » Jan 14 2019 9:32am
At 2500km I changed the chain. As soon as you lift a chain link over half the tooth height on the sprocket, you should renew the chain. The teeth on the sprockets are still looking good and will not be changed yet.
Flykrisco   1 mW
Post by Flykrisco » Jan 14 2019 3:03pm
Allex wrote:
Nov 16 2018 3:36am
How many Amps did you see during peaks?
Here is a battery case extender with a new hatch. The pack is like 22s10p
Allex. Is this extension available. I'm going to build a new pack and this would be perfect.
Allex   1 GW
1 GW
Post by Allex » Jan 15 2019 5:12am
Flykrisco wrote:
Jan 14 2019 3:03pm
Allex wrote:
Nov 16 2018 3:36am
They are still working on the hatch.
freeflow   1 mW
Post by freeflow » Jan 15 2019 3:18pm
Who's building it? Sur Ron or after market?
