Sur-Ron - New Mid drive Bike
sc-surfer   10 mW
Post by sc-surfer » Dec 20 2020 12:18am
Got it. I presume that just makes the shunt read low on current so the BMS doesn't freak out??? Will the BMS now not read capacity correctly? Seems the 'gauge' would read low? If that's the case, are you just using voltage to estimate battery SOC??
Hawaiiguy   1 mW
Post by Hawaiiguy » Dec 20 2020 12:41pm
That guys soldering was terrible.
fechter   100 GW
Post by fechter » Dec 20 2020 1:14pm
Yes it will affect the battery gauge. If you run the pack all the way down to cutoff and fully recharge the gauge will try to recalibrate itself. You may need to do this more than once to get it accurate.
Soldering on the board is challenging because it's an aluminum board. You need an iron with a lot of heat and it's likely to end up looking like that picture.
AZeBikeGuy   10 W
Post by AZeBikeGuy » Dec 20 2020 2:24pm
fechter wrote:
Dec 20 2020 1:14pm
....Soldering on the board is challenging because it's an aluminum board. You need an iron with a lot of heat and it's likely to end up looking like that picture.
Oh for the love of god get out some wick or something =]
Paulflieg   10 mW
Post by Paulflieg » Dec 21 2020 5:16am
Hallo,
Does anyone know which connectors are on the original controller? And where do you buy them?
ethana4   1 µW
Post by ethana4 » Dec 21 2020 9:15pm
So I'm having an issue with my Sur.
I installed a new headlight/switch assembly. For some reason when I turn the light on it makes my speedometer act crazy.
I've tried numerous wiring configurations and different switches. I also connect and try them before actually installing them under the ignition panel. They work without affecting the speedometer this way, but when I install the ignition panel, it makes the issue happen.
I can't put my finger on what is happening.
Could really use you help. Thanks !
fechter   100 GW
Post by fechter » Dec 21 2020 11:05pm
Which wire did you insert the switch into? Both the headlight and speedometer run off the 12v dc-dc.
ethana4   1 µW
Post by ethana4 » Dec 22 2020 4:47pm
I wired a switch to the the lights cable and then plugged into the existing headlight connector
fechter   100 GW
Post by fechter » Dec 23 2020 12:47pm
ethana4 wrote:
Dec 22 2020 4:47pm
That's pretty strange. I can't think of any reason that would happen. You could try putting it back the way it was and see if the problem goes away.
smdub   100 mW
Post by smdub » Dec 23 2020 9:04pm
Bad connection (power or ground) that goes loose when you shove all the wires back in place?
EMI is another possibility. The LED likely has a switching power supply and maybe not a lot of input filtering. A capacitor and/or ferrite bead would help if that was the case. Is it CE/FCC listed?
JuiceMeUp   100 mW
Post by JuiceMeUp » Dec 23 2020 11:02pm
light-bee-wiring-diagram.pdf
(1.09 MiB) Downloaded 71 times
thoroughbred   100 W
Post by thoroughbred » Dec 24 2020 7:13am
Paulflieg wrote:
Dec 21 2020 5:16am
Hallo,
I'm guessing you are in europe? in usa we have
https://www.ebay.com/itm/WATERPROOF-9-P ... 2749.l2649
Paulflieg   10 mW
Post by Paulflieg » Dec 27 2020 11:28am
thoroughbred wrote:
Dec 24 2020 7:13am
Paulflieg wrote:
Dec 21 2020 5:16am
Hallo,
Ahh yes, thanks ... With this info, I found the parts on Aliexpress 👍 the "old" controller had to give up its plugs for the new one.
Bullfrog   1 kW
Post by Bullfrog » Jan 03 2021 12:45pm
Can anybody tell me the head tube angle of a stock Sur Ron?
I have searched for it but not been able to find the spec...if it is listed somewhere a reference sure would be appreciated as well.
n2mb   100 W
Post by n2mb » Jan 03 2021 1:13pm
Amaxophobie wrote:
Dec 10 2020 3:09am
Has anyone measured the power output of the USB-plug from th Sur Ron? It says 5V 2,4A on it.
If so it would be enough to power an additional 10W LED on the handlebar without mounting the associated 1S3P batterybox.
Why not just use the 12V power? I run a 30W LED headlamp from it with no problem.
sc-surfer   10 mW
Post by sc-surfer » Jan 03 2021 8:55pm
Who's running the eMotoBros controller and display?? Any feedback?
Ohbse   10 kW
Post by Ohbse » Jan 03 2021 10:53pm
It's an ASI - so... unreliable, comparatively difficult to configure, dodgy support (thanks to resellers rather than the company themselves).
It's better than the stock controller IF you can get it configured correctly.
Nucular is a better option in every regard, with the notable exception of its long, long lead times. Very reliable, plug and play with the Surron harness, exceptional support and very easy to make changes yourself with the display.
thoroughbred   100 W
Post by thoroughbred » Jan 04 2021 5:32am
After running the 19 rear wheel with a geomax knobby for a year I wanted to try a 18 as the 19 has small knobs and puny sidewall.
I followed offroaders nice write up and bought some supplies. Apparently, all ebay 12g sapim spokes are not created equally.
the hook portion of these is too short to allow assembly. Plan B was to reuse the oem spokes with the new rim by switching from 2 cross to 3 cross pattern
Finer   100 µW
100 µW
Post by Finer » Jan 04 2021 6:53pm
Bullfrog wrote:
Jan 03 2021 12:45pm
63.5 degrees. I checked it because I ordered a 21 inch wheel and want to see what the difference is after the change.
Bullfrog   1 kW
Post by Bullfrog » Jan 04 2021 6:57pm
Thank You :D .
smdub   100 mW
Post by smdub » Jan 04 2021 8:08pm
Bullfrog wrote:
Jan 03 2021 12:45pm
Per sur-ron.ro/.it/etc its 26deg (= 64deg in common head angle terms)
https://sur-ron.ro/project/light-bee-x/
https://www.aebikes.com.au/specifications.html
But there have been a couple different forks on the front (26 & 27.5) so who knows which that was measured with.
W/ the 1260mm spec wheelbase, every 1mm increase in axle height = asin(1mm/1260mm)=0.045deg.
From the stock tire, the difference was about 35mm radius = ~1.6deg => 64-1.6=62.4 (that is if I *ONLY* put a bigger front tire on)
Going to a Fox40 27.5 fork was ~15mm longer axle crown measurement than my orig 26" RST. That's roughly equivalent to 15mm*sin(64)=13.5mm lift = another 0.6deg => 62.4-0.6=61.8
Since I ALSO used a larger rear tire, the front radius only raised ~7mm => 0.3deg. So my total change is only 64-0.3-0.6=63.1. FWIW, both my KTMs (150 & 500) are 63.5deg. I've never measured the ACTUAL angle but the bike steers ok but not super quick. I've used it on the scouting lap for a trials competition and its definitely 'lazy' compared to those. I really haven't ridden it and the 150 hard back to back to know if I can even tell the difference between the two. I've thought about ordering the rear shock link that lifts the rear a little and see if I like it. I'm tall and can use all the height I can get. But I'm close to making the bike too tall for my wife to ride comfortably so I have to tread carefully if I want her to ride along w/ us.
(Someone please check my math to make sure I didn't screw up.)
Bullfrog   1 kW
Post by Bullfrog » Jan 05 2021 8:01am
smdub wrote:
Jan 04 2021 8:08pm
Bullfrog wrote:
Jan 03 2021 12:45pm
Thanks smdub...you make some very valid points and your insight is very valuable and your calculations are awesome and exactly what I would be doing :lol: . I actually think it is acos but for the small changes we are talking about the change is virtually going to be the same whether you use asin or acos :D . I don't know about others but you can understand why I probably won't get a Sur Ron after getting the head tube angle info since I ride in tight single track trails most of the time with my top speed being approximately 17-18 mph.
The head tube angle on my BBSHD Ludicrous powered hardtail is 70 degrees and I like the steering on it. I have a fat tire bike with the same drivetrain that has a 68 degree head tube angle and I run a 27.5x2.8 front tire with the 26x4 rear tire and the steering on it is on the verge of being too slow for my personal preference.
If my speeds were faster then the lower angles would be nice and provide more stability but for the woods where I ride, I like something that steers relatively quickly. Sort of sucks because I'd like to build a full suspension ebike but head tube angle for all the current crop of full suspension bikes is pretty low. The lower angles are great for riding off the side of a mountain or high speeds but they suck when you are going 18 mph in the tight trails and need to make turns :wink: .
smdub   100 mW
Post by smdub » Jan 05 2021 9:19am
asin() is correct as acos(~0)=90deg. Big difference. SOHCAHTOA
Trail is as big a factor as head angle so don't discount that. Early 29ers w/ 26er low axle offset steered like crap until new high offset forks came about and reduced trail back to a reasonable number. Not sure which downhill forks have higher offsets but you could definitely get/make offset triples.
This is as close to as I have found for head angle on the trials bikes. 73deg. I have Shercos instead of GasGas but I suspect they are all similar. They have razor sharp handling.
I would like to try the Sur-Ron in a trials competition. There are a couple Electric Motions & OSETs that ride in local events. What its really lacking is steer angle though. You just can't turn the forks close to 90 deg left/right like you can on a trials bike. My old Betas would actually go past 90deg.
I see you are trying to adapt the Sur-Ron to something what it wasn't really designed to do. Nothing wrong w/ that(!) but is a 110# bike really going to be all that much fun in TIGHT single track even w/ better geometry? W/ a 1.6 gearing change like you asked for in the other thread, and the resultant increase in torque, it might end up as an overpowered, overweight, trail-destroying machine. (I recently installed a Nuc24F looking for more power and its a blast but its wreaks havoc on the yard and I'd never take it on the mtb trails.)
Hawaiiguy   1 mW
Post by Hawaiiguy » Jan 05 2021 5:11pm
I ride tight single track all the time and I think the steering is plenty quick enough,I am also running the Bac8000 set to 13500w and it’s a blast to ride and climb steep hills.My friend rides his trials bike with us and he has no advantage.
3DTOPO   1 kW
Post by 3DTOPO » Jan 05 2021 7:48pm
Sup y'all!
So after over 2,300 tubeless miles it was time to replace my trusty Bridgeport M403 with the newer M203.
The first tubeless conversions I had to use a strap around the tire to get enough of a seal for the tire to inflate. It really was the most pain-in-the-ass task in the whole procedure.
Welp, this time I removed the the spoke protector rubber and used a narrow strip of gorilla tap in the U-channel. I then added another slightly narrower band in the U-Channel over that to kind of fill it in. Then one more band on top of that the full width of the rim.
This gave me a good enough seal to eliminate the need for using the strap! Filled right up with just an air compressor. It's such an easy process now I could not recommend going tubeless enough.
