Tommm wrote: ↑Mar 18 2019 2:28pm
Thankfully they went with the sane 4000 instead of the motor burner and impossible to feed 8000.
Im confused. motomoto said he was working with ASI to get a custom tuned 8000 controller for the bike. He said that just a page or two before this if you want to see his post or here is the direct link.
viewtopic.php?f=28&t=89902&start=3175#p1451295
Now is this 4000 the controller that motomoto was working with ASI to tune or is this another controller version.
The other question is the 4000 seems to be way more power than you would need as its capable to hit 32KW. Why would motomoto want to get an 8000 controller made for the bike? Seems overkill unless you can get more phase amps or something out of the 8000.
Can someone clarify what is going on here with the 4000 and 8000 controllers? Would you ever really need or want an 8000 controller. I do know that phase amp used to make a differrence as the max-e had limited this, and maybe the 8000 allows more phase amps?
The other question is what exactly is motomoto getting custom tuned with the 8000, and does it matter? Is this 4000 custom tuned also?
This bike definitely needs a controller upgrade so we need to figure out what controller is best to get.
