Sur-Ron - New Mid drive Bike
Offroader   100 MW
Post by Offroader » Jun 22 2019 11:29am
Does anyone find the stock sur-ron handlebar doesn't feel right when holding it? It seems it puts your wrists in an odd position or something. I'm not talking about the low height.
The reason I notice this is that I was using a 3" aftermarket deity handlebar and that felt very good. Then I put back on my Sur-Ron handlebar, as I bought a new fork, and right away I can feel my wrists are in a position that does not feel right. It also seems I am not getting used to it.
I do know there are different sweeps with the handlebars and I am wondering if this is the case?
I am wondering if you guys also feel that the Sur-Ron handlebar is curved oddly (maybe called sweep) and is not very comfortable. I am not talking about the height as I have an uncut steerer tube on my new fox fork and I have raised the height about the same as my 3" Deity handle bar.
I'm thinking of just putting back on my 3" deity handlebar and cutting the steerer tube because I can't stand the Sur-Ron handlebar. I just didn't want to cut my steerer tube, so maybe I will have to get a new Deity handlebar that doesn't have a 3" rise.
EDIT: It does say this in the diety handlebar specs I bought. I think they may be right about ultimate comfort as this bar is way comfortable to hold.
9 degree bend / backsweep and 5 degree upsweep for ultimate comfort
https://www.deitycomponents.com/store/p ... _RISE.html
You guys may want to consider getting a new handlebar because you may not realize how much the stock one sucks in so many ways, height and sweep. You will also not realize how much it sucks and screws up the ride until you replace it.
Rix   100 GW
Post by Rix » Jun 23 2019 10:53am
Offroader wrote:
Jun 22 2019 11:29am
The stock ones have a unique bend profile. I eventually got used to it, but I did have plans to change the bars at one point before I sold it.
Merlin   10 MW
Post by Merlin » Jun 23 2019 11:02am
Handlebars are like clothes/shoes.
Iam not mad at a stock handlebar because I have to replace them always.
Some are picky some are not. If it feel not right... Change somrthing. Pushing the bar a bit forward /back changes also angles to your wrists.
I can't count how many handlebars I have tried in my life :D
But from that trying you get some experiences in which way you have to go on buying a new one.
Antenor   100 W
Post by Antenor » Jun 24 2019 4:15am
Anyone knows in Europe the best price for a surron?
SlowCo   100 kW
Post by SlowCo » Jun 24 2019 6:56am
Antenor wrote:
Jun 24 2019 4:15am
https://suchen.mobile.de/motorrad-inser ... 87795.html
Street legal as a moped in red or black for €3985,- incl. tax.
Antenor   100 W
Post by Antenor » Jun 24 2019 9:20am
Thank you :thumb:
wuhaichao443   10 mW
Post by wuhaichao443 » Jun 25 2019 1:12am
Offroader wrote:
Jun 22 2019 11:29am
I chose the odi and renthal cross-country bike handlebars, which felt great
skyungjae   10 kW
Post by skyungjae » Jun 25 2019 8:33am
Jammen wrote:
Jan 11 2019 10:52am
First post! Lurking for awhile, figured I should give back. :wink:
Rockshox Coil Spring Boxxer... https://www.amazon.com/dp/B002SR3MB2?re ... b_ap_share
That'll fit in the RST Killah. You'll need to take apart the weird like 6+" preload spacer they have in there and cut a piece of PVC down to 2" or 3". I think it was 1" diameter PVC but double check me.
Huge difference to have the extra firm spring for my 215# self!
This is one of the many modifications I wish I had done within the first month of owning the bike. It does make a world of difference when the factory RST fork stays compressed under the bike's own weight. It's nice being able to ride without the fork bottoming out all the time.
¯\_(ツ)_/¯
sn0wchyld   1 MW
Post by sn0wchyld » Jun 26 2019 7:04am
does anyone know the stock X controller phase amps?
n2mb   100 W
Post by n2mb » Jun 26 2019 7:53am
sn0wchyld wrote:
Jun 26 2019 7:04am
it may have changed from the first version of the x controller to a new version recently.
Offroader   100 MW
Post by Offroader » Jun 26 2019 8:57am
The Sur-Ron motor is getting hot in the summer heat. Touching the motor starts to burn my hand after 5-10 seconds.
I had a feeling this would be an issue once the summer hit and outside temps are 90F.
I am really not sure how hot this motor should feel considering it is different than a hub motor. My hub motors got just as hot on the surface but when the hub motors were that hot you had to be careful because the windings were easily overheated. It took just 10 seconds of full throttle for it to go into overheating temp zone.
I am still surprised many of you are not worried about this issue and just assume the motor will be OK. NO temp gauge, no problem.
Maybe this is the case since nobody has burnt up their motor yet.
I still can't wait to see when you guys start modifying your controllers and battery packs and don't really care that the motor has no temp gauge as you push the bike up over 10KW. :flame: :flame:
What I found is that 70F days are far different than 90F days when it comes to overheating and I am seeing this. The motor seems to not be able to cool itself in 90F summer heat, while with 70F days it was much cooler. The Sur-Ron motor also does not have very good airflow, to practically no air flow at all. It is complete blocked by the skid plate.
n2mb   100 W
Post by n2mb » Jun 26 2019 8:58am
Offroader wrote:
Jun 26 2019 8:57am
That's strange. Mine stays totally cool... Barely warm to the touch after long rides.
TechZoo   1 µW
Post by TechZoo » Jun 26 2019 1:48pm
wuhaichao443 wrote:
Jun 17 2019 12:49am
One of the necessary jobs after 7,000 kilometers
Can you measure the bolt circle on the front sprocket please? Or if someone else has it, please post it. I'd like to make a counterbored bolt circle on a shoulder sprocket to offset the chain about six mm and I don't want to take my bike apart just yet. I have the rear sprocket circle. _Thanks
front sproket.jpg (111.15 KiB) Viewed 1366 times
Paulflieg   1 µW
Post by Paulflieg » Jun 26 2019 3:45pm
36 mm, Lochkreis
Duncan75   10 mW
Post by Duncan75 » Jun 26 2019 3:58pm
Let's start with a few Sur-Ron website quotes:
"Inspected by the strict quality standards, come the best quality product.​"
"Professional off-road bike technology"
This rear mud guard and light holder is a piece of shit. And I didn't even hit anything with it.
I tried to limp home like this, but the left side also broke shortly after.
Looking at the type of metal used in this pos, it reminds me of the first Chinese pit bike imports years ago. They were like death traps because the frames loved to split in two at the worst moments, basically kindergarten metallurgy.
I do love my Sur-Ron, but I'm not fooling myself that it's a quality product. The stock brakes are crap, the chain is crap and the tires are also the worst I've ever ridden.
It's disappointing having to spend a lot of money to buy one and then still have issues that are typical for $400 Chinese gas bikes. It's not a new product anymore, these things should've been fixed long ago. Get your act together Sur-Ron.
Offroader   100 MW
Post by Offroader » Jun 26 2019 7:54pm
That sucks, I know the feeling when stuff breaks. Actually, other than the cheap skid plate they used which I had to use a hammer to knock back down today, my bike has been holding up for the most part through lots of abuse. The brakes are not great but they didn't break on me. I upgraded the brakes to Shimano saint breaks and glad I did.
Offroader   100 MW
Post by Offroader » Jun 26 2019 7:58pm
I used my temp gun to check the temps of the exterior of the Sur-Ron motor. With the motor hot I am reading 55c max temps.
I would have thought it would have been hotter. 55C definitely feels burning to my hand but I believe these motors can easily see temps like 130C at the magnets.
My question to you guys is 55c on the surface of the motor OK to continue riding the bike hard? Not sure how you should approach the heat with these motors since the wingdings are on the outside of the motor. Not sure if 55C is the temp on the exterior of the motor what the temps are probably at the magnets inside the motor.
fechter   100 GW
Post by fechter » Jun 26 2019 9:46pm
Since it's an inrunner, the temperature difference between the inside and the outside is not that much. Not like a hub motor.
I would stop at 60C. The magnets and hall sensors are the most heat sensitive parts, but they can take quite a bit.
When Luna tried to fry a motor they really put some power into it and it was apparently the windings that burned up before hall or magnet failures.
Allex   1 GW
1 GW
Post by Allex » Jun 28 2019 11:05am
Please try to not misinform ppl here if you are not sure about the facts.
The motor(P/N 11100-YQ2A-0200 u can find this label when lifting up the skid plate) has a KTY84 temp sensor installed so the protection is present.
Rix   100 GW
Post by Rix » Jun 28 2019 3:52pm
Offroader wrote:
Jun 26 2019 7:58pm
When I had my SurRon, I rode the hell out of it in the mountains. At 250#, I was running stock everything except a 55T rear sprocket and Renthal Chain. I couldn't get the motor to overheat to the point of thermo shutdown. For what thats worth.
Rix   100 GW
Post by Rix » Jun 28 2019 3:57pm
Duncan75 wrote:
Jun 26 2019 3:58pm
The SurRon is a quality bike with some low quality components, but the battery, frame, and motor/running gear is all good quality stuff. The shock, fork, footpegs, chain, stock sprockets and other stuff like that are bottom of the line to keep the price down. I believe the SurRon is worth upgrading.
3DTOPO   1 kW
Post by 3DTOPO » Jun 29 2019 3:08pm
Luna's Ludicrous R special edition is now available for order:
https://lunacycle.com/luna-ludicrous-r/
They claim double the stock amps. It's over $5k though and they claim they are only going to sell 20 of them ever. I imagine once they sell them, they will offer the Luna Ludicrous R II. :lol:
Offroader   100 MW
Post by Offroader » Jun 29 2019 6:03pm
Allex wrote:
Jun 28 2019 11:05am
Have you traced this KTY84 sensor to the controller? Is there a wire running to it from the motor to the controller?
That is good to know if it does have one, nobody ever mentioned it.
Offroader   100 MW
Post by Offroader » Jun 29 2019 6:08pm
3DTOPO wrote:
Jun 29 2019 3:08pm
That is a really good price for what you get.
You get a modified battery, controller, extra set of tires, Belt Drive,
Honestly, it isn't that much more for all these upgrades. This seems like a very good deal.
They should have ditched the stock handlebar and put on a 3" riser handlebar.I recommend the deity highside.
3DTOPO   1 kW
Post by 3DTOPO » Jun 29 2019 6:12pm
Offroader wrote:
Jun 29 2019 6:08pm
3DTOPO wrote:
Jun 29 2019 3:08pm
I didn't say it was a bad deal. I'm laughing at the claim that they will only make 20 of them - ever.
As far as an extra set of tires goes, I have absolutely no need for the moto wheels, so pretty meaningless to me.
