Sur-Ron - New Mid drive Bike
Merlin   1 MW
Post by Merlin » Jan 28 2020 12:48pm
Controller Heat sink for the tiny surron motor?
Before you heat up the controller the motor will be plasma.
Boom Storm   1 mW
Re: Sur-Ron - Heat Sink for ASI
Post by Boom Storm » Jan 28 2020 2:19pm
Posters were primarily interested in protecting their ASI. This fabricator for some reason already created a heat sink; hopefully it can do both.
3DTOPO   1 kW
Post by 3DTOPO » Jan 28 2020 4:45pm
skyungjae wrote:
Jan 28 2020 11:21am
I bet ASI, in general, would sell a lot more controllers if they didn't go with their orange/blue theme. :lol:
Is the case fairly easy to remove? If so, most thermoplastics can be dyed. Unlike paint, it won't scratch off.
To dye plastic, get a pot big enough to contain the part, bring water to a boil, then add some clothes dye like Rit Dye (I recommend liquid opposed to powder dyes). Boil the part until you see the part obtain the color that you want.
sn0wchyld   1 MW
Post by sn0wchyld » Jan 29 2020 12:21am
3DTOPO wrote:
Jan 28 2020 4:45pm
skyungjae wrote:
Jan 28 2020 11:21am
awsome - gonna try that with PVC.
3DTOPO   1 kW
Post by 3DTOPO » Jan 29 2020 1:32am
sn0wchyld wrote:
Jan 29 2020 12:21am
I think you can just dip PVC in the dye for 30-60 minutes - might not even need to boil it.
You can also use pipe-cleaner mixed with petroleum dye to stain PVC:
https://makezine.com/projects/make-30/s ... -you-like/
sn0wchyld   1 MW
Post by sn0wchyld » Jan 29 2020 1:43am
3DTOPO wrote:
Jan 29 2020 1:32am
sn0wchyld wrote:
Jan 29 2020 12:21am
Given I'm looking for black ill just leave it overnight :P
fechter   100 GW
Post by fechter » Jan 29 2020 9:04am
I'm not sure if the orange part comes off separately. Black spray paint will work. Another option would be black vinyl sticky sheet or fake carbon fiber.
The plastic dye process looks cool though. I might have to try it on some other projects.
amberwolf   100 GW
Post by amberwolf » Jan 29 2020 9:00pm
keep in mind a number of styrenes won't handle boiling water temperatures very well (150f is enough to deform them), and neither will a number of polyethylenes.
the thicker the plastic the less it will deform, but if it's not uniform density (not uncommon in complex injection molded parts, or ones with thin and thick areas, etc), or if it's vacuformed, the more likely it is to do so, and the worse the deformation will be if it does.
so it depends on what specific plastic you're using whether you can heat it that much or not.
3DTOPO   1 kW
Post by 3DTOPO » Jan 29 2020 9:12pm
True; like I said it can be done with most plastics; certainly not all.
That said, I don't think styrene/polyethylene parts are very common - especially for motorbike/bike parts. :wink:
To use the immersed dye method, I would try first letting it soak at room temperature. If it doesn't absorb any appreciable dye, go from there.
amberwolf   100 GW
Post by amberwolf » Jan 29 2020 10:10pm
3DTOPO wrote:
Jan 29 2020 9:12pm
you'd think that...but most of the common ebike motor kit control parts i've run across are styrenes. (throttles, control clusters, ebrake lever mounts (the ones that aren't cast alloys), display casings, battery cases, etc.) sometimes it's abs, which takes heat better, but sometimes it's plain old ps. :(
some of the regular bicycle shifters/etc i've had are also styrenes. (some of them even deform from the heat we have here, when stored in places that have no airflow (metal sheds, etc) and in direct sunlight in the summer.) more than a few of the bike computers and lights I've had have had styrene casing parts (and some of which deformed like the above)
some of them are marked with recycle triangles that help identify the material, but most don't seem to have them. but styrene usually has a specific smell when it gets hot (like when filing it or dremeling it).
pe...yeah, i don't recall ebike or bike parts made of that at the moment, though i think i've had some hdpe chain guides / rollers / etc. not sure though.
Kauaiguy   1 mW
Post by Kauaiguy » Feb 02 2020 8:14pm
I just got back from a muddy ride on Kauai. My friends ride a trials bike and the other rides a 2019 Ktm 300,where in our 60’s.The Sur-Ron is so much easier to ride!
LightBeeCommuter   1 µW
Post by LightBeeCommuter » Feb 02 2020 8:18pm
Any recommendations on brake pads?
KeithT   100 mW
Post by KeithT » Feb 02 2020 8:36pm
I'm an old guy on a Sur Ron in the mud too, love it. Much better on tight wet woods trail than my Zero FX. My friend is on a KTM500, way too much bike but I haven't convinced him to downsize, yet! I'm 69, he's 70.
Kauaiguy   1 mW
Post by Kauaiguy » Feb 02 2020 8:49pm
My friend with the Ktm300 has his Sur-Ron coming in tomorrow,he’s tired of the electric bike being faster and easier to ride.He can climb hills faster but those aren’t as common as the muddy tight woods riding on Kauai,Sur-Ron still climbs them at a slower speed.
For brake pads:Shimano H03C sintered metal Mtb
X-Nitro   1 mW
Post by X-Nitro » Feb 02 2020 11:27pm
LightBeeCommuter wrote:
Feb 02 2020 8:18pm
Alligator turbo and Shimano ho3c are the preferred aftermarket pads. :bigthumb:
E-Goat Sur-Ron
Kauaiguy   1 mW
Post by Kauaiguy » Feb 04 2020 6:10pm
Just installed a new skid plate made from HDPE from a Australia Sur-Ron aftermarket parts maker,(https:racespecsurron.com)$65 delivered,seems very solid and should slide over stuff better than the fragile stock skid plate.
Merlin   1 MW
Post by Merlin » Feb 04 2020 6:19pm
Looks slick. Not the edgy other stuff 👍
fechter   100 GW
Post by fechter » Feb 05 2020 9:14am
X-Nitro wrote:
Feb 02 2020 11:27pm
Feb 02 2020 8:18pm
I tried the HO3C pads but found them to be pretty noisy. The HO1A (organic) pads are much quieter and still stop well.
Merlin   1 MW
Post by Merlin » Feb 05 2020 10:19am
this is the problem from the disgusting luna fb group ^^
all those lemmings follow the crap
Aebrennan   100 W
Post by Aebrennan » Feb 05 2020 2:38pm
Kauaiguy wrote:
Feb 04 2020 6:10pm
Just installed a new skid plate made from HDPE from a Australia Sur-Ron dealer(https:racespecsurron.com)$65 delivered,seems very solid and should slide over stuff better than the fragile stock skid plate.EA322BB0-B718-49D1-AD45-ADA9294DCD14.jpeg63C0A5A1-1D36-44C0-810C-5DEEE7264457.jpeg
Please note that they (racespecsurron) are not a Sur-Ron dealer but a manufacturer/supplier of non genuine aftermarket components for use on Sur-Ron bikes.
Unfortunately this misleading information regarding the term
“dealer“ leads to other “dealers” getting upset with potential loss of market share sales etc this has also led to dealer conflict with Sur-ron directly.
Sur-Ron wants aftermarket suppliers to be clear and honest and not mislead customers and seperate themselves from the actual manufacturer.
Kauaiguy   1 mW
Post by Kauaiguy » Feb 05 2020 7:20pm
Sorry about that,they don’t sell bikes just there own parts,my bad,I corrected my post.
elik1111   100 W
Sur Ron brake lever
Post by elik1111 » Feb 07 2020 1:14pm
Does anybody where the Sur Ron brake lever can be bought?
I have just broke one of them and don't wish to replace the whole brake system.
Observeder   100 µW
100 µW
Post by Observeder » Feb 07 2020 6:01pm
aliexpress has them. That's where I got mine.
elik1111   100 W
Post by elik1111 » Feb 07 2020 6:06pm
What's about the part that push the hydrolicc piston?
elik1111   100 W
Post by elik1111 » Feb 07 2020 6:07pm
The part I meant to
