Sur-Ron - New Mid drive Bike
skeetab5780   10 MW
Re: Sur-Ron - New Mid drive Bike from China
Post by skeetab5780 » Feb 26 2018 5:18pm
Aww i was excited for a new vid but i already watched it earlier...
Hyena   100 GW
Post by Hyena » Feb 26 2018 5:34pm
Youtube channel subscription 4TW :P
Sorry for the disappointment. I'll have to do another soon :)
I've got some footage of riding 2 up with my little bloke - I'll post that on the weekend
www.HyenaElectricBikes.com
skeetab5780   10 MW
Post by skeetab5780 » Feb 26 2018 5:47pm
Im surprised at how bald your rear tire is already, makes me jelous as our winter is still closing out up here and i got the itch to ride. You can tell you ride hard and that means that it is a pretty fun ride!
Allex   1 GW
1 GW
Post by Allex » Feb 27 2018 8:29am
A quick video, feels good when you have sections with 30cm snow and it slice through it.
skeetab5780   10 MW
Post by skeetab5780 » Feb 27 2018 9:27am
Burrr that looks like a cold ride, This one makes me happy to be behind a computer
xcnick   100 mW
Post by xcnick » Feb 27 2018 11:29am
Thanks for the video. You appear to be the perfect person to try a ski on the front. I put one on for Motomoto on his visit, but the snow wasn't a condition that made too much a difference. However living in snow I find days when it is the difference between riding and not riding. My video so far:
E-geezer   100 W
Post by E-geezer » Feb 27 2018 12:13pm
I'd be careful riding in a designated wilderness area that close to the road, some ranger will pop you.....
The older I get, the faster I was
xcnick   100 mW
Post by xcnick » Feb 27 2018 12:30pm
No worries, we don't ride on the other side of the sign. Glad you pick up on my establishing shot. We, as in the dogs and I. I am very alone out here. (I only recognize my friends from their avatars.)
macribs   1 GW
1 GW
Post by macribs » Feb 27 2018 1:37pm
Running with studded tires or stock xcnick ? I did put studs on the old vector this winter. First ride I took I got hit by a car. Dislocated and fractured shoulder, still tender knees and only one working arm. Haven't even been able to fix up the vector yet because of shoulder pain.
I just watched one of Holmes Sur Ron videos, and from the look of it, it might see like the seating should have been slightly longer in front. To allow for a more easily weight transfer to front wheel in tight turns and bends, specially on loose gravel, dirt and sand. What do you think after riding the Sur Ron, can you get you foot out and up front like in mx style riding?
For those of you who yet haven't watched holmes videos.
litespeed   100 kW
Post by litespeed » Feb 27 2018 2:19pm
That was a good video and great camera work to really get an idea of what it is, size of it and what it can do. Doesn't look like it would fit my 6'4" 210 lbs size though. Bummer for me.
Tom
efMX Trials Electric Freeride   100 kW
Post by efMX Trials Electric Freeride » Feb 27 2018 2:38pm
static seat height stock is about 31.5".. has 19" moto wheels front and rear.. the seat strut is bolt on so removable.. someone tall could fit a longer handlebar stem to lengthen the reach, switch to 21" front moto wheel or 27.5 bike wheel.. and possibly have a taller seat strut made.. and stiffer suspension springs, etc for heavier riders..
some ride & sk8 videos:
metacafe.com/channels/NATAS666DAMIEN
http://www.youtube.com/natas666damien
i have nothing for sale.. :)
Gab   100 W
Post by Gab » Feb 27 2018 3:40pm
cool video but where is all the gear or chain whine comeing from ? this diffinetly sounds louder than a hub or even the c3000w mid drives ?
it could be that the belt or chain is doing all the high rpm reduction as their is no gearbox. whereas on the c3000w type mid drive ebikes its done inside the gearbox with plastic gears silently..
if you ride this on the road it will stand out due to the noise
Post by efMX Trials Electric Freeride » Feb 27 2018 3:49pm
the noise is coming from the small chain sprocket on the reduction jackshaft spinning at high rpm.. and maybe the cooling fan..
Hyena   100 GW
Post by Hyena » Feb 27 2018 4:05pm
Chilly ride Alex!
Have they changed the headlight or did you fit that ? Mine had a plastic case unit with a twist back to turn it on/off. Yours looks like cast metal ?
That was one of the things I found cheap/tacky looking on the bike so if they're coming like this from the factory now that's another nice upgrade
motomoto   1 kW
Post by motomoto » Feb 27 2018 8:03pm
efMX wrote;
I say yes to the above.
efMX also made this observation earlier;
to install a belt drive to the rear wheel you will need to remove the swingarm, jackshaft, and rear wheel.. install larger diameter and wider belt sprockets front and rear, make sure that you will have enough clearance for the wider belt and sprockets by the motor, tire and chain stays and find a belt with the proper length to achieve your desired gearing.. then if the belt should happen to break from a stick, rock or mud buildup on the sprocket you will not be able to perform a trail side repair without removing the swingarm, jackshaft, and rear wheel.. so be prepared to carry necessary tools with you if riding off-road.. this is the reason that zero offers chain drive conversion on the fx for off-road use..
I say yes to that one also.
I think a 20 mm wide x 8 mm pitch Gates Poly chain will do the trick.
https://ww2.gates.com/europe/downloads/ ... n_id=19464
sunrise   1 µW
Post by sunrise » Feb 28 2018 2:29am
how much do these weigh without the battery? I was wondering if I could carry one with a 1up hitch rack.
Also do folks know the difference between the dirt version and super moto? Is it just tires or also other specs?
Allex   1 GW
1 GW
Post by Allex » Feb 28 2018 9:11am
Hyena wrote:
Feb 27 2018 4:05pm
Chilly ride Alex!
Yes, they changed the headlight to the Alu one - much better one. And due to regulations it is always on as soon as you turn the key.
Post by efMX Trials Electric Freeride » Feb 28 2018 12:05pm
motomoto wrote:
Feb 27 2018 8:03pm
efMX wrote;
it would be interesting to see how much noise is coming from the chain drive and how much is from the cooling fan.. this could be done with a simple experiment by removing the chain master link, taking the chain off temporarily and revving the motor up to high rpm so that you could hear how much noise the fan makes without the chain drive.. of course you will not get rid of the cooling fan noise even with a belt drive conversion.. is the liquid cooled golden motor the same size?? that could be a nice upgrade to the bike, allowing for higher continuous power, less overheating on long steep climbs and even quieter operation.. how accessible is the fan blade?? it may be easy to remove the fan cover and then remove the fan blade temporarily to see how much noise is coming from the primary belt drive alone.. of course, do not run the motor for very long without the fan cooling, just enough for the noise level experiment.. leaving the noise from the primary belt drive only would give an idea of the sound level with a secondary belt drive conversion.. :idea:
LeftieBiker   1 kW
Post by LeftieBiker » Mar 01 2018 1:19am
sunrise wrote:
Feb 28 2018 2:29am
Are you talking about the Light Bee or another bike? The Sur Ron weighs about 80lbs with the battery removed - I asked Luna for the battery weight and they guesstimated 30lbs.
Rix   100 GW
Post by Rix » Mar 01 2018 8:27am
Skaiwerd wrote:
Feb 26 2018 4:23pm
Obviously those in the know won’t buy here.
I bet that was the same A-hole that was selling them for 12K on ebay a while back. I emailed that guy and asked what his deal was, never responded.
jamilon01   100 µW
100 µW
Post by jamilon01 » Mar 01 2018 9:48pm
Doesn't look like the Sur-Ron has a rim lock at the rear?
Has anyone had issue with tire slippage or tearing out stems with lower pressure?
Regards,
Rix   100 GW
Post by Rix » Mar 01 2018 11:36pm
jamilon01 wrote:
Mar 01 2018 9:48pm
Regards,
If PSI gets below 18, there will be slippage. I have ran 19, 18, and 17MC wheels on all of my ebikes. I had this happen once after crossing a creek with 15PSI in my tire. Tore the valve stem right off the tube. Also just recently happened to my dad.
Aebrennan   100 W
Post by Aebrennan » Mar 02 2018 5:09am
48v battery weighs 10kg, 48v bike complete weigh s 50kg
60v battery weighs 12kg, 60v bike complete weighs 52kg
No rim locks on either rims.
1000kms so far with no issues bar a puncture,and wearing out rear tyres.
Tyres are something between MTB and MX casing. Heavier than MTB but half the weight of a MX tyre. Tubes are MTB duty.
Allex   1 GW
1 GW
Post by Allex » Mar 03 2018 6:06pm
Sur-Ron with a 60V battery vs NYX with Adaptto mini-e 20s battery and mxus 3000 4t motor on 24" Peaking 5,7kW. They are quite even during take off but NYX overtakes due to higher voltage. NYX pulls harder after 30-40km/h thx to 20s battery
1:17 you have a good look at how both bikes start. Now the Bee had about 30% left on the battery while NYX still had around 50%
Thx Sweden_Rob for video footage!
Rix   100 GW
Post by Rix » Mar 03 2018 7:12pm
Good stuff Allex, thanks for posting the vid.
