Sur-Ron - New Mid drive Bike
Nice. It should last a long time in the snow. Maybe you can clear your driveway with it?
Isn't there a raising link available for the back end? That would sharpen up the steering.
Maybe 19S battery charged at 4.1v will work fine with stock X controller? That would be really coolJuiceMeUp wrote: ↑Nov 04 2020 2:27amPulled apart a couple of the stock controllers, gutting them to house the Nuclear controller. The capacitors are rated to 80V form memory. Didn't bother looking up the spec of the mosfets. Fell under my planned 18S (75V) application. Wouldn't go beyond that though.
Walking on the edge there. But hey, that's where the fun is.andrenoites wrote: ↑Jan 06 2021 2:10pmMaybe 19S battery charged at 4.1v will work fine with stock X controller? That would be really cool
Have yourself a spare controller on hand so your bike isn't down for too long.
I was personally underwhelmed doing voltage mods to the stock controller. Bit of extra top end speed but no additional torque on acceleration.
Sounds right. The controller amps would stay the same, so torque wouldn't change. Just top speed. Should go 12% faster with 18s. 50 mph?JuiceMeUp wrote: ↑Jan 06 2021 5:38pmWalking on the edge there. But hey, that's where the fun is.andrenoites wrote: ↑Jan 06 2021 2:10pmMaybe 19S battery charged at 4.1v will work fine with stock X controller? That would be really cool
Can you make a bridgeport tire on your bridgeport mill? What size is that, does your wheel have the little safety ridge, do you have to use a sealant of any sort, what pressures do you run? just a couple of questions3DTOPO wrote: ↑Jan 05 2021 7:48pmSup y'all!
So after over 2,300 tubeless miles it was time to replace my trusty Bridgeport M403 with the newer M203.
The first tubeless conversions I had to use a strap around the tire to get enough of a seal for the tire to inflate. It really was the most pain-in-the-ass task in the whole procedure.
Welp, this time I removed the the spoke protector rubber and used a narrow strip of gorilla tap in the U-channel. I then added another slightly narrower band in the U-Channel over that to kind of fill it in. Then one more band on top of that the full width of the rim.
This gave me a good enough seal to eliminate the need for using the strap! Filled right up with just an air compressor. It's such an easy process now I could not recommend going tubeless enough.
That would definitely sharpen things up and probably add some spring rate too.
Then perhaps slide the forks up in the clamps as far as possible.
Well, I'm not sure but I think the power will also increase with voltage W=V x Ampn2mb wrote: ↑Jan 06 2021 5:41pmSounds right. The controller amps would stay the same, so torque wouldn't change. Just top speed. Should go 12% faster with 18s. 50 mph?JuiceMeUp wrote: ↑Jan 06 2021 5:38pmWalking on the edge there. But hey, that's where the fun is.andrenoites wrote: ↑Jan 06 2021 2:10pmMaybe 19S battery charged at 4.1v will work fine with stock X controller? That would be really cool
Heh, well, shows you where my heart is. Sorry I meant Bridgestone.thoroughbred wrote: ↑Jan 07 2021 8:01amCan you make a bridgeport tire on your bridgeport mill? What size is that, does your wheel have the little safety ridge, do you have to use a sealant of any sort, what pressures do you run? just a couple of questions3DTOPO wrote: ↑Jan 05 2021 7:48pmSup y'all!
I'm glad I'm not the only one with the swingarm smear from the pesky migrating kickstand.
Here is a complete list of what I used:
Gorilla Tape: https://amzn.to/3nn5rrt
NoTubes Tire Sealant: https://amzn.to/3s3t6k9
Valve stems: https://amzn.to/3hTYpct
Injector: https://amzn.to/2LziGrJ
Bridgestone M203 https://amzn.to/3nooJwH
Also a tool to remove the valve from the stem. My valve stem cap has a tool built in.
Use 2-4oz of sealant per tire - bottle above is 16oz.
You can get by without the injector and valve removal tool if you pour directly in the tire but I think they are worth it.
Just let me know if you have any questions.
It's is the stock wheel, not sure what you mean about safety thing.
Any idea how to seal the rim lock?? I run rim locks on all my wheels and I'd love to go tubeless but don'y know how I'd seal that. Thoughts??3DTOPO wrote: ↑Jan 07 2021 4:22pmHeh, well, shows you where my heart is. Sorry I meant Bridgestone.thoroughbred wrote: ↑Jan 07 2021 8:01amCan you make a bridgeport tire on your bridgeport mill? What size is that, does your wheel have the little safety ridge, do you have to use a sealant of any sort, what pressures do you run? just a couple of questions3DTOPO wrote: ↑Jan 05 2021 7:48pmSup y'all!
Also, what pressure are you running? Any worry about spinning the tire?
Interesting. Wonder what fork they are using? I'm super happy with my Manitou Dorado Pro fork, but it wasn't a cheap upgrade. Would be nice to see a better fork come from the factory.3DTOPO wrote: ↑Jan 08 2021 7:08pmNew 200mm fork from Sur-Ron:
https://www.facebook.com/groups/9120075 ... 441384013/
My understanding (and of course I could be wrong) was that rim locks are primarily to prevent valve stems from tearing. That is not possibly an issue with tubeless.
I think around 12psi and spinning has never been noticeable let alone an issue.
Rim locks are to keep the tire from spinning on the rim, which does indeed rip the stems off. However, even spinning a tire without a tube in it is not great. At the minimum you don't move forward (usually when climbing or accelerating) and at worst you break the rim seal and get a flat.
At 12psi on a Sur Ron you're probably ok. Not really sure. I'm running 8-10psi but I have rim locks so I can't really say what would happen without them. If you've got that many miles on your setup it obviously works, and I love the idea of no tube. I just think I'd have to give up the rim locks. I might try my new 21" wheel tubeless before I install the rim lock and see what happens at 8-10 psi. I can always add it and a tube later.
I've limped home on flats (before going tubeless) with 0psi so I know about spinning.
I'd expect it to slip a little which like I said is imperceptible at 12psi. Might be a bit more of a problem at 8, but I don't know. If I had to guess it's probably some slippage not outright spinning.
Slipping shouldn't break the seal. Low PSI and hard bumps can cause burping with all tubeless tires that use sealant however.
What is possibly not OK?
OK just being that the tire will stay on the rim. At that psi I've not had any issues. As for spinning and not breaking a seal, I'm skeptical, but maybe.
If you really need to run such low pressure, "Tubliss" is probably better for you - supposedly you can run all the way down to 0, though I've never used it.
Two of my friend’s did the tubliss conversion for the back,and they come back at zero psi often.1 converted back and the other is in the process of converting back.Regular old rim lock and tube works the best in my opinion.So much easier changing tires.
Pulling the tire off the rim enough in a corner for it to go (nearly)instanly fat.
I run a Tubliss system on the motorcycles and SurRon but I run Stan's tubeless on my mtbs (29ers w/ 2.35" tires so ballpark SurRon sized.) Anything below 12-ish psi on those and I can burp air or rocks/roots will mess up the bead seal. The mtb tires are thinner sidewall than a moto tire so the moto tires might resist this more? But I don't even make 1hp on the mtb so the SurRon might do it easier?
I don't think you'd spin tires w/ Stan's tubeless. The sealent 'glues' the tire on a bit when your first mount.
I've ridden over 2,300 miles and as I stated its never been an issue so its curious that someone would say that I might be OK.
Terrain is different? Some trails here I never have a problem. One had little root bits sticking up that are fond of messing up tire beads. Running across a creek, clipping a small rock, and getting dirt in the bead wsa a fun one too. Though by in large I mostly get flats in wrecks where I slide. Stan's is still awesome and I'll never go back to tubes on a mtb. Pinch flats are a thing of the past. Can't hurt to try it on a SurRon.
I'm running a wider rear wheel on the SurRon now so can use Tubliss and it's great to go down to trials-bike type pressures. I haven't had great luck w/ it in on a front yet though. Never could get it to seat and hold air. Never a problem on the rears though.
