it works pretty good...
California Ebike BA130 Bafang chain ring adapter
26" 1and1/8 straight steerer Boxxer front suspension
Magura MT-5 quad piston hydraulic disc brakes
KHE Mac26 × 2.30 "Park" 120psi tires
Chris King 36h disc front hub
Chris King 1 and 1/8" headset
Rohloff, 36h threaded spindle, disc brake version
Rohloff 180mm rear rotor, generic 203mm front rotor
Buck and Wing "Quill" saddle
27.2mm RaceFace Evolve aluminum seatpost
Deity nylon pedals
generic aluminum stem and bars
Gates CDX 50 tooth front, 20 tooth rear, 113 tooth belt
Luna Cycles 48V "Whale" battery with 17.5ah
Bafang BBS02 48V 750W motor kit
E-Rad brake sensor throttle cut-off
Swobo Folsom 26'er aluminum frame
SAS Halo 36h rims
Sapim spokes
Pitlock 10mm axle nuts
(about 52 lbs.)
Deity nylon pedals
SAS Halo 36h rims
Sapim spokes
(about 52 lbs.)
