two_shirts
- Joined
- Sep 30, 2017
- Messages
- 4
I have a commuter set up based on a 29ER hardtail with a BBSHD and a Luna Eclipse chain ring.
After about 4,000 km, when pulling away from the lights yesterday at high power, my chain was completely jammed on the Eclipse.
Basically, one tooth was substantially bent laterally, catching the chain. See picture.
I have managed to tap it back square with a hammer, and the chain is again flowing freely. I am assuming it is rideable, although I haven't tried yet.
Closer inspection of that tooth showed what I believe to be quite a bit of wear - the tooth is somewhat thinner than some of the others, and it was rough on the back face - i filed it smooth.
I am assuming it is worn out and needs replacing though maybe not urgently.
I am after some advise on what to do.
My setup has been very hard on chain wear, and consequently cassette wear too. I am on about my fourth chain and have to replace the 11 ring on my cassette after about 1,000km. I am suspicious that the Eclipse may be part of my issue. It seems to have much longer teeth than any other chain ring I've seen, and I can imagine that this may be not good for the links of the chain as they have more to rub on as they run over it - not sure about this, it is a theory!
Any other experience of similar?
I am thinking I would be better replacing it with a Lekkie Bling Ring, just because it looks more conventional, and should last longer. Thoughts anyone?
Thanks
Thanks
