My Bafang Ultra Mountain Bike! Frey AM1000
joq3   10 mW
Re: My Bafang Ultra Mountain Bike! Frey AM1000
Post by joq3 » Apr 12 2019 4:26am
Got an update on my torque issue.
Sent down the motor to Bafang in Netherlands and they found out that the torque sensor was broken. And they will send a new motor as a replacement.
Thank you for the help when looking for the issue. I hope to experience the bike as it should be!
Sinbord1981   10 W
Post by Sinbord1981 » Apr 13 2019 7:21am
Just about to pull the pin on this bad boy! I read this whole topic top to bottom and tried to pull all the best bits in to my spec. The only thing not there is the improved thumb throttle but Grace @Frey said they can only supply the standard one. She's been really responsive to all my questions too!
I'm paying extra for the gear sensor, for the motor. Is the gear sensor necessary do you think and/or should it really be standard?
I'm also going for an extra battery. What are the chances of improving tech meaning that a higher ah 52V will come out soon and is there a risk that if I only bought one and something went wrong with it wouldn't be able to get another, or would have to get one made bespoke? That could be a whole world of pain. I've actually gone for the 48V 21ah rather than the 52V 17.5ah owing to the greater energy density (should get better range but perhaps lesser top speed and ultimate performance, right?).
I'm based in the United Kingdom by the way - not sure how many others in the UK have bought a Frey AM1000 yet - if local to me I wouldn't mind having a look. I'm in Sussex near Gatwick.
SunnyDay1   1 mW
Post by SunnyDay1 » Apr 13 2019 8:00am
I think the gear sensor is a must have for the high torque motor, the extra cost is minimal.
Razerr   1 mW
Post by Razerr » Apr 13 2019 8:42am
Sinbord1981 wrote:
Apr 13 2019 7:21am
Nice list!
I am also thinking about to buy one and read the topic top - bottom.
How do you choose the size? How tall are you? Why no SRAM ex1 on the list? I read a lot of good things about it.
I live in EU and the only thing that is holding me back is customs...
Sinbord1981   10 W
Post by Sinbord1981 » Apr 13 2019 9:07am
I gave my height & weight to Grace and she suggested the Medium. I then looked up all the geometries for the medium and checked it all against my existing Yoeleo M91 Hard tail MTB which fits me like a glove. Pretty much exact same apart from the chain stays that are a bit longer. Anything bigger than the Medium looks seriously huge! I’m 5’ 8”.
I think ex1 is quite a lot more and Shimano M8000 is very good kit already.
I bought my Yoeleo MTB direct from China (frame and wheels only and I made the bike up) and had a very good experience. I’d also had another set of deep section rims off them for my road bike and it was very nice quality.
I do a lot of cycling and love anything that’s got wheels on it!
Sinbord1981   10 W
Post by Sinbord1981 » Apr 13 2019 9:12am
Also with the SRAM ex1 you’ve only got 8 ratios so you loose the close ratio-ness of the drive (XT is 11 speed). Range is the same but each gear change is a more significant jump in gear ratio. For me as big cyclist already I like to cycle with a fairly high optimal cadence (90-ish). Probably less of a factor with a motor but hey ho!
Razerr   1 mW
Post by Razerr » Apr 16 2019 2:12am
Sinbord1981 wrote:
Apr 13 2019 7:21am
Any update you got for us? Did you order?
Sinbord1981   10 W
Post by Sinbord1981 » Apr 16 2019 10:13am
Razerr wrote:
Apr 16 2019 2:12am
Yep. Order placed today. They’re waiting on a new batch of the Rockshox Lyric forks to come in but should be with me by end May
Richard N   100 W
Post by Richard N » Apr 16 2019 12:18pm
Does anyone have any input on the charger that comes with the Frey bike, I'm talking about the 54.6V 5A Smart Charger for the AM and HT 1000s. What makes it 'smart?'
Razerr   1 mW
Post by Razerr » Apr 17 2019 5:27am
Sinbord1981 wrote:
Apr 16 2019 10:13am
Razerr wrote:
Apr 16 2019 2:12am
Nice, I still have doubts about the battery voltage...can someone help me here :-) what are the cons at 52v?
Hardcore   100 W
Post by Hardcore » Apr 17 2019 10:39am
48v battery is about 10% more Wh and about 8% less max. power. But in my experience, the 52v will give you less voltage drop under high load and more consistent power 'feel' throughout the full use of the pack.
BigBoris   1 µW
Post by BigBoris » Apr 17 2019 12:18pm
Hello, I ordered a Top of the line Frey 1000 watt duel suspension bike. My original reason for buying it was to commute to work. When it came I realized that it was too big of a bike for my to keep in my office. I would like to sell it, please email me if you are interested. It has 20 miles on it.
Bafang Ultra 48V 1000W mid drive system with throttle;
48V 21AH Samsung 35E cells powered big capacity battery;
ROCKSHOX YARI 160mm air suspension fork;
ROCKSHOX DELUXE RL rear suspension;
MAGURA MT5e 4-piston hydraulic brake with power cut function for ebike use;
SHIMANO XT M8000 11 speed group set;
MAXXIS 27.5*2.8" mountain tire.
1 extra battery
bugnut   1 mW
Post by bugnut » Apr 17 2019 4:03pm
BigBoris wrote:
Apr 17 2019 12:18pm
1 extra battery
Where and how much?
Razerr   1 mW
Post by Razerr » Apr 18 2019 1:55am
Hardcore wrote:
Apr 17 2019 10:39am
Are there battery readout problems on the Bafang screen, can it handle 52v? Less voltage drop sound like a more pleasant ride.
I going to buy 2 batteries so 10% less Wh isn't a problem.
BigBoris wrote:
Apr 17 2019 12:18pm
Where do you live, whats frame size and how much do you ask?
FREYebikes   100 W
Post by FREYebikes » Apr 18 2019 2:48am
Hello,
Here we would like to share with all you how to use the gear set better.
Best condition use guide for 11 speed cassette and chain.
Green: best starting and riding level. The cassette and chain life is longest, and riding effect is the best.
Blue/Yellow/Red: under the speed showed in the graphic, cassette and chain is in the best condition, minimal wear.
Color meaning: Risk level of cassette and chain.
How about your use tips? you can share with us!
Hardcore   100 W
Post by Hardcore » Apr 18 2019 1:01pm
Razerr wrote:
Apr 18 2019 1:55am
no problems reading the voltage on the screen and yes it is a pleasant ride. I have another 48v hub and I can certainly feel the battery reaching LVC while the 52v on the frey keeps more power till LVC
cheers
Razerr   1 mW
Post by Razerr » Apr 18 2019 3:45pm
Hardcore wrote:
Apr 18 2019 1:01pm
Razerr wrote:
Apr 18 2019 1:55am
cheers
Thanks for the info, I am sold for 52v :-)
Sinbord1981   10 W
Post by Sinbord1981 » Apr 18 2019 5:46pm
Razerr wrote:Thanks for the info, I am sold for 52v :-)
I was having the same dilemma but opted for two of the 48V21ah batteries with my AM1000. Surely you’ll have less potential peak power with them but a longer burn given the fact that they’ve got 14% more capacity in the first place (48x21=1,008 WHr vs 52x17=884). Whilst the voltage on the 52 is obviously higher than the 48 it will drop faster at the same drain level.
....or have I got this all wrong and I should also change for the 52V17ah.
Are you about to order an AM1000 Razerr?
Razerr   1 mW
Post by Razerr » Apr 19 2019 1:58am
Sinbord1981 wrote:
Apr 18 2019 5:46pm
Yes i do, pretty close to make the order.
a friend of mine rides a BBSHD and also mentioned the fast drop of power with the 48v, the voltage drop was a lot smoother when he swapped to a 52v battery. Yeah you got more miles with the 21ah but still plenty miles with double 52v 17ah batteries...
It is a difficult choice because more miles per battery is attractive, but the way the battery behaves when discharging makes for a better ride. I guess..
Sinbord1981   10 W
Post by Sinbord1981 » Apr 19 2019 6:10am
I’ve already placed my order with Frey and paid for the AM1000 with two 48V21ah batteries but I have asked whether I can switch to two 52V17ah batteries instead, obviously with the correct charger for the 52V pack. I’ll let you know how I get on. It is a difficult one and I guess six of one and half a dozen of the other in terms of weighing it up. Thanks.
Razerr   1 mW
Post by Razerr » Apr 19 2019 2:04pm
Now the frame size. I am 5.9 feet (+-181cm) I was thinking of the large variant.
I would like some opinions of the frey bike owners.
SunnyDay1   1 mW
Post by SunnyDay1 » Apr 19 2019 3:35pm
Razerr wrote:
Apr 19 2019 2:04pm
Go with the medium frame size if you're 5'9" tall, you will regret it if you don't.
SunnyDay1   1 mW
Post by SunnyDay1 » Apr 19 2019 3:38pm
Sinbord1981 wrote:
Apr 19 2019 6:10am
I would go with the 52v batteries, its worth the extra cost. I don't think FREY will have any problems upgrading your order, I went through the same thing making battery decisions.
Razerr   1 mW
Post by Razerr » Apr 20 2019 2:31am
SunnyDay1 wrote:
Apr 19 2019 3:35pm
Razerr wrote:
Apr 19 2019 2:04pm
181cm is 5'11" i think.
https://www.calculateme.com/height/conv ... hes/181-cm
Still the medium?
SunnyDay1   1 mW
Post by SunnyDay1 » Apr 20 2019 6:29am
Razerr wrote:
Apr 20 2019 2:31am
SunnyDay1 wrote:
Apr 19 2019 3:35pm
Razerr wrote:
Apr 19 2019 2:04pm
Still the medium?
You are correct, 181 cm is 5'11". I'm 5'9" and the medium works great for me. If the medium was any larger it would be too big for me.
Maybe another AM1000 owner will chime in on this post for you.
