My Bafang Ultra Mountain Bike! Frey AM1000
18650   10 mW
Re: My Bafang Ultra Mountain Bike! Frey AM1000
Post by 18650 » Mar 22 2018 2:19am
Still silence about riding experience (power, range)?
FREYebikes   100 W
Post by FREYebikes » Mar 22 2018 8:27am
Thank you for your commends, we will take care about more possibility in future design on bike frame.
Z0RR0 wrote:
Mar 20 2018 11:47am
Since we're talking design and versions and whatnot, I would LOVE to see you guys (or anyone) come up with a more modern geometry, with more head angle, and the signature "kinked down tube that premium MTBs have.
Essentially look at what Haibike is doing in terms of designs, but not quite as high-end and with the Bafang Ultra instead of the less powerful europe-compliant motors.
luna5k   100 µW
100 µW
Post by luna5k » Mar 22 2018 9:16am
Would it be possible to have a list of specifications for the $2000 level bike?
Adova   10 µW
10 µW
Post by Adova » Mar 22 2018 7:27pm
luna5k wrote:
Mar 22 2018 9:16am
Sure - I don't think they would mind as this is the same configuration I think anyone would get at this price point (at least at the time of my order):
Bafang Ultra 48V 750-1000W mid drive system with throttle;
48V /17.4AH battery;
ROCKSHOX RECON 150mm air suspension fork;
ROCKSHOX MONARCH rear suspension;
TEKTRO HD E725 4-piston hydraulic brake with power cut function for ebike use;
SHIMANO ACERA 8 speed group set;
CST 27.5*3.0" mountain tire, MAXXIS 27.5*2.4” available for option;
I added the lights and extra charger as well as the 21AH battery.
luna5k   100 µW
100 µW
Post by luna5k » Mar 23 2018 3:22pm
Adova wrote:
Mar 22 2018 7:27pm
luna5k wrote:
Mar 22 2018 9:16am
That’s very helpful, thanks!
FREYebikes   100 W
Post by FREYebikes » Mar 24 2018 12:06am
Hi,we made a video, anyone interested can have a look at below link:
https://youtu.be/eFKbGP_3QRY
Drop Dead Fred   100 W
Post by Drop Dead Fred » Mar 24 2018 1:54am
FREYebikes wrote:
Mar 24 2018 12:06am
Hi Ivy,
Nice video!
I wanted to let you know if you planned on anyone racing one of your bikes it needs to be set to 750w and have no throttle to be able to compete.
FREYebikes   100 W
Post by FREYebikes » Mar 26 2018 5:48am
Thank you for your info. We will take care about it. :)
Drop Dead Fred wrote:
Mar 24 2018 1:54am
FREYebikes wrote:
Mar 24 2018 12:06am
Hi Ivy,
Nice video!
robocam   10 kW
Post by robocam » Mar 27 2018 4:01pm
What do you mean by "modern geometry?" The head angle is already relatively slack at 66.5 degrees. It's even slacker than that of the Specialized Enduro 29. What do you mean by "more head angle?"
What do you mean by "kinked down?" Are you referring to an S-shaped downtube? If so, what are its advantages? It seems that a straight downtube is a more logical choice for the battery. Maybe you can show a picture of what you're referring to.
Z0RR0 wrote:
Mar 20 2018 11:47am
robocam   10 kW
Post by robocam » Mar 27 2018 4:20pm
If I hadn't bought it right as winter started, I'd have a lot more to say about it =) Think of it as slightly less powerful than a BBSHD, though my BBSHD runs at 52V, so I can't really make a direct comparison, and the Frey AM1000 has a 48V/21Ah battery (1 kWh), so you have a general idea of how far it can go based on others with similar capacities.
I've seen a GPS-verified test on the Luna Mighty Mini 6Ah 30Q pack on a folding bike, and it went 24.2 miles at ~15mph. Depending on speed and weight, you're going to have a huge range of numbers but whatever numbers you get, they'll probably be better than those of other bikes with smaller batteries.
18650 wrote:
Mar 22 2018 2:19am
Still silence about riding expierience (power, range)?
FREYebikes   100 W
Post by FREYebikes » Mar 28 2018 8:18am
Hi, long time no see you here :)
robocam wrote:
Mar 27 2018 4:01pm
Z0RR0 wrote:
Mar 20 2018 11:47am
Sduro Ultra   10 µW
10 µW
Post by Sduro Ultra » Mar 28 2018 5:16pm
Hey guys,
i am new member here, but i red some threads before. my bike is a haibike sduro with 150mm/150mm suspension and 27,5" x 2.8" plus magura mt5.
i have a bafang ultra with a 52v 17,5a battery and a 4a charger which i modified, because it was very loud (put two 4000 1/min fans in instead of 1 8000 1/min fan).
i already installed the programming software and changed the "spd0 start(kg)" and "return(kg)". it worked well. i want to change a bit more, i just started. when i stop pedaling the motor pushes about a second still forward. i want it to react more spontaniously.
i think the "0 speed boost time" [120] (x10ms) will change this behavior. do you agree with me?
can someone help to get the best configuration?
thanks for exchange
woggs1   1 mW
Post by woggs1 » Mar 28 2018 7:59pm
Sduro Ultra wrote:
Mar 28 2018 5:16pm
Hey guys,
thanks for exchange
I thought Haibikes used Bosch or Yamaha motors?
Tom L   1 kW
Post by Tom L » Mar 28 2018 8:18pm
Yeah they do.
Wrong place to post Sduro. You'd be better off starting a new topic. This one is unrelated.
hoojsn   1 W
1 W
Post by hoojsn » Mar 28 2018 11:50pm
woggs1 wrote:
Mar 28 2018 7:59pm
Sduro Ultra wrote:
Mar 28 2018 5:16pm
Hey guys,
thanks for exchange
I look at Haibikes website, they didn't offer bike with Bafang Ultra M620 or their new range of product? Bosch or Yamaha couldn't hold a candle to the performance to the Ultra and on different league.
Sduro Ultra   10 µW
10 µW
Post by Sduro Ultra » Mar 29 2018 2:54am
I modified the frame to fit and weld the bafang motor plate in and i am not the first one doing this with a haibike sduro. Its a nice conversion.
Have a good ride
hoojsn   1 W
1 W
Post by hoojsn » Mar 29 2018 4:11am
Sduro Ultra wrote:
Mar 29 2018 2:54am
20180319_173012-02.jpegI modified the frame to fit and weld the bafang motor plate in and i am not the first one doing this with a haibike sduro. Its a nice conversion.
Have a good ride
Nice, where do you bought your Kit from? If from Luna for Ultra Ludicrous 2500 watts, you might want to follow Karl
https://electricbike-blog.com/2017/11/2 ... #more-6836
Sduro Ultra   10 µW
10 µW
Post by Sduro Ultra » Mar 29 2018 6:29am
I know this guide, but karls setting wont fit a standart ultra and lets lots of questions open in setting parameters
hoojsn   1 W
1 W
Post by hoojsn » Mar 29 2018 9:56am
Sduro Ultra wrote:
Mar 29 2018 6:29am
Yes Karl setup is not suitable for our standard Ultra. I didn't reprogram mine since the current setup is still suitable for me. Did your motor came with steel drive or nylon? Bafang sent me the replacement steel drive plus a new set of the display.
Sduro Ultra   10 µW
10 µW
Post by Sduro Ultra » Mar 29 2018 11:33am
hoojsn wrote:
Mar 29 2018 9:56am
Sduro Ultra wrote:
Mar 29 2018 6:29am
I did not open my motor yet, so i dont know. Should i open it? Is nylon bad? I got it from cnebikes.com
I lowered the shut off times and it worked well to get it more spontaniously. But i am not done with the programming
hoojsn   1 W
1 W
Post by hoojsn » Mar 29 2018 11:43am
Sduro Ultra wrote:
Mar 29 2018 11:33am
hoojsn wrote:
Mar 29 2018 9:56am
Sduro Ultra wrote:
Mar 29 2018 6:29am
I lowered the shut off times and it worked well to get it more spontaniously. But i am not dosteelne with the programming
If you able to open, than take a peep inside, otherwise talk to supplier cnebikes. It will be good that they request the steel drive for you. Understand Luna, Frey and others bike maker come with steel. Steel will be more durable, as for my case I take it as spare in case the nylon kaput.
Daxxie   10 W
Post by Daxxie » Mar 31 2018 8:52am
Where did you get that information?
My Bafang Ultra Ludicrous from Luna has a nylon gear.
I asked them before ordering and they said their Ludi version has NO steel gear.
hoojsn   1 W
1 W
Post by hoojsn » Mar 31 2018 11:50am
Daxxie wrote:
Mar 31 2018 8:52am
You had been cheated by Luna. Especially for "Ludicrous" it must come with Steel Drive because of Peak 2500 watts. I remember reading somewhere from Karl article. You can refer to Karl Article on Max Ultra. Without steel your Nylon will melt like butter. https://electricbike-blog.com/category/ultra-max/
Luna Ultra casing for Apex come with magnesium which was 2lbs lighter than standard. I am not sure whether your motor had this improvement too..
fechter   100 GW
Post by fechter » Apr 01 2018 2:11pm
Gear destruction is pretty dependent on motor temperature. If the motor stays cool, the gear can handle a lot of power without turning to peanut butter. The BBS02 over driven had a real tendency to do this.
We'll have to just see how the nylon gears hold up. If they start failing, I'm sure somebody will make a steel version.
hoojsn   1 W
1 W
Post by hoojsn » Apr 02 2018 12:50am
fechter wrote:
Apr 01 2018 2:11pm
Why wait, when the steel gear upgrade were already available for free?
