My Bafang Ultra Mountain Bike! Frey AM1000
Ivanovitch_k   10 W
Re: My Bafang Ultra Mountain Bike! Frey AM1000
Post by Ivanovitch_k » May 19 2018 5:47am
Cruncher123 wrote:
May 19 2018 1:29am
Placed an order for the base bike - about 1 month delivery estimate.
But I have a few questions:
Curious if I should ask/request any upgrades? Is it worth upgrading the rear shock or front fork? (I plan to ride some single track.but not do large jumps etc)
suspensions upgrades are always nice. However, I saw someone mention they upgraded to Sram EX-1 groupset (e-bike reinforced derailleur, chain, and 8-speed cassette) from Frey (to be confirmed).
IMO, this is the better upgrade this bike can have, the stock 11-speed XT is not rated at all for this much torque... If I recall, someone in this thread already experienced cassette failure.
Cruncher123 wrote:
May 19 2018 1:29am
I did request a couple of spare derailleur hangers. I also asked about a second wheelset so I could quickly convert to more road-friendly tires, but they weren't able to oblige. Any recommendations for a suitable wheelset/tire/cassette/hub combo and where a good place to get them from is? Will 29ers work?
DT Swiss Hybrid series are very nice, H1900 for the entry level, H1700 middle, or HX1501 for higher end, ranging from 300 to 800 eur from german sites like bike24 or bike-discount, they both have cheap worldwide shipping. These wheels all feature hubs with oversized bearings, hardened steel freehub bodies ( --> no spline-gouging under extreme torque), oversized spoke interfaces, reinforced spokes and much stronger rims. They are available in both 27.5 and 29, each with different rim widths. AM1000 frame compatibility with 29er will have to be checked tho.
Cruncher123 wrote:
May 19 2018 1:29am
Has the ill-fitting bearing issue been sorted on newer bikes? (ie, someone reported a suspension bearing couldn't be fully seated and left 1-2mm gap that might allow dirt/debris to enter?).
the bearing itself is seated properly, the bolt covering it too long resulting in the gap. Previous AM1000 did not even have this cover on the bearing-retaining bolt. I don't know if it is resolved.
Cruncher123 wrote:
May 19 2018 1:29am
Should I enquire about the smaller 40T chainring? I plan to be climbing some decent hills and don't really need higher top speed.
you would be better served by any aftermarket 130BCD chainring like the narrow-wides from RaceFace as Bafang ones a stupidly heavy. For climbing ability I would even go to a lower teeth count.
Cruncher123 wrote:
May 19 2018 1:29am
I'd like to do some night riding on trails and am considering the Fisher Fab light https://lunacycle.com/fisher-fab-house- ... ike-light/ Is this light something that could be powered from exising wiring, or would I have to splice new wires?
existing wiring will not offer the connector of this lamp. The motor does suplies a 6V light line controlled by the Display buttons / light sensor but it's current rating and voltage are too low for this lamp. You'll have to tap into the main power line running from the top of the downtube (where the battery connector is) to the motor (terminated by an Anderson connector). Not an hard job IMO.
Cruncher123 wrote:
May 19 2018 1:29am
Finally, does this bike have a GearSensor? And if not, do people recommend adding one?
the motor does have a Gear Sensor input. Needing it depends on if you can get in the habit to use the ebrakes as a clutch on gear shifts, otherwise you don't need it. Repeated shifts under power will lead to (very) premature chain failure. With the much lower torque BBS02, I snapped multiple times the same KMC X11-e (e stands for e-bike) chains that Frey use. The connector from the motor to the gear sensor will have to be checked, it's not a circular Higo as on other BBS systems.
BBS'ed Radon ZR Team 8:
BBS02B 750W - DPC750C - 48V 17.5Ah GA shark - 11 spd 11-40 Shimano XT, 42T N-W Precialps CW, KMC X11e chain, Gearsensor, XT RD, XTR Shifter, F Saint Brake, R XT Brake, RT99 200/160 Discs, magnetic shutoff, DT Swiss X1900 QR9 wheels, Manitou M30 air fork, 2.4" slick balloon schwalbe Super Moto X tires @2 bars, Suntour NCX suspension seatpost, ergon SFC3 saddle, ergon GP3 grips, Supernova M99 Pro + E12 Taillight
Ivanovitch_k   10 W
Post by Ivanovitch_k » May 19 2018 5:56am
could someone please measure the rear thru-axle bolt ?
I need to find a compatible one:
I know it's M12 x 1.5mm pitch, but i'm looking for the thread length and total length.
thanks 8)
Cruncher123   10 mW
Post by Cruncher123 » May 19 2018 2:55pm
Thank you for your detailed and well-reasoned responses!
Ivanovitch_k wrote:
May 19 2018 5:47am
Cruncher123 wrote:
May 19 2018 1:29am
Cruncher123 wrote:
May 19 2018 1:29am
Cruncher123 wrote:
May 19 2018 1:29am
Cruncher123 wrote:
May 19 2018 1:29am
Cruncher123 wrote:
May 19 2018 1:29am
Cruncher123 wrote:
May 19 2018 1:29am
Hardcore   100 W
Post by Hardcore » May 20 2018 1:52pm
Hi all,
just received my AM1000 as well. I have the SRAM Ex1 groupset on there and the gears are plentiful to go up steep hills/stair while the smallest cog still allows 50 km/h speed with pedalling. Soon the gear sensor will be installed.
Cheers,
H
Cruncher123   10 mW
Post by Cruncher123 » May 20 2018 4:10pm
Hardcore wrote:
May 20 2018 1:52pm
Hi all,
Cheers,
H
Great to hear. I also upgraded to SRAM EX1. And I also plan to install a GearSensor. It would be great if you could post some installations tips/photos when you install it.
WalkinTarget   1 µW
Post by WalkinTarget » May 20 2018 10:09pm
This search for an ebike is going to be the death of me !! Back in February, I was all set on a Rip Current S, with a $2k budget that it fit in and no interest in looking at any other bikes. Fast forward to late April when I got serious about it and procured financing - my goal was to order at the end of April in the hopes that I could get the bike by mid-June for my 50th B-day. Yea, it was yet another mid-life crisis toy to get over the pain of hitting the big 5-0.
So at the end of April, the RCS went out of stock - on two occasions I had one in my cart - gave it a day to think about whether it was 'the one', and both times it sold out from under me. So I started doing research on other types of bikes, and after seeing these higher end bikes like the Frey .. well, hell, of COURSE I think I now want to buy one !! Note that before I wanted the RCS, I REALLY wanted the Hyperfat, and I'm pissed that I didn't get that bike, but the RCS was enough of a compromise that I could be happy with it.
So what do I see but this Frey AM1000, which in black pretty much looks like a full suspension Hyperfat ?!? I went ahead and contacted Ivy earlier today, and lemme tell ya, she REALLY wants me to buy this bike, like .. NOW. Shipping was a bit of a stunner ... I had no idea I was going to almost pay 1/3 of the bikes cost JUST for shipping !! But, here we are ... my original budget of 2k blown to hell, my adjusted for awesomeness new budget of $2,600 blown to hell ... and Ivy really wants me to buy this bike !! I need a part-time job to swing this deal .. but dayam, I am hot and bothered for a lime green/black paint combo that she said she can make happen.
Thank you for allowing me to vent. I need to give this some time to sink in. It's not easy plunking down that much cash and living with your decision. I know it will all go away once I receive it and take it for its first ride, but its making my stomach roll just thinking about it now.
Cruncher123   10 mW
Post by Cruncher123 » May 21 2018 1:03am
WalkinTarget wrote:
May 20 2018 10:09pm
Don't get carried away, there will likely be RipCurrent's back in stock before Frey can ship an AM1000 to you. Yes, Frey sells a nicer bike, but is it $2K nicer? (I think so, but the money.really isn't an issue for me). Honestly, my dream bike is this thing https://www.exess-bikes.de/index_en.htm, but they won't sell to the US.
There are other companies that offer similar bikes to the RipCurrent. Biktrix, Voltbike, M2S etc. Many are likely made in the same factory.
Honestly, I'm surprised Frey hasn't built a container-full on spec and shipped them over - air freight is very expensive. What they save on shipping could be used to lower the cost, or add higher-end components.
Mantsos   10 mW
Post by Mantsos » May 21 2018 2:29am
I am also going to upgrade to SRAM EX1 groupset (thank you guys, my wallet is now empty). That bike coming to be so expensive... :| I should get that my bike in June and I really hope I get something good. That bike is my dream bike.
WalkinTarget   1 µW
Post by WalkinTarget » May 21 2018 5:59am
Cruncher123 wrote:
May 21 2018 1:03am
I'm probably past the carried away point, but this too shall pass. Received a reply from Roshan at Biktrix - the Juggy is #2 on my personal wants and needs ebike list at this point, and I doubt that will change. The Juggernaut is a hell of a nice bike, so I wouldn't be disappointed at all in buying that. Was the Frey a better bike ?? Yea, it was. Was it a better bike for me ?? Doubtful, when 85% of my riding is a flat rail trail. But speed and performance is very addicting, so I was sucked into tossing big money at something that wasn't a good fit for me.
I agree with you - damn shame they couldn't ship a container over here and sell them at a reduced shipping rate. I'm very pleased with the bikes price, but surprised at the shipping costs.
Ivanovitch_k   10 W
Post by Ivanovitch_k » May 21 2018 11:09am
Cruncher123 wrote:
May 21 2018 1:03am
This bike is nice, but if I had to choose between the excess and the frey, I would still go for the frey.
The selling points of the Excess vs the AM1000 are the carbon frame and the dt swiss e-bike wheels. But, IMO, a carbon frame is not suited for an extreme torque platform like the bafang ultra :/ ...
Besides that, it's got shit-tier Hailong battery case, and an okey-ish sram GX (slightly more resistant than the shimanos XT, but nowhere near the EX-1).
Would they have gone EX1 (or better IGH like Kindernay / Rohloff) + Reention or even custom design frame battery + AL frame with a better & lighter build quality than frey (not hard, sorry Frey :lol: ), this would be a killer setup !
Cruncher123   10 mW
Post by Cruncher123 » May 21 2018 1:43pm
Ivanovitch_k wrote:
May 21 2018 11:09am
Cruncher123 wrote:
May 21 2018 1:03am
The sheer gorgeousness of it's appearance has me drooling - yes, some compromises were made, but as an overall package, I haven't seen anything that's even close at that price point (or any price point) with a 1000w motor.
The choices to date have been to accept a nicely-designed Euro emtb with 250/350w/36v battery or a rather inelegant/chunky Chinese frame with 1000w/48v. I reluctantly chose power, but I wanted both - and the Exess was as close as I could find.
I was hoping Luna would finally start selling the Apollo, but it's been months and no further word about it that I'm aware of.
efMX Trials Electric Freeride   1 MW
Post by efMX Trials Electric Freeride » May 21 2018 3:28pm
Cruncher123 wrote:
May 21 2018 1:43pm
Ivanovitch_k wrote:
May 21 2018 11:09am
Cruncher123 wrote:
May 21 2018 1:03am
on Luna's facebook group Eric said that they would be releasing Apollo within the next couple weeks (by end of may, early june??) and hosting a release party .. so should be soon, but I wonder how much they will cost.. looks kinda pricey ..
reference :
https://facebook.com/groups/11854571115 ... 5676630389
some ride & sk8 videos:
metacafe.com/channels/NATAS666DAMIEN
http://www.youtube.com/natas666damien
i have nothing for sale.. :)
Tecneek   1 µW
Post by Tecneek » May 21 2018 9:04pm
Cruncher123 wrote:
May 21 2018 1:43pm
Ivanovitch_k wrote:
May 21 2018 11:09am
Cruncher123 wrote:
May 21 2018 1:03am
How about, fly there, buy it, export it back.
Ambient2010   100 µW
100 µW
Post by Ambient2010 » May 22 2018 2:58am
can someone tell me how to get the rear wheel expanded?
I'm too stupid to understand it :-D
dalysea   100 mW
Post by dalysea » May 22 2018 4:57am
Cruncher123 wrote:
May 21 2018 1:03am
Interesting, this caught my eye:
"Two operating modes and 5 power levels each provide an ideal driving style for every need and every terrain. The ECO mode optimizes the energy consumption and thus ensures homogeneous power delivery and long ranges. In SPORT mode, the engine develops its performance more spontaneously, faster and the peak performance is higher. In addition, 5 power levels can be set in both operating modes."
Anyone figure out how to set up two completely different settings of 5 pedal assist levels, one for Eco, one for Sport? I'm not seeing anywhere to do this in either the display settings or in the programming.
Thanks,
Sean
California
Ivanovitch_k   10 W
Post by Ivanovitch_k » May 22 2018 4:09pm
dalysea wrote:
May 22 2018 4:57am
the current programming software is not able to deal with those different modes. It only sets global PAS levels. I guess the different modes acts as multipliers on PAS levels. I.E Sport 100% current limit, Eco 50%, etc... to be confirmed.
Ivanovitch_k wrote:
May 19 2018 5:56am
I know t's M12 x 1.5mm pitch, but i'm looking for the thread length and total length.
thanks 8)
anyone ? Thx
Cruncher123   10 mW
Post by Cruncher123 » May 22 2018 8:24pm
Tecneek wrote:
May 21 2018 9:04pm
Cruncher123 wrote:
May 21 2018 1:43pm
Ivanovitch_k wrote:
May 21 2018 11:09am
Cruncher123 wrote:
May 21 2018 1:03am
Actually, not a bad idea. Will be in Italy for 3 weeks in September. Maybe I can figure out something.
Cruncher123   10 mW
Post by Cruncher123 » May 22 2018 8:38pm
efMX Trials Electric Freeride wrote:
May 21 2018 3:28pm
Cruncher123 wrote:
May 21 2018 1:43pm
Ivanovitch_k wrote:
May 21 2018 11:09am
Cruncher123 wrote:
May 21 2018 1:03am
reference :
Link leads me to a non-existent page :!: I'd love to see more details of the Apollo
Post by efMX Trials Electric Freeride » May 22 2018 9:21pm
Cruncher123 wrote:
May 22 2018 8:38pm
May 21 2018 3:28pm
Cruncher123 wrote:
May 21 2018 1:43pm
Ivanovitch_k wrote:
May 21 2018 11:09am
reference :
link works for me.. its a "closed group" so one needs to be in the group to view the content.. if interested search facebook for "Fast Electric Bike" group and join if desired .. so just a heads up that Apollo release now seems imminent, within weeks not months.. once released, Apollo should be listed on the luna site as well so maybe check back there in a couple weeks..
Tom L   1 kW
Post by Tom L » May 22 2018 11:51pm
Received my bike today. No shipping damage at all, which was nice. Very well packed.
Took a month or so longer than expected due to the Chinese New Year, needing a different freight company to deliver to my door, and a bit of a customs kerfuffle about ebikes needing import permits in Australia. Needles to say Ivy was very helpful the whole way along.
Having a bit of trouble setting the correct sag on the rear shock as my pump adaptor head is too large and interferes with the suspension arm. It's about 40% instead of the ideal 25-30% (the test rider was obviously lighter than me). Will pick up an adaptor hose from my local bike shop to rectify this asap.
Wish this battery would hurry up and charge it's a beautiful day for a ride outside.
Tom L   1 kW
Post by Tom L » May 23 2018 1:16am
Well that could have gone better.
Battery finished charging. Went for a test ride, in lowest gear, eco mode 3, 15 seconds into the ride, starting up a steep hill and the derailleur snapped off between the adjustment limit screws. Waiting to hear back from Frey. :(
Cruncher123   10 mW
Post by Cruncher123 » May 23 2018 2:47am
Tom L wrote:
May 23 2018 1:16am
Yikes. Can you share a picture?
Tom L   1 kW
Post by Tom L » May 23 2018 2:55am
nataS@phnet.fi   100 mW
Post by nataS@phnet.fi » May 23 2018 8:51am
Any idea should there be any foul play on front hub? Novatec D041SB-B15. The hub is making nasty clonk sound even when rotated on hand, there´s couple of millimeters loose on both sides of the hubs, could the bearings be shot? Is there a way to tighten it up or something, completely new to this kind of hubs :?
Hardcore   100 W
Post by Hardcore » May 23 2018 12:02pm
nataS@phnet.fi wrote:
May 23 2018 8:51am
When the box comes, there are protection plates on the side, right? In my case when taking those off I accidentally took the spacers off too.
