My Bafang Ultra Mountain Bike! Frey AM1000
Tom L   1 kW
Re: My Bafang Ultra Mountain Bike! Frey AM1000
Post by Tom L » Jul 02 2018 7:33pm
I haven't noticed this with the torque sensing. I don't use the throttle enough to comment on that. Can post my settings if someone PMs me a link to the software.
scrambler   100 W
Post by scrambler » Jul 02 2018 10:47pm
Tom L wrote:
Jul 02 2018 7:33pm
The article below has a link to it
https://electricbike-blog.com/2017/11/2 ... ike-drive/
Tom L   1 kW
Post by Tom L » Jul 02 2018 10:49pm
Thanks.
FREYebikes   100 W
Post by FREYebikes » Jul 03 2018 12:38am
Hi all,
About battery situation, last year we use battery mainly come with LG cells, but since beginning of this year in February, we get battery with LG cells very difficulty for several months already, the delivery time is un-expected.
That's why recently use battery with Samsung cells more, because of the supplying is more regular and delivery in prompt time. We get battery with LG and Samsung cells in same offer from supplier.
The battery discharge at 34.9V mini, and the motor low voltage cut at 41.5V. so the battery cells performance is OK to match the motor.
Mantsos   10 mW
Post by Mantsos » Jul 03 2018 1:14am
Ivanovitch_k wrote:
Jul 02 2018 4:51pm
Mantsos wrote:
Jul 02 2018 11:23am
thinking about battery and bad connections inside there, could that be a possible and explain these "speed boosts"? Or how does your bike go with only throttle?
From your video it doesn’t look like a connection issue. If it was, it would be happening randomly, and more so at higher speeds because of increased vibrations. You would also see the battery level / voltage fluctuate a lot on the display (with “empty” battery red gauges coming and going).
Changing handling from speed to current should make a large impact. You can also try unlinking the throttle response from a specific PAS level by choosing the designated assist level to one with 100% current and speed. Also set speed limited in PAS tab to max and not to “by display”.
Besides the dedicated torque page, all other settings are shared with BBSxx series. Have a look to this guide and explore this thread too.
For the torque settings look here and here.
Can’t comment about my bike as it is far from ready. It’s a very slow but steady build, but I’m documenting almost everything and will do a dedicated thread when I near completion :) !
Thank you guys! I will try to change some settings. Also what I noticed yesterday when I drove about 3km with only throttle battery energy dropped ~50% to 11% what is pretty much I think. Before that I drove about 10km roadtrip and before that roadtrip I was also fully charged that battery. So 90% of battery energy is left after 13km roadtrips... When I had a bike with bbs02 motor and about 800wh battery I drove about 40km with full throttle and that bike was also faster.
Lets see what Ivy answer for me... but something is not definitely okey I think.
Mantsos   10 mW
Post by Mantsos » Jul 03 2018 10:57am
I tried little bit different settings show I changed next things from the program:
Basic-page:
Assit0: -> Limit current (%) = 1 and Limit Spd(%) = 1 (these settings was 0)
Throttle Handle
Start Voltage (x100mv): 12 (was 15)
Mode: Speed --> to current
Speed limited to 40km/h (that was "By displays command")
But results are almost same. Now throttle is maybe little bit "smoother" but it still take some "speed boosts" after 20km/h speeds (or when I am driving downhills) so that motor doesn't give still all powers out every time with throttle.
Next thing is maybe try to change "Start current (%): 10" to much higher? But I am little bit worry to change that setting because when I had bbs02 motor and I put this settings higher to like 25% I was almost going to do backflips with my bike. So someday if that my frey bike want to take that speed boost from the start I am going to do so badly these backflips. :roll:
Tom L   1 kW
Post by Tom L » Jul 03 2018 2:28pm
It is unwise to raise the start current above 20.
Tom L   1 kW
Post by Tom L » Jul 03 2018 5:37pm
FREYebikes wrote:
Jun 07 2018 11:38pm
About battery holder issue you mentioned, I think that's because this is really a big and heavy battery, and we think the battery holder design is not strong enough and perfect.
What we are doing try to make it more stable as following:
We found the lock core is not long enough to hold the battery. the original one is in golden, we customize a longer one to use now.
If anyone need some help or support from us, please feel free ask.
Are these new battery locks available aftermarket?
I shook my battery off my bike on my ride to work this morning. Not completely off the bike fortunately. I managed to grab it and shove it back into place rather than letting it fall out.
Marmalade   10 mW
Post by Marmalade » Jul 03 2018 9:16pm
..in the meantime, could just use 2 velcro straps (the ones with buckles) to hold the battery solidly in place, everyone uses them to hold batteries on our racing quadcopters and they will snap before they loosen.
Has anyone any opinions/experience with the 2018 frame over the previous one? Suspension pivots seem to be quite different?
Mantsos   10 mW
Post by Mantsos » Jul 04 2018 5:56am
Tom L wrote:
Jul 03 2018 2:28pm
I changed next settings to -->
And now I got this thumb throttle to work little bit better. So now that bike doesn't take so badly this "speed boosts". I will try to do some change still to get that thumb throttle more better so if someone other have similar "problems" what I have can also try this settings.
Edit: Ivy answer for me: "About the boost, it seems how the motor it is come from Bafang. Can't be adjusted by the software. "
Also what I little bit wondering now is that when I brake using rear brake that rear hub keep some noise like "bang, bang, bang, bang" and what harder I brake that bigger is that noise. I thought first that noise coming that's why because brake pads are new but that noise has not ended.
Tom L   1 kW
Post by Tom L » Jul 04 2018 6:13am
Have a close look at both sides of your rotor for defects.
Paikan   10 µW
10 µW
Post by Paikan » Jul 04 2018 8:42am
A question:
I'm waiting for Ivy to answer me, but I've received the two bikes I ordered, but no batteries. Ivy told me before buying that the batteries come separately, but she did not give me a tracking number for the batteries.
Does anyone know how and when my batteries come home?
Best regards
Mantsos   10 mW
Post by Mantsos » Jul 04 2018 10:24am
Paikan wrote:
Jul 04 2018 8:42am
A question:
Best regards
If you live in usa i think that bike come first by air cargo and this battery come by ship. So it would be take 1-4 weeks longer? I didn't get also that tracking number but they called for me from the cargo company when bike was in my country.
Paikan   10 µW
10 µW
Post by Paikan » Jul 04 2018 12:54pm
[/quote]
[/quote]
I live in Spain. I´ll wait tomorrow some answer from Ivy...but I guess there will be no tracking number for the batteries and that they will come by ship ... It's time to wait :cry:
Regards
Ivanovitch_k   10 W
Post by Ivanovitch_k » Jul 04 2018 3:27pm
Marmalade wrote:
Jul 01 2018 6:57pm
Please post more pics as you progress,very cool modification! So there are a few blank spots there for some additional cells? :)
No. Amongst the 5 cell holders, only the lower one has 2 empty slots. There are 16 cells per holder. 4 * 16 + 14 = 78 cells.
As per Ivy, the 52V version in the same casing has less cells, only 70.
Tom L wrote:
Jul 03 2018 5:37pm
I don't think so. It's the orange locking pin that is replaced.
I believe Frey themselves machined a longer one.
Ivy sent me one with a side order of spare parts. Here is the comparison of the two:
It wouldn't be that hard to DIY a crude one from an alu. rod and a file, but Ivy can probably send them out if you ask.
Paikan wrote:
Jul 04 2018 12:54pm
I live in France and the battery also came in a separate shipment by UPS. The frame came from FedEx. Ivy sent me tracking numbers for both. It took around 15 days end-to-end for the battery to be delivered.
BBS'ed Radon ZR Team 8:
BBS02B 750W - DPC750C - 48V 17.5Ah GA shark - 11 spd 11-40 Shimano XT, 42T N-W Precialps CW, KMC X11e chain, Gearsensor, XT RD, XTR Shifter, F Saint Brake, R XT Brake, RT99 200/160 Discs, magnetic shutoff, DT Swiss X1900 QR9 wheels, Manitou M30 air fork, 2.4" slick balloon schwalbe Super Moto X tires @2 bars, Suntour NCX suspension seatpost, ergon SFC3 saddle, ergon GP3 grips, Supernova M99 Pro + E12 Taillight
Cruncher123   10 mW
Post by Cruncher123 » Jul 06 2018 10:53am
Mantsos wrote:
Jul 04 2018 10:24am
Paikan wrote:
Jul 04 2018 8:42am
A question:
Best regards
My bike is on its way (air freight) and Ivy confirmed yesterday that the battery is with the bike. I'm in the US
Tom L   1 kW
Post by Tom L » Jul 06 2018 2:03pm
Ivanovitch_k wrote:
Jul 04 2018 3:27pm
It's cool. Ivy is sending me one of the longer silver (Al) ones. And the battery is sufficiently Velcro strapped for the interim.
Ender2000   1 mW
Post by Ender2000 » Jul 07 2018 12:41pm
Is anyone else having trouble communicating with Frey?
I have been trying to initiate an order for several days, and I have been getting incredibly brief responses half the time, and no responses at all the other half.
Any tips for dealing with this company? They didn't respond to a direct e-mail either...
Cruncher123   10 mW
Post by Cruncher123 » Jul 07 2018 1:53pm
I communicated/ordered via the Alibaba app. Ivy was quite responsive. Almost always next-day response, even on weekends. If I communicated during China working hours, usually got quick response within hours.
Ivanovitch_k   10 W
Post by Ivanovitch_k » Jul 07 2018 6:35pm
+1
Ivy answers fast and on point.
I deal a lot with China during my day job and It's actually quite refreshing to see a Chinese manufacturer this responsive.
Kudos to them !
Hardcore   100 mW
Post by Hardcore » Jul 08 2018 5:29am
Ender2000 wrote:
Jul 07 2018 12:41pm
Their response usually ends in your junk or doesn't even reach that. Try the alibaba message center, I had the same email issue. Try asking one thing at a time if you get 'half'/brief responses.
thingone   100 µW
100 µW
Post by thingone » Jul 08 2018 9:56am
What is the maximum amps that can be programmed on the controller? Only 30?
How does Luna, and how could we, reprogram to pull a full 2-3000watts?
Ivanovitch_k   10 W
Post by Ivanovitch_k » Jul 08 2018 9:59am
thingone wrote:
Jul 08 2018 9:56am
Yes, 30 Amps.
Luna replaces the current shunts on the controller to make the brainbox believe less amps are flowing.
They possibly change the FETs too, but unsure about that.
BTW, a suitable replacement for them are the Infineon IPB017N08N5 with a cool 1.7 mΩ RdsOn. The D2PAK aka TO-263-3 package is cool, easier replacement than the through hole TO-220 of BBSxx series. That, and the non potted controller 8)
I will place a temp probe on the stock fets and see how hot they get at 30 amps 48V to gauge wether or not changing them can help.
Ender2000   1 mW
Post by Ender2000 » Jul 08 2018 11:37am
I'm a little frustrated. I've been messaging Ivy on alibaba for three days. She's reading my messages according to the site, but not responding. I only got one vague response about five days ago. Here's the record.
Screen Shot 2018-07-08 at 9.34.25 AM.png (44.94 KiB) Viewed 550 times
Hardcore   100 mW
Post by Hardcore » Jul 08 2018 11:58am
Ender2000 wrote:
Jul 08 2018 11:37am
I can understand. Try being specific with what you want, for example: the 2018 frame fatbike xxxx model with those standard components and xxx upgrades and ship to xxx address.
