My Bafang Ultra Mountain Bike! Frey AM1000
TOLM   10 mW
Re: My Bafang Ultra Mountain Bike! Frey AM1000
Post by TOLM » Jul 12 2018 9:20pm
https://m.ebay.com/itm/Park-Tool-Bb-Par ... is+bb.TRS0
This should work for isis bottom bracket
Hillhater   100 GW
Post by Hillhater » Jul 12 2018 9:58pm
Tom L wrote:
Jul 12 2018 6:16pm
I had the same trouble with my square taper puller. It worked for my 2008 Giant Alias but not this bike. While the tool threads on to the crank fine, you can see in Ivanovitch's photo above the ISIS has a much larger inner diameter. The centre of the puller just slips right inside with nothing to lever against.
There is a separate larger diameter tip for the puller, that fits the bigger bore ISIS shafts.
You could improvise one from a suitable thick washer or similar..
https://www.pushys.com.au/topeak-univer ... uller.html
TOLM wrote:
Jul 12 2018 9:20pm
https://m.ebay.com/itm/Park-Tool-Bb-Par ... mm-Sh-isis
Yes it does but, ... That tool is for removing the whole BB bearing cassette...not the cranks from the shaft.
TOLM   10 mW
Post by TOLM » Jul 12 2018 10:06pm
Hillhater wrote:
Jul 12 2018 9:58pm
Tom L wrote:
Jul 12 2018 6:16pm
TOLM wrote:
Jul 12 2018 9:20pm
My bad sorry. I am using the same crank tool for both my square taper and isis bb. The round piece at the end of tool is very important for isis bb
https://m.ebay.com/itm/Bicycle-Bike-Cra ... =R40&rt=nc
Hillhater   100 GW
Post by Hillhater » Jul 12 2018 10:13pm
Yes its important..as you have discovered it doesnt work without it !
But it is only a metal "plug" of the correct dia to fit inside the crank splines and rest against the shaft shoulder.
As i said its possible to make one, ...no big deal.
...but the correct "universal "tool is only $20 new !
Ivanovitch_k   10 W
Post by Ivanovitch_k » Jul 13 2018 1:46am
One could also buy self extracting isis bolts (in the tool less variant) instead of a compatible puller. I don’t know if they work with standard isis cranks tho...
I have the SRAM EX-1 isis crankset and they come with these. You only need an 8mm hex bit for both install & removal :D !
BBS'ed Radon ZR Team 8:
BBS02B 750W - DPC750C - 48V 17.5Ah GA shark - 11 spd 11-40 Shimano XT, 42T N-W Precialps CW, KMC X11e chain, Gearsensor, XT RD, XTR Shifter, F Saint Brake, R XT Brake, RT99 200/160 Discs, magnetic shutoff, DT Swiss X1900 QR9 wheels, Manitou M30 air fork, 2.4" slick balloon schwalbe Super Moto X tires @2 bars, Suntour NCX suspension seatpost, ergon SFC3 saddle, ergon GP3 grips, Supernova M99 Pro + E12 Taillight
Paikan   10 µW
10 µW
Post by Paikan » Jul 13 2018 5:39am
Mantsos wrote:
Jul 12 2018 4:57am
Paikan. I have a bad news.
They called for me from my local ebike store and told that my bike back frame is bent about 0,5cm :( So that is the maybe reason why my bike keeps that noise. Also it could be good idea to check your bike rear axle and drop out threads from the inside because mine drop out was taken little bit damage. And because that back frame is bent about 0,5cm was that axle also little bit tight when I tried to take it out. I am going to send that report to Ivy so let's see what happens next.
Hi Mantsos:
The noise only appears when the motor is working at high amperage rates. When the motor is off, there is no sound, so yesterday I try not force the motor monitoring watts in screen, and and the sound was louder...
By the way, I´m going to check rear axle...but i d´ont know how check that 0,5 cm of the rear frame :(
Regads
DaninSpain   100 mW
Post by DaninSpain » Jul 13 2018 8:53am
FREYebikes wrote:
Jul 10 2018 9:12pm
Hi Daniel,
Please don't worry. We will be responsible for you. I've replied you by email.
DaninSpain wrote:
Jul 10 2018 1:10pm
DISASTER: 40km from home, 95 in the shade
My biggest fear about ordering this bike was what happens if something really major goes wrong.
Today, 40km from home it did all go wrong. The power delivery suddenly became really juddery, followed shortly after by a horrible noise from the motor, and then I lost all power. I could hear the motor turning, but no propulsion.
I had to cycle a 30kg bike 40km in 95 degrees to get home. Pretty brutal.
I wanted to make a quick video to show what's happening, but now it won't even switch on. To say I'm gutted doesn't come close :(
I have ridden my AM1000 almost every day since I got it 4 months ago, and have loved it. It's done 800 miles, and I keep on top of basic maintenance such as checking for loose nuts and bolts, cleaning chain, adjusting gear cable etc.
My riding is not aggressive, usually between level 1 and 3 (sport mode). Off-Road 40% On-Road 60%.
It's lovingly cleaned whenever I've been off-road and I stick to the easy stuff with nothing too taxing. The bike has had an easy life so far.
I ordered the bike in February 2018 and was told it has the steel gear, not the nylon, but it does feel motor gear related.
I'm REALLY hoping that Frey do not abandon me, that they take this seriously and get it sorted ASAP. I've just sent Ivy an email to explain and ask her what she needs from me to get my bike fixed under the warranty. Any which way, it looks like it's going to be as while before I'm back in the saddle :(
The thought of taking apart the motor to replace gears fills me with dread.
Anyone any ideas what could have gone wrong?
Ivy has asked me to remove the motor and return it to China, but I'm having problems removing the retaining bolts holding the motor in place.
I’m having problems removing the retaining bolts.
I have tried 2 approaches:
Removed the lock nut on the right side, then tried to unscrew the Allen nut on the left side. The whole retaining bolt just rotates and nothing happens
Then I replaced the lock nut on the right side and tried to undo the Allen nut on the left side, but it absolutely will not move. If I apply anymore force I will break or strip the Allen key.
Can anyone help?
Thanks
Dan
The best things in life are not things :)
Tom L   1 kW
Post by Tom L » Jul 13 2018 8:56am
Take the nuts off and belt the bolts out with a hammer and a steel rod (I used an old T30 torx screwdriver). Seriously. They aren't threaded, just really tight. By using a rod centred on the bolt you are less likely to roll over the thread with the hammer.
DaninSpain   100 mW
Post by DaninSpain » Jul 13 2018 11:55am
Tom L wrote:
Jul 13 2018 8:56am
Brilliant. Thanks Tom. I'll grit my teeth and give it a whack :shock:
Update: Done it :D It's hard to apply violence if you're not sure it's the right move.
DaninSpain   100 mW
Post by DaninSpain » Jul 14 2018 11:29am
Can anyone help me identify the name of the tool I need to remove this ring?
Thanks
Ivanovitch_k   10 W
Post by Ivanovitch_k » Jul 14 2018 1:00pm
you can use luna wrench or the bottom bracket shimano TL-FCsomething tool (beware, there are different Ø that look almost the same).
trooper5707   100 mW
Post by trooper5707 » Jul 16 2018 7:38am
Wow - great job getting it home - I would have called a tow truck! Keep us posted! I don't have mine yet, should be getting close to completion. I am riding a Rad Rover now, really looking forward to trying the AM. I will say the RAD has been an amazing bike thus far, this will be even better.
Frey AM1000 - Speed Machine
Rad Rover - Work Horse
Rad mini - On the go
Home Brew Hub 1000W Hub build
Xiaomi M365
DaninSpain   100 mW
Post by DaninSpain » Jul 17 2018 11:47am
Ivanovitch_k wrote:
Jul 14 2018 1:00pm
Thanks Ivanovich_k.
I took the motor into my local bike shop, and after the staff member picked up his jaw at the size, weight and power of the motor (he's used to Bosch and Yamaha 250w power plants), he came up with the correct tool.
I want to give the size and details, but nowhere on the packaging does it give any sizing details.
DaninSpain   100 mW
Post by DaninSpain » Jul 18 2018 10:50am
Not good news for those of us in the EU :(
https://uk.reuters.com/article/us-eu-ch ... KKBN1K816H
dalysea   100 mW
Post by dalysea » Jul 19 2018 2:56am
DaninSpain wrote:
Jul 17 2018 11:47am
If the lockring is 16 notch, 48.5mm, then the Park BBT-29 should work. The BBT-9 will not work. The Luna Bafang tool will work (I just measured it). The Shimano TL-FC36 tool... maybe?
That's cool that they had one with a nice handle; with the double-sided ones or the Luna tool, you're stuck with a thin metal edge to grip.
trooper5707   100 mW
Post by trooper5707 » Jul 20 2018 7:46am
DaninSpain wrote:
Jul 18 2018 10:50am
Ouch! They are looking at tariffs on them for US as well.
I just got notified that the EX-1 set will not be available until sometime in August, Ivy and team will ship the bike as is with the standard set and then ship that later. Looking forward to getting the bike! I have a Rad Rover and a mini now that I really enjoy, can't wait to try the AM1000!
Xiaomi M365
Marmalade   10 mW
Post by Marmalade » Jul 21 2018 4:40am
I guess the concern over mass imports and market flooding could be genuine concern after seeing this...
https://www.theatlantic.com/photo/2018/ ... es/556268/
barbarossa   1 µW
Post by barbarossa » Jul 21 2018 4:50pm
Hello,
also bought a Frey AM1000 one month ago - and still love it. it is really a cool bike...
concerning the battery lock:
i dont think that a longer bolt will solve the problem because the hole in the battery would have to be deeper which is not the case i think.
but i recognized that the bolt of the lock was adjusted. it is not curved at the end anymore. i think this little adjustment might prevent unwanted openings or am i wrong ?
Marmalade   10 mW
Post by Marmalade » Jul 24 2018 3:33pm
... can anyone suggest an appropriate LED light (front/rear) for this bike, that is removable for the trails?
How is everyone finding their AM1000? Still not too many reviews/videos on it.
FREYebikes   100 W
Post by FREYebikes » Jul 24 2018 10:49pm
Yes, this change is helpful to hold the battery better.
barbarossa wrote:
Jul 21 2018 4:50pm
Hello,
FREYebikes   100 W
Post by FREYebikes » Jul 24 2018 10:57pm
I think if send by express, there is little effect on the tariffs change in Europe. we have some bikes go to Europe recently, no change on tariffs, as express company handle the process in a simple way, not very strictly.
DaninSpain wrote:
Jul 18 2018 10:50am
trooper5707   100 mW
Post by trooper5707 » Jul 26 2018 7:51am
Marmalade wrote:
Jul 24 2018 3:33pm
Still waiting on the arrival - I don't think there are too many out there - sort of a niche market
Xiaomi M365
Marmalade   10 mW
Post by Marmalade » Jul 26 2018 4:19pm
..so what tools/spares does everyone carry with them (links)? With the range of the 21ah batt, getting stuck in the middle of nowhere could be really interesting...
Hardcore   100 mW
Post by Hardcore » Jul 27 2018 8:25am
Hi All,
I have been riding my am1000 for about 400km now over the past two months loving and hating it.
In the meantime, I've had my share of problems as well. All in all I love the bike, but so far this has happened chronologically:
1) gear sensor was not installed as requested - one was send to me for me to install
2) battery fell out of the holder when the top plastic part broke (after I warned them 1 or 2 screws is not enough to hold it in place) - new top part was send to me with a longer locking pin, damage to the housing of the battery is minor but doesn't look new anymore.
3) rear suspension broke, one of the rods broke in half - new one was send to me with new bearings
4) kickstand broke off - replacement bolts were given
5) chainlength was not adjusted for the sram ex1 cassette - new one was send
6) novatec freewheel hub snapped in half - compensation to buy my own rear wheel
7) rear axle snapped in half - replacement was send
8) the left brake lever snapped during a fall (not even a serious crash) - bought a new set myself
But on the other side of things, this system is capable of 45-50km/h top speed for ~30km. If avg is 30km/h you get about 40km range (with 850 height meters). I have two 52v batteries that can take me for a collective 4h cycle ride covering about 80km and 1.7km in height (human pedalling included). On sram's ex1 biggest gear it can climb the steepest hills (30-45%) if you can keep your balance and traction. Anything that is steeper will throw you backwards. I do have a dropper post installed but had to forcefully clamp it because the diameter was slightly larger than 31.9mm as advertised.
More details about the bike:
Lyrik 160mm front fork
Deluxe RL rear suspension
SRAM ex1 upgrade
203mm rotors front and back
front pads upgraded to magura MT7 race variant (they are compatible)
150mm dropper seatpost internally routed
first trips were done with the original wheels (rekon 2.8+) but switched to minion DHF 2.5 and DHR II 2.4 WT version and DH casing in the rear.
52v 17.5ah battery and limited the controller to 25Amps
new parts are:
DT swiss H 1900 35 mm
Robert axle project replacement rear thru axle
Richard N   10 W
Post by Richard N » Jul 27 2018 8:49am
Hardcore wrote:
Jul 27 2018 8:25am
Hi All,
SRAM ex1 upgrade
new parts are:
That is a frightening list, on the first read through for only 400km traveled. Are you trail riding or where these on road incidents?
