BBSHD + Grin Phaserunner (52V okay, 72V problem)
titusmc
Post by titusmc » Oct 16, 2017 7:20 am
Hi -
I'm working on an external controller mod for one of my BBSHDs using a V2 Grin Phaserunner. Goal is to run 72V (20S) at 40A with smooth/ramped acceleration from a stop to minimize stresses.
I made my own JST adapter cable for the hall sensors and motor temp sensor and added 10AWG phase wire using silver butt crimps. I paired the motor and controller using a 52V battery since I hadn't yet finished my 72V one, and everything ran okay. I took it for a test ride at 52V50A and everything was great except for some "judder" if I moved the throttle too quickly - surely must be a ramp rate issue that I can fix with CA3.
This weekend I finished my 72V battery (Samsung 30Q 20S5P, 60A BMS, 10AWG to XT90, triple-layer nickel). I hooked it up and got a hall sensor fault (LED code 1-6). The communication over USB seemed unstable as well. I tried the 52V battery again and everything was fine - halls are okay. The only thing I can think of is that the 5V line might be too high with the 72V battery for some reason, causing both the halls and USB to have issues. I'm going to check that tonight with a multimeter.
I know others have successfully used external controllers (including Phaserunner) on BBSHD. Hopefully someone has the answer or a decent troubleshooting idea.
Thanks,
Matt
titusmc
Re: BBSHD + Grin Phaserunner (52V okay, 72V problem)
Post by titusmc » Oct 17, 2017 6:54 am
Well, I seem to have figured out my own problem. I'll post about it for the benefit of others who may attempt this mod.
1. I charged up the 72V (20S) battery to full (84V) - not sure if this matters at all.
2. I plugged in the 52V battery to the Phaserunner (I originally configured with this battery), launched the Phaserunner software, and plugged in the USB.
3. I followed the instructions on ebikes.ca to reflash the "Default Parameter File."
4. I disconnected the 52v battery and plugged in the fully charged 84V battery.
5. I entered the approximate kv of the BBSHD (70 RPM/V) and pole-pair count (4) in the software.
6. I ran the autotune test (spun backwards on first run).
7. Leaving the battery rated voltage at 48V, I changed only the regen voltage (BBSHD can't regen anway), max power and max current settings.
The bike now runs fairly well on 72V limited to 3000W. I ramped the acceleration from a stop to be slower using CA3 throttle ramp (1V/sec up). My only remaining issue is that I experience a motor judder whenever I coast on no throttle and reapply throttle, such as coming out of rolling through a corner or coasting down a hill. I've read that this is not exactly easy to fix, and that a minimum throttle output setting might be one solution.
Can anyone point me in the direction of useful material for fixing/reducing this judder issue? If I solve this, the bike will be basically perfect. Light, stealth (except for speed), silent, powerful.
titusmc
Post by titusmc » Oct 27, 2017 7:15 am
Fixed the judder issue last week - posted about it in the "Ultimate 3000W BBSHD" thread.
I highly recommend this mod to anyone with a fair amount of ebike experience (3 years for me, plus a good engineering education). I already owned 2 BBS02s and 2 BBSHDs when I started this too, so I was familiar with stock performance on 52V. The move to 3000W (72V@40A-ish) is incredible. The need to change gears has basically disappeared for me - I've been in 30T front/16T rear for about 2 weeks and haven't found any hill I typically ride on (<10%) that I can't climb fast (25mph+). The bike tops out around 40 mph on a flat. With 72V@50A + field weakening I'm sure it could do even better, but I don't find that necessary - the bike already gets too much attention going 40mph.
melodious
Post by melodious » Oct 27, 2017 8:06 am
The bike is screaming to put the battery in the frame :P . At 40 it would definitely handle better :wink: .
Surly Ogre rigid 29er, rear 10T MAC @ 50V 25AH & 40A: 30mph road/gravel/hill machine
42" dual diagonal Eskateboard @6s & 90mm wheels
Next: eMTB @10-12s & 8"-12" pneumatic wheels; Got Strapped? d-(',')z
sabongi
Post by sabongi » Oct 27, 2017 8:30 am
You should get a EM3EV frame bag. It's amazing how the weight of the battery "dissapears" since it's so low on the ground!
titusmc
Post by titusmc » Oct 27, 2017 9:22 am
I actually have an EM3EV frame bag, but since the controller is mounted on the seat tube I wanted maximum airflow around it. I find the bike's handling to be acceptable with the battery on the rack, but a triangle battery would be nice sometimes - for instance, I have a custom made insulated pizza carrier that works on my topeak mtx rack that I like to use. On my other BBSHD bike I simply clip the pizza carrier onto the frame and run a 14S5P pack in the EM3EV bag.
Aerialpixels
Post by Aerialpixels » Dec 21, 2017 7:09 pm
I have my Phase runner running on 21s Lipo (88v).
Phase current is set to 96a
Max current continuous is 46a
Flux weakening set to 32 amps
Ramp is 12v/sec
Rad set to 1.5
Min throttle output is set. 01v above minimum to just get the motor to barely spin while coasting. Current draw not moving is about 200ma
While coasting, chain ring spins slowly and when re-engaging throttle its liquid smooth. Barely noticeable.
Ebrake lever cuts throttle completely while stationary.
Internal thermistor installed on windings. Thermal CPU paste added between stator core and hosing to efficiently draw heat away and copper heatsinks added to outside.
Max temps have not breached 120F and I'm geared 42 chain to 32 rear cog. Bike easily goes 48mph. No shifting and wheelies in 1st - 3rd gear.
This is THE setup none of the pros have figured out.
Your welcome
Joe
StinkyGoalieGuy
Post by StinkyGoalieGuy » Dec 21, 2017 11:38 pm
Thanks for sharing your setup. I may have to try it out.
Can you explain what you mean by this?
If you are not shifting, how are you getting into 3 gears?
andrebandre
1 W
1 W
Post by andrebandre » Dec 30, 2017 2:39 am
Ramp is 12v/sec
Rad set to 1.5
Your welcome
Joe
Ramp is 12v/sec
Where did you set this parameter, por favor?
Is it the PR Suite or the CA? I can't guess for the life of me .
RollerBoy
10 µW
10 µW
Post by RollerBoy » Dec 30, 2017 5:16 pm
Andrebandre, that's a CA3 setting.
andrebandre
1 W
1 W
Post by andrebandre » Jan 10, 2018 11:53 am
Thank you RollerBoy!
I did increase the minimum throttle out to where it barely spins the wheel in order to keep the motor engaged all the time but i didn't dare messing with anything else.
The only problem i have now and then with throttle applied (cruising) is some stuttering as if it loses sync. I back off it and reapply it and all is well. Very vary happy with the performance, i ride gently but i can feel the wheelie power is there.
tinasdude
Post by tinasdude » Jan 13, 2018 10:59 am
Hi -
Thanks,
Matt
Did you use any field weakening with the 52V battery at 50 amps, If so what settings, and what were the results? Thanks
