BBS02 pedal resistance
monkey11   1 µW
Post by monkey11 » Dec 27 2017 11:12am
Hi,
After leaving my bike unused for a couple of months, I now notice that my pedals have a lot of resistance. It's uneven (about 4-6 resistance peaks per rotation of the pedal). This happens with the motor on or off. I've removed the chain from the front chainring so it's definitely the BBS02.
Any ideas what this can be? I've ridden about 15000km on this motor over 3 years and it's been solid until now.
melodious   100 kW
Re: BBS02 pedal resistance
Post by melodious » Dec 27 2017 11:30am
Probably one of two things.
The easiest fix is just to regrease the inner motor gears. With that much distance & time put into it, it's due for a servicing. The type of grease can be found in the main BBS thread. You'll have to browse through it to find it.
The harder fix is that clutch has either degraded or rusted. That requires some key tools and a new clutch. There are takedown videos of the BBS where you can deduce how to do this if this is the case, also located in that forementioned thread.
My instincts point to the first, only because in my case the clutch slowly degraded over time with more and more useage.
Edit: before doing this, make sure it isn't something as simple as your drivetrain & brakes aren't causing friction issues.
Surly Ogre rigid 29er, rear 10T MAC @ 50V 25AH & 40A: 30mph road/gravel/hill machine
42" dual diagonal Eskateboard @6s & 90mm wheels
Next: eMTB @10-12s & 8"-12" pneumatic wheels; Got Strapped? d-(',')z
augidog   10 W
Post by augidog » Dec 27 2017 10:43pm
monkey11   1 µW
Post by monkey11 » Dec 28 2017 12:13pm
Thanks melodious and augidog.
There's no resistance when backpedaling, so I guess it's not the clutch. I've removed the motor completely and ordered some mobilgrease 28 from amazon, I'll re-grease the thing when it gets here.
