Chain tensioner with Shimano Nexus 3 and BBSHD
Kitaro1999   100 mW
Post by Kitaro1999 » Jan 02 2018 1:09pm
Is there a chain tensioner that is recommended for my setup - Nexus 3 and BBSHD?
I've used the eclypse MT95C but the build quality is poor, and it's too narrow for single speed chains or a seven speed with the KMC pin.
Looking for a good high performance single speed tensioner that just works and I don't have to fiddle too much with it.
LewTwo   100 kW
Re: Chain tensioner with Shimano Nexus 3 and BBSHD
Post by LewTwo » Jan 02 2018 7:06pm
Have you considered using a half-link chain and just making it the right length so that a tensioner is not required ?
The more I learn the more obvious the immensity of my ignorance becomes.
Weight Wennie E-Bike https://endless-sphere.com/forums/viewt ... 3#p1173723
Shaft Drive Grocery Getter https://endless-sphere.com/forums/viewt ... =6&t=90718
...and thanks to Justin!
Kitaro1999   100 mW
Post by Kitaro1999 » Jan 02 2018 7:58pm
I did. However I ride 25-30 miles every day. Chain extends by a little bit and it adds up over miles. Suddenly there’s a chain popping out mid ride. :(
I have had better experience with a tensioner - and am looking for a better component.
samsavvas   100 W
Post by samsavvas » Jan 13 2018 7:39pm
I've used one of the Shimano Alfine tensioners with excellent results. They seem to have 2 designs that amount in different ways. Very high quality and reasonably priced.
Sam
NickF23   100 W
Post by NickF23 » Jan 14 2018 9:42am
I have a Sturmey-Archer tensioner that came with my Alfine 8. They do a series here with similar prices to the Shimano, so far it just works.
http://www.sturmey-archer.com/en/produc ... tensioners
I've just ordered a chunkier 1/8 chain in the hopes that it will last longer than the 3/32 chains. I'm hoping I'll be able to just add some washers to the tensioner to allow space for the new chain. I've never seen a tensioner thats speced to for a 1/8 chain yet.
Home made early version Puma 48V 1500 watts http://endless-sphere.com/forums/viewto ... f=6&t=4933
WoodlandHills   10 kW
Post by WoodlandHills » Jan 14 2018 10:52am
Surly Singulator. I have used them for a couple of years with Nexus 3's and BBSHDs and they fit all sizes of chain..... You can set them up to either push the chain against the rear cog or pull it against the cog.
