How to reset a bbshd?
Pctree
100 µW
100 µW
Post by Pctree » Jan 08, 2018 9:34 pm
Ok so I just had a bonehead moment! I was hard wiring in a set of lights into my battery which was connected to my bbshd. I touched the wires and caused a momentary short, turned on the display to check the system and it came on for a couple of seconds then cut off and won't power up now. Lights work and battery is taking a charge. Any suggestions would be greatly appreciated!
amberwolf
Re: How to reset a bbshd?
Post by amberwolf » Jan 08, 2018 11:38 pm
Disconnect the battery completely from the system for a few minutes (to let all the caps drain), then reconnect it and see what happens.
DolphLundgren
Post by DolphLundgren » Jan 09, 2018 11:31 am
In the worst case you might have fried your controller. The display came on for a couple of seconds because there was some juice left in the capacitors. Good luck! I fried one in a similar way.
Pctree
100 µW
100 µW
Post by Pctree » Jan 09, 2018 4:16 pm
Ok so I let it discharge all day and switched the lights on but no dice :oops:
Guess i will be sourcing a controller,....
Chalo
Post by Chalo » Jan 09, 2018 4:23 pm
Don't do that until you check the battery. You might only have caused the BMS to shut down.
Try this: https://lunacycle.com/jumping-your-luna ... tery-pack/
Pctree
100 µW
100 µW
Post by Pctree » Jan 09, 2018 6:48 pm
As I said if I plug the charger into the battery it whirs to life and battery takes a charge and the lights work so I'm thinking the battery is good no?
fechter
Post by fechter » Jan 09, 2018 8:46 pm
It sounds like a BMS problem. What kind of battery is it?
