izip my1018z motor question
roadstar
Post by roadstar » Feb 06, 2018 12:31 pm
Hi,
just picked up a izip motor from ebay. It runs ok when connected to a battery and controller.
I noticed when I turn the motor cog by hand (not connected to a battery) it makes no noise clockwise but counter clockwise it sounds like I'm winding a clock.
I've got a second spare motor and this does not happen on that motor when I turn it by hand counter clockwise.
Both motors run fine when connected to a controller and both look the same physically. I just wondered why one make that noise?
Current Ebikes...
Electroped Roadstar (first bike), 36 Volts - heavy, slow, 27 km/h max, reliable got inbuilt lights and a horn
Whoosh Sirocco, 36 volts, light weight, slow, 24 km/h max, battery has died - nice frame
Home built, side mounted motor, 24 volts, unite 1020Z motor, heavy, 20 mph max speed - now in bits - may overvolt
Home built mid drive, unite my1018Z (200 volts), 36 Volts SLAS, currie 24 volt controller, currie battery rack.
Dauntless
Re: izip my1018z motor question
Post by Dauntless » Feb 06, 2018 2:22 pm
Is there a gear, if so do you suppose there's a freewheel?
It's really hard to just answer a question like that without seeing, handling, hearing. There's one typical guess for me to make.
Any sufficiently advanced technology is INDISTINGUISHABLE FROM MAGIC!
- Arthur C. Clarke
roadstar
Post by roadstar » Feb 07, 2018 11:46 am
Hi,
the motors a geared motor it's a unite my1018z or variant.
Regards
Current Ebikes...
Drum
Post by Drum » Feb 07, 2018 2:51 pm
Hi Roadstar, I don't have personal experience with that particular motor, but I have noticed with other brushed motors in the past that sometimes the brushes make a noise when the commutator is turned in one direction but not the other.
Is the motor that makes the noise new or used?
Hard to judge without having the motor in my own hands... when you turn the output sprocket, does the noise happen a few times each revolution of the sprocket, once per revolution, or a lot faster than that?
roadstar
Post by roadstar » Feb 07, 2018 5:49 pm
Hi Drum,
the motor looks new but I think it has been used. The ticking is continuous as you turn the output sprocket. Like turning the key in a clock. The noise is only heard counter clockwise which is opposite to how the motor runs when it was on a bike (I think)
Current Ebikes...
