Help with Bafang remote
BillTheGalacticHero
Post by BillTheGalacticHero » Feb 09, 2018 11:04 pm
As you can see I need a better solution for this remote. The clamp that it comes with is too small. Is there a cleaner way to mount it?
Raisedeyebrows
Re: Help with Bafang remote
Post by Raisedeyebrows » Feb 10, 2018 12:13 am
If you really wanted it down on the bars you might be able to use just the top half and put a piece of foam under the top half and then use a small zip tie or better yet come kind of cleaner looking wire arrangement of some sort to cinch it down and affix it to the bars.
BillTheGalacticHero
Post by BillTheGalacticHero » Feb 10, 2018 2:14 pm
I see, remove the ring completely and use a zip tie over the entire remote!
Raisedeyebrows
Post by Raisedeyebrows » Feb 10, 2018 4:45 pm
I was thinking just remove the bottom half and affix something from the screw holes on the top half around the bars to hold it snugly on there.
BillTheGalacticHero
Post by BillTheGalacticHero » Feb 11, 2018 9:57 am
Thanks. How would you connect the zip tie to the ring?
Raisedeyebrows
Post by Raisedeyebrows » Feb 12, 2018 12:07 am
I was just thinking you could connect to the two screw holes that are in the top half of the unit. I hope you can figure out something that looks halfway clean, those road bars are quite wide aren't they? The unit fits around my MTB bars with the 31.8 stem size no problem.
