Hi Guys
Well its been a while since i posted on here...
after building many E-skates and scoots ive turned my hand to an Ebike-
I have KTM Macina (highly modified i might add )that i use to commute but i was also interested to see how a BLDC would perform ..(i had a lot lying around from my previous business)
So initially i wanted to try to use only 3D printed parts and i used my Road bike as a donor-
I used a 6374 motor,120a ESC and a 6s Lipo battery all in custom designed 3d housings and running a 15mm wide belt and pulley ..the battery is quick release that just slides out for charging..
I had to custom print a throttle for the drop as there are non on the market that fit ..
It achieved a nice 24mph with great hill climbing and only added around 2kgs to the bike weight- but i just couldn't live with e belt slippage ..
So i continued to use my Macina to commute and decided to change my design to fit the rear drop out
I initally tried all 3d printed clamp but i soon found out the 3d printed parts alone just didn't have the strength to clamp enough..
So I use a combination of waterjet parts and 3d printed inserts to suit the frame diameter ...and after several iterations its actually turned out pretty neat ,
The 3d printed gives the contour and the waterjet plates give the required clamp strength ..
The drive pulleys are from mini moto bikes and then a added to a waterjet ring that drives through the centre hubs ,where the spokes meet..works a treat
Using the same motor,esc and battery its achieves around 22mph on the fatter tires which was still good- and i have just added a 7s battery and this have significantly increased the top speed to around 26-27mph with very good torque- infact it will run at that speed with no pedaling..
I have printed flexible filament ESC holder with cable ties to the frame and now incorporated a BMS and charging port to the bottle battery..
so overall im happy with the results-
next step is to increase battery voltage to 8 or 10s ..then it will really fly !! make a full battery and esc enclosure and add a motor cover .. which im just protyping now..
