New "Lingbei MM28.250 torque sensor mid drive"
rick.schoenmaker@gmail.com   100 µW
100 µW
Re: New "Lingbei MM28.250 torque sensor mid drive"
Post by rick.schoenmaker@gmail.com » Oct 18 2019 4:50pm
Chito wrote:
Oct 18 2019 12:51pm
Hi, I have a mm28.500, I have noticed that it only has 85 rpm of pedaling assistance. this is normal?
Quite normal for electric assistance as Max torque is at 1rpm? Maybe this something cut by the torquesensor?
Chito   10 mW
Post by Chito » Oct 19 2019 5:59am
rick.schoenmaker@gmail.com wrote:
Oct 18 2019 4:50pm
Chito wrote:
Oct 18 2019 12:51pm
I measured it directly with the throttle, and without the chain in place so that it didn't force
Chito   10 mW
Post by Chito » Oct 19 2019 6:01am
mm28 really uses a torque sensor, use a spring between the axle and the transmission to the pinion.It has two magnets and measures the offset between the two to record the displacement of the spring. The transmission may have a small displacement with respect to the axis. One magnet is attached to the shaft and the other magnet is fixed to the transmission.
Chito   10 mW
Post by Chito » Oct 19 2019 6:05am
I don't know why they don't upload the photos I upload :(
Aeron   10 W
Post by Aeron » Oct 22 2019 2:33am
maitilupas wrote:
Sep 21 2019 3:07am
The downside is that is still annoyed with its PAS functions programing, specially with a 500w battery, ive ordered a cable to see if i can change the amps on the pas levels. If i can do this im happy with it, as for the torque sensor maybe in The future ill add something different if possible..
Can you tell us more about this cable and the programming process ? The existence of this cable was mentionned in the thread earlier but nothing more.
The only thing holding me back for this motor is the lack of assist settings (adjust sensitivity to cadence and torque sensors).
stancecoke   100 kW
Post by stancecoke » Oct 23 2019 5:21am
Chito wrote:
Oct 19 2019 6:01am
Thank you for the photos. But please explain better. I understand the principle, but I don't see a suitable spring in your photos....
regards
stancecoke
Chito   10 mW
Post by Chito » Oct 23 2019 7:35am
stancecoke wrote:
Oct 23 2019 5:21am
Chito wrote:
Oct 19 2019 6:01am
regards
stancecoke
Hello stancecoke,
the analysis you did in the images are correct.
Here I put more images of the spring, I have repaired it because it was broken:
https://www.instagram.com/p/B39eVk8hKgt/
https://www.instagram.com/p/B39cwD-BjDN/
https://www.instagram.com/p/B39cxx6hH3t/
https://www.instagram.com/p/B39c0JPhXBf/
I had to drill the shaft to remove the original spring, since it was very tight:
https://www.instagram.com/p/B39c2QXB2LZ/
you have to be very careful when removing the magnet because it can break
https://www.instagram.com/p/B39eSNMBlzV/
fortunately it was easily repaired
https://www.instagram.com/p/B39c5pahErM/
The spring works with little pressure on the pedal, it seems more like a switch than a linear sensor. To start pedaling assistance, it is necessary to put some pressure on the pedals at the beginning
the problem that Metaller (forum user) had, is solved with a fine adjustment in the magnet position so that the pulses are synchronized
Chito   10 mW
Post by Chito » Oct 23 2019 7:51am
The engine is very efficient, it heats up very little
Chito   10 mW
Post by Chito » Oct 23 2019 8:50am
I saw in a part of the forum that the motor controller uses a stm32 micro controller. Is it correct? If so, it could easily be programmed in arduino IDE with a st link v2. :D
Does anyone know where to find any programming code of any controller? :wink:
having a code, it can be edited or new functions can be programmed and then loaded in mm28 :flame:
The code in programming language would be more useful, for example in C or Java, not the code in hexadecimal
stancecoke   100 kW
Post by stancecoke » Oct 23 2019 8:55am
Chito wrote:
Oct 23 2019 7:35am
Hm, with some beam theory and some assumptions of dimensions from your new photos, the sensor could work quite linear...
You'll get a displacement of about 1mm if you step on one pedal with 80kg. Of course your spring made from two stripes is much weaker, than just one solid spring.
Chito wrote:
Oct 23 2019 8:50am
See my open source project for Lishui Controllers, they use STM32 as well (perhaps it's even a Lishui-Controller, can you find a print LSW.... on the PCB?)
https://github.com/stancecoke/LishuiFOC/wiki
regards
stancecoke
Chito   10 mW
Post by Chito » Oct 23 2019 11:27am
stancecoke wrote:
Oct 23 2019 8:55am
Chito wrote:
Oct 23 2019 7:35am
Chito wrote:
Oct 23 2019 8:50am
regards
stancecoke
Congratulations stancecoke. Very good calculations very good modeling and very good approximation.
Adjusting the parameters a bit: a = 3; b = 10; therefore I = 22.5.
we assume f = 0.9 approximately, but L is more difficult to give an approximate value because measuring directly can give a value between 3 and 12 mm, https://www.instagram.com/p/B393_kshQUm/
To this we must add a component of transverse flexion of the spring so I decided to take experimental measurements and model a little
for the spring I used a = 1.5 mm, therefore I = 2.8 but since they are two springs we have I = 5.6. I measured the force that would be exerted on the pedals so that f is approximately 0.9 and shows w = approximately 6.5 kg
https://www.instagram.com/p/B3920Z4hOSJ/
With these results, adjust in the equation a value of approximately L = 14.2 mm so that the results are consistent with the experimentally measured force. So recalculating for the original spring, we have: w = F / (170/10) = 3fEI / L ^ 3 = (3/17) * (0.9 * 210000 * 22.5) / (14.2) ^ 3 = 262N = 26.2 kg approximately
I haven't seen the motor controller board yet
Chito   10 mW
Post by Chito » Oct 25 2019 1:39pm
Is it possible to replace the STM32F031C6T6 of the lingbei controller with an STM32F103C8T6?
Nigelsheffield   1 µW
Post by Nigelsheffield » Oct 27 2019 7:30am
Oct 15 2019 1:10pm
Aquakitty wrote:
Aug 30 2019 10:09pm
Aug 30 2019 3:28pm
Aug 05 2019 6:06am
I've been in contact with OKFeet (supplier) and they send me an new Hall Sensor component to bolt on (no soldering). Very helpfull with video instruction for assembly. I'm wondering if more people have trouble with the Hall Sensor or other sensors. Maybe my issues are due to the Dutch weather.
After receiving the Hall-sensor, I opened the motor and delivered a surpise I was afraid of....
At least 50ml of rust water came out. The motor was covered in rust and also elements of the controller. So not only a defect on the hall sensor... After putting it back together I now also get a “Current Error”... The thing is dead I presume
Sadly OKfeet said this is not part of warranty/after sales care. It surely is a manufacturer error on the seals where moisture was able to get in via the ingoing/outgoing wires.
Don’t know what to do now, giving it another chance or seeking an alternative...
You should never assume any of these Chinese mid-drives are waterproof. You have to waterproof them
yourself.
After direct contact with the Lingbei factory I received today a new motor (fairly quick as it was shipped last friday from China). $100 for the motor and $100 postal it fairly cheap as well (OKfeet asked for $236 without shipment).
An extra connection on the main wire from brakes/display/gashandle to the motor was included (maybe for flashing the firmware?).
Now the biggest challenge is to make it waterproof. Still figuring out the best way (silicon kit at the wiring and plastic cover over the motor at least).
So it's it possible to order a motor directly from them than at that price?
I'm liking the sound of this motor and thinking of getting it for my old mountain bike, not sure if I would be best off with 36v battery to make the sensor work better?
Best place to get this motor right now with shipping and import tax to the UK anyone?
Thanks.
stancecoke   100 kW
Post by stancecoke » Oct 27 2019 12:45pm
Chito wrote:
Oct 25 2019 1:39pm
Why a "STM32F031C6T6"? In the beginning of this thread a "STM32F101C6T6" is mentioned?!
viewtopic.php?f=28&t=94220#p1382795
But all three share the same pinout. The STM32F031C6T6 has only one ADC, so my FOC code can't work with it.
STM32 comparison.PNG (208.16 KiB) Viewed 3575 times
regards
stancecoke
tomjasz   10 GW
Post by tomjasz » Oct 27 2019 10:37pm
Oct 15 2019 1:10pm
use liquid gasket or rtv at seams and ACF50 on any connections and electronics.
Metaller   10 µW
10 µW
Post by Metaller » Oct 29 2019 4:33pm
Chito wrote:
Oct 23 2019 7:35am
Thanks to you I finally understood how the torque sensor works in this engine, it is left to understand how to do it without multiple assembly-disassembly of the engine... :) My motor seems to have started to blow again... :cry: apparently the spring has weakened or flipped... I will try to disassemble the old shaft.
fifthbro   1 µW
Post by fifthbro » Nov 01 2019 2:24pm
My 48V 500W Lingbei is acting really funny and some of the symptoms might look similar to what Metaller described earlier.
The torque sensor seems to be doing opposite to what it should. I noticed that the harder I press the pedals, the less like power will be delivered. Only when pedaling very gently the motor will activate and deliver full motor assist. So great on flat, but pretty useless when trying to climb some hills or overtake in the traffic. And my feeling is that overall power delivery when pedaling seems to be pulsating. However, the throttle works fine.
I was wondering if anyone has a clue what the problem might be?
I have been in contact with the seller, and after going back and forth they offered to provide me with the cable to program the motor “with an update”. I am bit puzzled what that update would actually do and worried it might be some sort of a workaround disabling input from a faulty torque sensor and relaying on PAS only.
If the torque sensors in this motor is so fragile, it would mean that it’s not really big advantage over TSDZ2 (which was I considering in the first place).
Chito   10 mW
Post by Chito » Nov 02 2019 7:33pm
fifthbro wrote:
Nov 01 2019 2:24pm
What is happening to you is due to an incorrect offset between the sensor magnets. When you feel the intermittency is when you lower the left pedal because the natural torque of the bottom bracket axis helps to further offset the magnet that is more central, however when you lower the right pedal, it does not contribute to offset the magnet due to the torque of the axis because chain transmission is more direct. If you also feel loss of power when you lower your right foot it is because the angular offset between the magnets is very large.
The solution to this problem is to rotate the magnet (the one inside) a little (VERY LITTLE) counterclockwise if you look at it from the side of the chain. Or rotate the magnet that is outside, in favor of the hands of the clock, but it is more difficult.
Chito   10 mW
Post by Chito » Nov 02 2019 9:59pm
https://youtu.be/Y9HFFLLJLaw
This video explains better
Chito   10 mW
Post by Chito » Nov 02 2019 10:00pm
maitilupas   100 W
Post by maitilupas » Nov 03 2019 12:36pm
Chito wrote:
Nov 02 2019 10:00pm
thanks allot , great video
i broke the magnets while taking them out stupid me , do you think if i glue them they can work out?...
Chito   10 mW
Post by Chito » Nov 03 2019 1:14pm
maitilupas wrote:
Nov 03 2019 12:36pm
Chito wrote:
Nov 02 2019 10:00pm
my magnet also broke, I joined it with cyanoacrylate and it was perfect
maitilupas   100 W
Post by maitilupas » Nov 03 2019 2:26pm
Chito wrote:
Nov 03 2019 1:14pm
great to know ! thanks allot for the pic, more relief but meanwhile found another problem. i also found out my spring is broken inside and cannot take it out
Chito   10 mW
Post by Chito » Nov 03 2019 2:32pm
maitilupas wrote:
Nov 03 2019 2:26pm
Chito wrote:
Nov 03 2019 1:14pm
I drilled it with a dremel, a tungsten drill and a tungsten strawberry. Then I hit the spring from behind
