BBS Brake Cut Off Wiring Question
Lurkin
Melbourne, VIC, AUS
I've got some brake lever which incorporate a reed switch as a ebrake cut off. They use a two wire reed switch.
I want to use them on a BBS01 kit, which has a three wire reed switch female higo connection. Can I use these two wire reed switches instead of the hall sensors? which wires to go which in this instance? (I've read other sites which suggest using signal and GND for the two wires, and not + but I'm not sure if this is correct or whether it will have a problem with this particular kit)
Yes it will work. There are 3 wires, signal, ground and 5v. Use the signal and ground. Sorry I don't know which color the wires are.
