Cyclone chain alignment - is it possible to move the sprocket?
endrew   100 mW
Post by endrew » Jun 24 2018 7:29am
Hi,
is it possible to move the sprocket outwards/inwards in order to adjust the chainline? see attached image... Thanks!
HY10   10 mW
Re: Cyclone chain alignment - is it possible to move the sprocket?
Post by HY10 » Jun 25 2018 2:14am
Hi
A few millimeters is ok I also added a counter sunk hex head bolt to the drive shaft to create longitudinal force on the grub scew after tightening
There's a pic of my aft 1680 with the bolt
AFT only 10,000 km real world testing
100,000 real world ongoing adjustments needed
aCeMadMod   100 W
Post by aCeMadMod » Jun 28 2018 6:07am
get a new freewheel . I high grade one will be offset 8)
or change the alloy core . from a left side one
minimum   10 W
Post by minimum » Jun 29 2018 6:29am
Motor freewheel uses aluminum bushing/adapter to mount it onto motor shaft. When have access to a lathe, you could turn bushing's collar thinner from threaded side (thick red line on the picture), so freewheel would screw on further outward on bushing.
Either that or loosen the fixing screw and pry bushing away from shaft the needed distance. Few mm's won't make much difference.
endrew   100 mW
Post by endrew » Jun 30 2018 3:44am
thanks everyone!
I just loosened the fixing screw, and pushed the sprocket up a millimeter...
