Cyclone hall effect connector pinout
endrew
Hi,I want to pair a (mini) Cyclone with a phase runner controller. The mini cyclone has a 7 pin hall effect connector, and the phase runner uses a 5 pin connector.
I need the cyclone hall connector pinout, so I can make the adjustments. Can someone help?
I am pretty sure the Cyclone 3000 and Cyclone mini has the same hall effect connector, so any one of them will be good...
Thanks!
I don't have access to my files right now but if my memory serves right, 2 wires are used to pass through "ignition" wire to controller. With ohmmeter, find those two wires that have 0 ohm resistance (measured both ways!).
I found one post releated: https://endless-sphere.com/forums/viewtopic.php?p=1299944#p1299944
btw the pin out for the hall wires is as follows
purp / blue temp cutout ( just a loop of the power switch wire really )
orange is ground
yellow is +5v or +15v depending on controller
black is hw
white is hv
red is hu
But from my own cyclone 3k hall replacement I have picture where wire colors are different: https://endless-sphere.com/forums/viewtopic.php?p=1319252#p1319252
red +
black -
blue/green/yellow halls
