GNG X1-pro 3000w
oefianer   10 µW
10 µW
Re: GNG X1-pro 3000w
Post by oefianer » Nov 30 2018 5:12pm
SlowCo wrote:
Nov 30 2018 2:23pm
oefianer wrote: 20s battery is 84volt.
The Controller can 72volt No more 🤣
Since when does 20S stand for 84V?
20x3.6V=72V
That is exactly what the controller can take NOMINAL!
When talking of controller voltage it is about the nominal voltage. And even the manufacterer quotes(!) 20S in their reply... :roll:
So yes a 72V controller can take a 84V fully charged battery.
I have a nother information CNC .
I Search morning old Email.
endrew   100 mW
Post by endrew » Dec 01 2018 3:02pm
20cells, 84V max.
andrebandre   10 W
Post by andrebandre » Dec 02 2018 2:59am
Excerpt from my ongoing email exchange regarding the X1:
"Yes, the controller will be suitable to go up to 20s. 36-72V rated. If it is too fast, you can limit the rpm via our app. We are working hard to fine tune the controller performance. Thanks for your waiting!"
Best regards,
Jon
anttipaa   10 W
Post by anttipaa » Dec 02 2018 4:02pm
So how many of you ordered so far? Just paid mine. Chain version. I hope it is good/better than bafang.
Canyon Torque + ?
Lenk42602   10 kW
Post by Lenk42602 » Dec 02 2018 4:10pm
I ordered a chain version on 11/22. Bike is all ready to go.
micah78   1 mW
Post by micah78 » Dec 05 2018 2:13am
So this should fit on a futr beta??I would like the geared version if it will fit.Been wanting a mid drive for a while and this looks like it fits the bill.
anttipaa   10 W
Post by anttipaa » Dec 06 2018 7:44am
My kit is shipped.
Canyon Torque + ?
LexHammer   10 mW
Post by LexHammer » Dec 06 2018 1:41pm
micah78 wrote:
Dec 05 2018 2:13am
Im also thinking about a frame similar to the alpha or beta, but i dont know exactly howthe motor is mounted. If the motor is moving along with the swingarm/rear shock, it may be a problem if the mounting needs to motor to touch the frame all the time
SlowCo   100 kW
Post by SlowCo » Dec 06 2018 5:56pm
LexHammer wrote:
Dec 06 2018 1:41pm
Why would the motor need to touch the frame? The motor needs to be attached to the bottom bracket and prevented from rotating. So if the bottom bracket is in the swing arm, the motor should be attached to the swing arm (to prevent rotating) as well. (Look in your own thread where I posted pictures)
LexHammer   10 mW
Post by LexHammer » Dec 07 2018 3:01am
SlowCo wrote:
Dec 06 2018 5:56pm
LexHammer wrote:
Dec 06 2018 1:41pm
Thats exactly what i mean, but the swing arm should be rather long so the motor can be attached there. According to the dimensions in the CYCmotors site, on the chain version, the motor is 25 cm long from the BB to the end of the motor. I dont have the frame, but looking at picures where the crank arm is just a little but shorter from where the wheel stars, there will be max 20 cm space, even fewer on frames like Futr Beta. I hope somebody with enduro e-bike frame (like the futr alpha, stealth bomber, vector typhoon) can check what the exact space is.
P.S. Im posting a picture to clarify things. The red one is how it should be on a normal bike, the green one is how you are proposing, if i understood correctly
SlowCo   100 kW
Post by SlowCo » Dec 07 2018 6:18am
LexHammer wrote:
Dec 07 2018 3:01am
No, but it seems possible on that frame.
Why don't you look at the pictures I posted in your own thread? In the second last photo you can see that the builder has ground away a little of the cooling fins on the BBSHD to be able to rotate the motor as far forwards as possible to clear (not attach!) the box section of the frame. The same goes for the CYC Motor X1-Pro. You can insert the bottom bracket of the kit in the swing arm and rotate the motor forwards as far as it goes before hitting the frame with the suspension in maximum position (wheel off the ground, no load). Then you need to fixate the motor kit to the swing arm so it cant rotate around the bottom bracket. That can be done with a strip or custom plate bolted to the swing arm. If there is enough room between the bottom bracket and the rear tire you could indeed also rotate the motor to the rear and fixate to the swing arm.
Lenk42602   10 kW
Post by Lenk42602 » Dec 08 2018 4:02pm
anttipaa wrote:
Dec 06 2018 7:44am
My kit is shipped.
antipaa where are you located? My tracking via hong kong post is not even trackable yet.
cheers,
len
crossbreak   100 MW
Post by crossbreak » Dec 09 2018 9:19am
same with mine.
Lenk42602 wrote:
Dec 08 2018 4:02pm
Lenk42602   10 kW
Post by Lenk42602 » Dec 09 2018 12:25pm
contacted Jon - he indicated that when they ship, they will be done so with an email containing a photo of the kit and an update to the paypal status as shipped.
Still in the final stages of testing.
I encouraged him to take their time and get it right on the first pass :thumb:
Len
n2mb   100 W
Post by n2mb » Dec 11 2018 12:05am
This looks great! But after reading the thread I still can't tell the difference between the gear and chain version. What's the pros and cons of each?
endrew   100 mW
Post by endrew » Dec 11 2018 12:34am
the chain version is longer, hence better ground clearance, and quieter. On the other hand less compact. It may also require less maintenance.
ScooterMan101   1 MW
Post by ScooterMan101 » Dec 17 2018 1:50am
For those who ordered from the U.S. , what is the quoted shipping cost to the U.S. ? and which one did you use 3-7 day or 2-3 weeks shipping ?
My first conversion ...
https://endless-sphere.com/forums/viewt ... 1#p1077497
It's 2018 already, lets get some real , improved e-bike / e-velomobile / e-motorcycle designs .
valkus   1 mW
Post by valkus » Dec 17 2018 3:18am
This is the first kit that gives you a choice between chain transmission from the motor and gear. I had an experience with GNG2 450W kit, and Ii was very disapointed by the build quality and the design.
For the chain transmission models they have a chain tensioner, a small wheel (derailer type). It was very fragile piece that failed first. With this model it looks a bit more robust, but I have an allergy now to this kind of solutions.
If i were to go for this kit then only in the geared version.
hypertoric_amplituhedron   100 W
Post by hypertoric_amplituhedron » Dec 17 2018 2:05pm
n2mb wrote:
Dec 11 2018 12:05am
I'd say that the geared version is well suited for off-road riding and cargo bikes, with harsher on/off power bursts and higher loads. Whereas the chain version would last on a road/trail surface, with lighter and smoother drivetrain loads.
There are two types of people in this world.
1. Those who can extrapolate from missing information.
Lenk42602   10 kW
Post by Lenk42602 » Dec 17 2018 6:57pm
ScooterMan101 wrote:
Dec 17 2018 1:50am
speed post 3-7 days. 120 clams
n2mb   100 W
Post by n2mb » Dec 18 2018 10:22pm
Has anyone received their kit yet? Photos?
Lenk42602   10 kW
Post by Lenk42602 » Dec 18 2018 11:11pm
no. none shipped yet
Post by hypertoric_amplituhedron » Dec 19 2018 8:15pm
All right, I'm in. I just ordered one, too. I'm going for an efficient dual sport build with 700x28 tires, 12s18p of GA, and using PAS with ab 700~2000w , and keep my cadence around 90-100 rpm (120 max). This will be my first PAS build on a middrive that I can pedal along with. Plus, I recently rode a customer's 400w ebike in PAS mode (a bbs01 I think) and thought it was really cool to go through the gears like that, without needing a throttle. And as a true ebike enthusiast, I immediately thought of how it would be on steroids, with crazy power up to 40-45mph. This motor came out just in time.
Tommm   1 kW
Post by Tommm » Dec 19 2018 9:38pm
hypertoric_amplituhedron wrote:
Dec 19 2018 8:15pm
I would go for 20s, as much as the controller can handle. It is free power you will be missing from that huge pack.
Post by hypertoric_amplituhedron » Dec 20 2018 12:51am
You think that would be a good idea if I'm only using it at 100 rpm at the crank? 120 rpm max? 12s would be perfect for those speeds. Even if I restricted the rpm that low on 20s, wouldn't I be better off going 12s in the long run? The size of the pack is for decent range at 35 mph, a typical cruising speed for me in some places. I was thinking of running 50v 50a for most hot rodding.
