Can you post a video from a cold start?
GNG / CYC X1 Pro 3000w
Re: GNG / CYC X1 Pro 3000w
Tommm,
Did you get your ASI controller from CYC or buy it yourself? Did they provide you with what you needed to tune the controller?
I have 1 from cyc and 1 from other european seller. The configuration you can upload to any asi, cyc will share it if you ask, but the harness is specific to cyc display(optional) throttle/brake/hall plugs.
You don't need a cable, only bacdoor login for bluetooth phone app to upload/download/change configurations, but they are reluctant to give login info(same as other asi resellers) as it isn't meant for the end user and asi don't like too many people using one login.
I'll do it tomorrow as I'm sharing a battery between a cyclone and cyc bike both with asi2000.
Interesting, it's a shame ASI doesn't like to share that login.. That would be critical to me even wanting to give the ASI controller a try. I need to be able to tinker and tune or I wouldn't get the nicer controller..
- Contact:
I have an BAC855 on the way so will update after testing.
The throttle sucks from 0 but once you're on it, its fairly responsive. Stock controller, stock settings 72v will slide out from under you mid-turn easily. No, you wont do power wheelies or any low speed kickers but its good enough for chopping up traffic around 40mph. So far the newest batch of controllers work fine throttle only even with a passenger. And I haven't had any heat issues with a city race that included a full throttle Central Park lap (6mi 400ft elevation)
But summer just started and I have a second battery on the way so we'll see
Yes getting the asi bac 855 with the 5,000 kit order June 16 and a 20s6p of Samsung 40t BMS 90 amp also in the mail. So would like to know more about asi 855.
Puzzling that people upgrade to ASI and yet still have throttle lag problems
Let's say you quickly rip the throttle from 0% to 50% or more, still 1 sec lag or instant?
You can set up asi torque and speed throttle response to the millisecond level. It's just cyc fault they don't have a good config, mine is based on the cyc config but it was lousy out of the box.
Hey guys...DID YOU KNOW
THERE IS A BACDOOR APP FOR PC that works offline, doesn't need a login, and is much easier to use and more full featured than the stupid app which is basically for people without working brains (or working PCs). Do you want a copy of the PC app? Please inquire via PM.
Also a 300ms ramp is frocking slow as shit I use like 1/10th of that on my ASI controllers paired with motors that are a decent match.
If anyone wants to send me a ASI / X1 file that they think has good throttle, I will try it and eat my words at once if it's good.
I going to ask Jon to pre program my controller for my battery and setup. I will bribe him. Or go to the next step.
Well after doing some more research I think I'm going to go with a cyclone 3000 kit (probably from Luna) with the stock controller initially. Once I get that working I will probably upgrade to an ASI if I can get programming software, so I can tweak and tune it.
This option is a good amount more cost effective for a first build (~$500 compared to $1000).
It should be enough for what I want, and give me a cheaper way to start up.
Think real hard about this because the cyclone 3000 in my opinion sucks more than twice as hard as the twice as expensive X1. The X1 not only is lighter and more powerful the build quality of the entire assembly is much higher. The stock controller is also better.
Yea, I know I won't be sticking with the stock controller on either build, so I'm not to worried about that.
The lighter and more powerful is tempting, but at this point its an experiment, so I don't think I can justify the extra $500 in something that likely won't work out. I doubt I need the power, I'll just have to gear it way down for torque (trials is slow, no need for speed). Of course likely will include converting to moto chain etc..
I have decent fab tools and skills, so not a lot of risk from that standpoint.
If it all works out, I can always sell this build or use it for more of a "normal" ebike and move to the CYC.
If you go with cyclone I think the gng one is better built than the luna one.Leanier wrote: ↑Jun 23 2020 9:54pmWell after doing some more research I think I'm going to go with a cyclone 3000 kit (probably from Luna) with the stock controller initially. Once I get that working I will probably upgrade to an ASI if I can get programming software, so I can tweak and tune it.
Thanks for the heads up, I'll take a look at the GNG one.
Is the motor and electrical actually different, or just the brackets etc?
The throttle on the cyclone controller takes some getting used to, if you're not careful you'll be doing a wheelie very quickly, it's very sensitive. After a week I'm already looking at other controller options, the pas is useless too.Leanier wrote: ↑Jun 23 2020 9:54pmWell after doing some more research I think I'm going to go with a cyclone 3000 kit (probably from Luna) with the stock controller initially. Once I get that working I will probably upgrade to an ASI if I can get programming software, so I can tweak and tune it.
Friction drive ebike viewtopic.php?f=6&t=235&start=1875#p1546191
Northrock XC00 fabike + cyclone 3000 viewtopic.php?f=6&t=235&p=1565563#p1565563
Which cyclone controller? Gng pair it with a different one. The luna cyclone controller (non mini) is a 40a yuyangking without Bluetooth, the 60a yuyangking has Bluetooth with tunable throttle.forcefed wrote: ↑Jun 25 2020 9:21amThe throttle on the cyclone controller takes some getting used to, if you're not careful you'll be doing a wheelie very quickly, it's very sensitive. After a week I'm already looking at other controller options, the pas is useless too.Leanier wrote: ↑Jun 23 2020 9:54pmWell after doing some more research I think I'm going to go with a cyclone 3000 kit (probably from Luna) with the stock controller initially. Once I get that working I will probably upgrade to an ASI if I can get programming software, so I can tweak and tune it.
In the end, if you want great throttle control, you aren't going to get it with the $3 thumb kits.
The 40a bluetooth waterproof one from sickbikeparts, an app allows you to make some throttle adjustments but they're pretty useless. The worst part is during cruising, if you let go of the throttle and get on it again you have to rev match the motor to your speed and then add more throttle or its going to jerk you back.Tommm wrote: ↑Jun 25 2020 3:09pmWhich cyclone controller? Gng pair it with a different one. The luna cyclone controller (non mini) is a 40a yuyangking without Bluetooth, the 60a yuyangking has Bluetooth with tunable throttle.forcefed wrote: ↑Jun 25 2020 9:21amThe throttle on the cyclone controller takes some getting used to, if you're not careful you'll be doing a wheelie very quickly, it's very sensitive. After a week I'm already looking at other controller options, the pas is useless too.Leanier wrote: ↑Jun 23 2020 9:54pmWell after doing some more research I think I'm going to go with a cyclone 3000 kit (probably from Luna) with the stock controller initially. Once I get that working I will probably upgrade to an ASI if I can get programming software, so I can tweak and tune it.
Does anyone know which torque sensor comes with this kit? Is it one of the known sensor that is stamped with cyc, or have cyc specced their own?
The torque sensor + freewheel looks like something that can be used to build torque sensing into other mid drive kits with a CA, so Im quite interested in it. How many poles for the cadence sensor, does it measure torque from both cranks, etc. ?
Thanks
Thanks
DIY lightweight mid drive with torque sensing build thread: viewtopic.php?f=6&t=107622
Try fast start 8, slow start off, adjust accelerator curve onforcefed wrote: ↑Jun 25 2020 3:41pmThe 40a bluetooth waterproof one from sickbikeparts, an app allows you to make some throttle adjustments but they're pretty useless. The worst part is during cruising, if you let go of the throttle and get on it again you have to rev match the motor to your speed and then add more throttle or its going to jerk you back.
Unfortunately that is the nature of a freewheeling motor. I have the same "issue" with bac2000 and domino throttle. The only difference is I have more precise control over the same interaction.
Torque mode throttles also work differently on a motor with multiple gears, on an easy gear 20% throttle will launch you at max speed for that gear, on a difficult gear 20% willjust slowly starting moving you.
I have my BT 40a controller set to "adjust accelerator curve" = OFF
i find this eliminates delay on throttle and strange throttle on while cruising.
Throttle delay is only linked to "fast start".
Boost mode is just fast start 11, useless, as 8 is high enough. So keep it off.
Adjust curve setting gives you finer control on the low rpm range but takes away a bit of control higher up:
Where vertical line is target rpm in % of max rpm, and horizontal line is throttle position.
That definitely helped a bit, time to get a better throttleTommm wrote: ↑Jun 26 2020 4:52amTry fast start 8, slow start off, adjust accelerator curve onforcefed wrote: ↑Jun 25 2020 3:41pmThe 40a bluetooth waterproof one from sickbikeparts, an app allows you to make some throttle adjustments but they're pretty useless. The worst part is during cruising, if you let go of the throttle and get on it again you have to rev match the motor to your speed and then add more throttle or its going to jerk you back.
GNG has the updated cyclone lunas cyclone is over half a decade old and hasn't been updated since they were heavily pushing the inferior bbshd till they got the sur-ron partnership.Tommm wrote: ↑Jun 24 2020 2:28amIf you go with cyclone I think the gng one is better built than the luna one.Leanier wrote: ↑Jun 23 2020 9:54pmWell after doing some more research I think I'm going to go with a cyclone 3000 kit (probably from Luna) with the stock controller initially. Once I get that working I will probably upgrade to an ASI if I can get programming software, so I can tweak and tune it.
