BBSHD 3KW controller opinions (Aust)
Beauie   10 mW
Post by Beauie » Sep 17 2018 2:23am
I have close friends that live and work in China and are willing to help me negotiate /design / make a new aftermarket controller for the Bafang BBSHD.
I will probably get a limited number CNC'd for my friends and I but if there's enough interest I will look into getting the tooling done to get the costs down.
I'm hoping to have programmable sine-wave controllers that fit / replace the existing controller for about $220 AUD.
Im located in Sydney, So only available to Aussies atm.
Let me know if your interested.
Cheers
James
Rube   100 W
Re: BBSHD 3KW controller opinions (Aust)
Post by Rube » Sep 17 2018 2:51am
Hi James, I'm interested in a new controller. Based in Brisbane.
Grautuefel   10 mW
Post by Grautuefel » Sep 17 2018 3:10am
Another one for Brisbane please, by the way, props for having a price in mind up front.
Beauie   10 mW
Post by Beauie » Sep 17 2018 9:29am
Cheers guys.
I'm excited to have a clean fitting programmable sinewave for the bbshd .
I'll probably limit the first run to 10 Aussies who like to ride fast, hard and are willing to test/ change a nylon gear once every few months :p (easy job :))
From what I've seen though they love higher voltage / amps
Will send you guys some more info through soon..
Grautuefel   10 mW
Post by Grautuefel » Sep 17 2018 5:36pm
I certainly push the gear fast and hard, although probably a little differently from your use case. Mine is hauling about 250kg at times on a mundo through some hilly paths. If this comes through I'll probably have to look at putting the boat anchor N171 hub back on as I've already managed to eat a bunch of rear gearsets.
Matador   10 kW
Post by Matador » Sep 17 2018 6:20pm
If there is a future for international orders,
I'd be interested (I'm in Canada) if shipping isn't too prohibitive (I know aussi shipping is expensive).
Matador
JonoP   10 µW
10 µW
Post by JonoP » Sep 17 2018 7:40pm
i'll put my hand up for one. im on the gold coast
Mines in pieces right now waiting on a new nylon gear after i got a bit carried away on the trails the other day. Would love to hook up a larger controller and really get into it.
BBSHD / 750wh 40a Battery / Giant Glory DH0
Beauie   10 mW
Post by Beauie » Sep 28 2018 4:35am
Quick update from my guy in China, nothing to really report but thought I'd keep you guy's in the loop..
"Hey, the cad drawings of the controller is to be revised at this stage. controller chip is being developed. you are looking at at least 3 weeks."
Hopefully here in a month :)
Grautuefel   10 mW
Post by Grautuefel » Sep 28 2018 11:11pm
Very nice, thanks for the update. Whereabouts in China are they based, I've got family coming in December.
racingame   100 W
Post by racingame » Oct 06 2018 9:52pm
I would be interested in it, but I'm from Europe. Still I hope you can ship me one at the extra cost.
Enric   1 mW
Post by Enric » Oct 07 2018 4:48am
Yes me too. I'm in Europe.
endrew   1 W
Post by endrew » Oct 10 2018 2:04pm
Also interested, also not in Australia, will be happy to pay whatever shipment costs...
andrebandre   10 W
Post by andrebandre » Oct 10 2018 9:32pm
endrew wrote:
Oct 10 2018 2:04pm
Same here.Located in the US.
Nicer   1 µW
Post by Nicer » Oct 13 2018 7:23pm
I'm in Sydney very interested
Beauie   10 mW
Post by Beauie » Oct 17 2018 12:51am
Awesome...
Apparently the first prototype is coming together nicely. Waiting to find out specs of caps etc etc.
I'm getting worried about the responsibility of all your guys hard earned dollarydoos and I'm thinking it might be best to get the first one sent over and I can run it through its paces and test / abuse it?
That process will obviously slow delivery times.
If anyone wants to take the gamble (factory assures me they will work great but if there are any issues return postage back and forth it could get expensive) with me and not wait LMK?
Hopefully have some pics etc soon
Cheers
James
endrew   1 W
Post by endrew » Oct 17 2018 12:28pm
I probably won't mind gambling on the controller (depending on shipment costs), however, I think it is important that the controller will be compatible with at least 74V batteries... will the controller be built into the motor same as the original?
fechter   100 GW
Post by fechter » Oct 17 2018 2:05pm
It will be interesting to see how this turns out. For sure there is lots of room for improvement on the stock Bafang units.
One problem I can see is the main capacitors. The stock BBSHD caps are marginally sized and would need to be bigger for a higher powered unit. But there isn't much room inside the housing. Having extra capacitors mounted outside (on the main battery wires) might be one way around this. Higher quality capacitors would help too.
Another possibility would be to make the controller housing a little thicker to have more room inside.
racingame   100 W
Post by racingame » Oct 17 2018 7:20pm
I actually got a question for you Beauie: how exactly are you gonna allow people to customize the parameters of the controller? Have you already designed a firmware and a software that accesses the controller from the PC and lets you change the values? Because after all, this is one of the main objectives of having a custom controller, not having to bother with any limitations imposed by the closed source stock firmware. The other goal is to get better components to allow for higher voltage and current so that everyone can easily turn his e-bike into the perfect suicide machine. :lol:
Beauie   10 mW
Post by Beauie » Oct 17 2018 9:10pm
It should be a direct swap over that fits were the stock one goes.
Hoping to use the existing bafang plugs / cable for programming.
Once they send me some more concrete info and pics I will upload and we can look for improvements etc.
Cheers
James
Beauie   10 mW
Post by Beauie » Nov 04 2018 11:38am
It's sad to say but looks like this is going to fall through.. Sorry for getting all your hopes up :( .. Looks like it's time to mod the stock one :p.. Sorry again I'm sad about this :(
racingame   100 W
Post by racingame » Nov 04 2018 2:40pm
Beauie wrote:
Nov 04 2018 11:38am
What happened if you can share?
Beauie   10 mW
Post by Beauie » Nov 04 2018 10:50pm
Price has gone up, they want more for tooling etc... I have a Skype call set up this week with my guy in China but it's not looking good :(
Grautuefel   10 mW
Post by Grautuefel » Nov 05 2018 12:29am
Tooling? Were they going to cast it? I would have though for such a small run you'd just mill it, face cutter, pocket end mill, drill bit, slotter. Anything a basic machinist shop should have. Usually the expensive part is setting the machine. PCBs are done cheap by a mob like JLC pcb, with some poor kid in a poorly ventilated room in downtown Guanzhou hand soldering the components. If you had the schematics for the plate and board I'd be interested in getting a few quotes for a 10/20/100 run.
Cobain Windsurfer   1 mW
Post by Cobain Windsurfer » Nov 08 2018 4:21pm
:roll: ...well...why PAY someone else to do the fun part, when you can do it yourself? :mrgreen: :mrgreen: Here is the DIY thread, happy reading and soldering :) :arrow: viewtopic.php?t=83778
