Full suspension mountain bike Friction Drive
Grantmac   10 kW
Re: Full suspension mountain bike Friction Drive
Post by Grantmac » Aug 05 2019 10:27pm
How much contact width are you actually getting/need?
I'm thinking of the rollers which run between the tread blocks and how little could be gotten away with.
Kepler   1 GW
1 GW
Post by Kepler » Aug 05 2019 11:16pm
I haven't personally tired it but other members have. It would be good to hear how the tire is standing up.
viewtopic.php?f=28&t=96581&start=100#p1479759
Current Rides
Lightest true ebike on the planet: ON ROAD viewtopic.php?f=6&t=74269
eBoost on facebook: http://www.facebook.com/pages/Eboost/200306283342024/
Grantmac   10 kW
Post by Grantmac » Aug 05 2019 11:43pm
That's exactly the one I'm curious about. Possibly if it could be combined with the cogged roller idea, but with enough space that the cogs would only make contact if it started slipping.
Unaserit   1 µW
Post by Unaserit » Aug 08 2019 5:03am
Ride infrequently. Still rocking a Cannondale F700 from time-to-time. That's the model Cannondale loaded with as much '90s tech as was available: Headshok, Grip Shift X-Ray shifters, Onza pedals with the rubber inserts, and a subpar proprietary cable pivot for the cantilever brakes that was dropped for a Tri-Dangle which wasn't exactly an improvement.
Haven't looked at bikes in 20 years. What are the options for used, full suspension https://bikesbros.com/full-suspension-mountain-bikes/, titanium mountain bikes? Something I can find on Craigslist around a grand. Found a few hard tails in what appeared to be decent shape for less so am assuming that's a reasonable target.
Litespeed used to be good. Dean used to be good but more boutique. XC/all-around suspension rear suspension meaning it doesn't need to have huge travel (but more than a Unicoi). A good rear suspension design would be nice. Horst link? Something better than the unified rear triangles that were new 20 years ago. Titanium for no other reason than the cool factor.
Thanks.
Howiep   100 µW
100 µW
Post by Howiep » Aug 28 2019 1:26am
Grantmac wrote:
Aug 05 2019 11:43pm
Each side of my roller is 4mm wide, so 8mm total. The actual contact area would be slightly more because it's angled.
There are no problems with slippage when the pressure is dialed in right, but I don’t yet know if the wear is acceptable - I rode about 70km of mixed road and mtb with almost no noticeable wear. But then I accidentally let the motor mount get crooked (maybe due to heat, or me constantly messing with it) and it munched almost through to the casing threads in about 20km. Just like a car with crooked wheel alignment.
The new mount I'm making should keep a straight even contact much better, and I'll post again when I’ve done a longer period of testing with it.
I also tried a "makes contact with casing around knobs" roller with Specialized Slaughter, and Maxxis Forekaster tyres but had the same result as Kepler.
There is always a tiny bit of slip with this system because rubber. As a result the voids in the roller always end up scootching up to the edge of the tread blocks. Even though it's not pushing on them hard, it's still striking each knob as it rolls around, which makes for the jet engine noise Kepler aptly described.
However I did find it difficult to correctly mesh the roller to the tread knobs over the curved tyre profile as the circumference changes from centre to edge. A nicely meshing volute gear profile may be more successful.
Here is the one I tried with the Slaughter tyre:
SlowCo   100 kW
Post by SlowCo » Aug 28 2019 7:05am
Great thread, thanks for all the info.
Grantmac   10 kW
Post by Grantmac » Aug 28 2019 11:53am
It sounds as though slippage is just a fact of life. Interesting to hear that 8mm of contact can work. Although it seems like a rigid mount becomes very important with the narrow contact patch.
I wonder if you could create a roller which makes contact with the sides of the knobs or if you would have the same noise issue?
Leeleeducati   100 W
Post by Leeleeducati » Aug 29 2019 12:08pm
Has anyone on ES successfully driven the rim? Stumbled on this the other day, seems like this concept could solve some of these problems as well as I’m sure opening up a bunch of new ones :). Thought I’d share, may spark some ideas for those that haven’t seen it.
http://www.velogical-engineering.com/ve ... rofittable
andrea_104kg   100 W
Post by andrea_104kg » Nov 28 2019 3:59pm
