LMX 64 : Freeride Ebike with dual drive and torque sensor
BCTECH   100 W
Re: LMX 64 : Freeride Ebike with dual drive and torque sensor
Post by BCTECH » Oct 18 2018 12:54pm
efMX Trials Electric Freeride wrote:
Oct 18 2018 12:43pm
BCTECH wrote:
Oct 18 2018 12:31pm
how does the e-bike brake (regen brake) work when both side have freewheel? while the motor stops, you can still pedal to move the bike right?
this lmx model does not have regen braking, just motor cutoff at brake lever, optional ..
the motor side freewheel allows the bike to be pedaled without motor power or cogging..
thanks!
what is the benefit using ebike brake vs normal brake in this case?
efMX Trials Electric Freeride   100 kW
Post by efMX Trials Electric Freeride » Oct 18 2018 8:28pm
BCTECH wrote:
Oct 18 2018 12:54pm
Oct 18 2018 12:43pm
BCTECH wrote:
Oct 18 2018 12:31pm
thanks!
brake lever motor cut off is often disabled for aggressive riding, wheelies, burnouts, etc.. being able to use the brakes and motor power independent instead of dependent..
some ride & sk8 videos:
metacafe.com/channels/NATAS666DAMIEN
http://www.youtube.com/natas666damien
i have nothing for sale.. :)
jbalat   10 kW
Post by jbalat » Oct 21 2018 10:37pm
A bit hard to see the rear disk brake ? Any close up pics ?
Please subscribe to my Youtube home page for Quadcopters, FPV and Bike Rides http://www.youtube.com/jbalatutube
My build log here http://endless-sphere.com/forums/viewto ... =6&t=55352
For some cool ebike talk join us on The Best ebike https://www.facebook.com/groups/193581737807033/
Tech talk TSDZ2 Opensource firmware https://endless-sphere.com/forums/viewt ... &start=150
Opensource TSDZ2 Wiki https://github.com/OpenSource-EBike-fir ... _wiki/wiki
bzhwindtalker   1 MW
Post by bzhwindtalker » Oct 22 2018 1:30pm
It is the same system we have been using on the lmx81. However on the two pics above it is not the latest version of the sproket carrier. The newer version has the screws on the outside to ease sproket change.
bzhwindtalker   1 MW
Post by bzhwindtalker » Oct 24 2018 7:21am
We opened the preorders :
https://www.lmxbikes.com/en/accueil/143 ... -emtb.html
Any question, send me a PM :)
bzhwindtalker   1 MW
Post by bzhwindtalker » Oct 30 2018 8:39am
Due to changes in components specs (lighter tubeless ready wheelset and 2.6" ECER75 offroad tires) we will have to increase the list price to 5999€
Weight is down to 27.5kg complete, tubeless.
bzhwindtalker   1 MW
Post by bzhwindtalker » Oct 30 2018 9:14am
Frame kit prices
For the frame kit with :
Controller
display
torque sensor
wiring
back wheel with HALO VORTEX tubeless ready rim and Shimano style freewheel body
motor side transmission
headset
The preorder price is 2400€ EX VAT.
It does not include :
Battery
Front and rear suspension
tires
brakes
handlebars and stem
pedals
seatpost
bike side transmission
Price incl 14S5P 35E battery and wired is 3300€ EX VAT
macribs   1 GW
1 GW
Post by macribs » Oct 30 2018 9:43am
bzhwindtalker wrote:
Oct 30 2018 8:39am
The 1.5 kilo weight savings all in the wheels? Nice. Less rotational mass. How much weight savings by going tubeless? And how much of that is the tire choice?
Antenor   100 W
Post by Antenor » Oct 30 2018 11:50am
What battery type will fit?
devo1223   100 W
Post by devo1223 » Oct 30 2018 4:40pm
I've been waiting for this frame kit, sooo tempting. Does it come with Vasilis's nucular controller and display? Does it have a bms? What torque sensor are you using?
Vector lite stuffed with 30Qs
Mxus 3k turbo 3t in 17in moto rim
viewtopic.php?f=3&t=92531&p=1353484&hil ... e#p1353484
bzhwindtalker   1 MW
Post by bzhwindtalker » Oct 31 2018 4:04am
macribs wrote:
Oct 30 2018 9:43am
Actually saved 1.1kg per wheel with new rims, around 350gr saved in tubes and 250-300 gr saved by going with enduro/gravity folding tires instead of rigid gravity tires.
Antenor wrote:
Oct 30 2018 11:50am
It fits hailong type battery, and reention DP-6.
Not sure about the big haillon, but this one fits 78 cells in 13S6P
The frame kit includes the Nucular controller and display, sempu 3th gen torque sensor with crank arms, no BMS is provided unless you take the battery with the kit.
Best regards,
jbalat   10 kW
Post by jbalat » Oct 31 2018 6:31am
Hey Adam just noticed that the red chain tensioner in the photo above looks a bit tight/aggressive, do you think that may contribute to any noise.
Also how does this bike handle on the tracks in a mountain bike park, is it ok with jumps, drop offs and all the ruts and tree roots ? Or is it more suited to free ride ?
bzhwindtalker   1 MW
Post by bzhwindtalker » Oct 31 2018 9:04am
The bike is very well suited to jumps and is very playful par to modern 160-180mm enduro MTB.
Here is a video we shot riding the LMX 81.
Check the gap at 0.52, landing in the roots.
The 64 does the same, only much better stability due to shorter rear end/longer front triangle, lower bottom bracket height, slacker headtube angle and steeper seat tube angle, more linear/progressive suspension with lower leverage ratio, lowered center of mass.
bzhwindtalker   1 MW
Post by bzhwindtalker » Nov 02 2018 11:06am
I really like this kind of views from 3d models, what do you guys think?
bzhwindtalker   1 MW
Post by bzhwindtalker » Nov 04 2018 9:25am
Trail riding with the LMX64. 35km ride with a lot of stop and go for video.
litespeed   100 kW
Post by litespeed » Nov 04 2018 10:59am
Looks like an excellent ride.
Tom
bzhwindtalker   1 MW
Post by bzhwindtalker » Nov 09 2018 11:01am
Cowardlyduck   100 MW
Post by Cowardlyduck » Nov 10 2018 6:44pm
VERY interested in the frame kit!!!
Selling my Stealth Alpha and might also sell my Fighter if I can get this.
I like long range...something the stock version of this bike is lacking. I would solve this by either trying to make the big haillon case fit or having 2 (maybe 3) of the standard size packs so I can swap them out as I go.
How easy is it to swap out the battery packs? Could you post a picture or video of the mounting system for the battery?
Also, when does the cheaper price for preorder price of kits end?
Cheers
High Power LiPo wiring harnesses - 4P - XT90, HXT4mm, 5.5mm. 200Amp+ capable. Global shipping.
Modified Stealth Fighter - Force air cooled motor @ 6KW, Adaptto Mini-E. 49AH, 52V 18650 - 2.5Kwhr
Cowardlyducks - Stealth Fighter Videos
BikeE recumbent commuter - 9C, 6Fet Grinfineon, internal 17AH, 52V, + on-board solar.
Ebike Garage - My YouTube Ebike ramblings.
bzhwindtalker   1 MW
Post by bzhwindtalker » Nov 12 2018 5:16am
We added the first version of the stickers kits on the test bikes :
The packs are very easy to swap, like any hailong/reention case.
There is a possibility to add a second case below the down tube for more capacity, but you would have to run the two battery in //. No problem with matched single ports BMS.
Preorder will end when the first 20 bikes / kits are sold.
Adam
bzhwindtalker   1 MW
Post by bzhwindtalker » Nov 19 2018 1:09pm
Latest video with some details of the controller, modes setup and controls.
For the serial model we will add an external mode switch close to the dropper seatpost remote with up/down keys to ease mode switch during the ride. As I said before we are working on reducing noise, with some lower KV motors and bigger front sprokets and other small improvements.
jbalat   10 kW
Post by jbalat » Nov 19 2018 5:57pm
Looking good !!!
Cowardlyduck   100 MW
Post by Cowardlyduck » Nov 19 2018 6:27pm
Put my order in for an LMX Frame kit. :)
Glad I went with the basic option for 2400....after shipping and conversion to AUD it was over 4k :shock:
Should be worth it though....this thing looks like it is years ahead of anything else similar out there.
Gonna be making several batteries, not sure if I will attempt the bigger hailong pack or just 2-3 smaller ones.
I still didn't see any info on the top speed? I guess it depends on the battery voltage....what is the controller/motor recommended max voltage and what is the speed at this voltage with a 26" wheel?
Cheers
